E Flight HABU 32- P-20SE Build thread+Videos*
#201
RE: E Flight HABU 32- P-20SE Build thread+Videos*
Chris
CA or silicon sealer. The tailpipe to cool ring has them glued to the cool ring only, with the tailpipe a slide fit to the required distance for cooling 5-6mm. On the two Habu I have done, I glued the cool tube/ fuselage spacers to the fuselage with CA and used two small drops to hold the cool tube in position. I can remove the tailplane halves without taking the tail pipe out, a long 2.5mm ball driver goes between the two tubes
Dave
Dave
#202
Good news
Another batch of tail pipes for Europes most popular Habu 32 conversion have arrived
Just need more tanks now []
Dw
Dw
#203
Banned
1 Post
Do up your nuts
We flew mine today and had a very lucky escape as I had forgotton to do up the lock nuts on the control rod push rods. On landing one aileron was completly disconnected. Curiously this was not noticed in flight.
They are now all tight with a little dab of cyno on each
Dennis
Dennis
#204
Turbines don't vibrate...
Don't use nuts. Just thin CA which wicks down and fills the thread, locks the rod and takes out the play.
Simon and Colin were out today playing Habu 32T's Left mine at home to concentrate on Torus practice...tomorrow is another day though
Dw
Dw
#207
You think something running at 245,000 would last out of balance? Other than airframe pulsing there is nothing...and anyway you knew what I meant verses IC DF or EDF.
Dw
Europe?!
Dw
Europe?!
#208
1 Post
Think the 'Europe' thing came from the Heinekenesque comment about Europes most popular Habu 32 conversion - creative yes but don't work in a corporate marketing department (not that you would want to), you might not last long with unsupported sweeping statements like that
Even Heineken added 'Probably'.................
marcs
marcs
#209
Banned
1 Post
ORIGINAL: marc s
marcs
marcs
See the last page in RCJI June/July............. So my comment was not so much unsupported as understated............
I am sure however DW belives he is right though
#210
Funny, missed that. We don't sell in the USA and I don't know how many sets Tams have sold. I've run ten different P-20's and have something over 120 flights on them...anyone else?
Anyway, a text last night asked for a test flight on another M&R conversion, so 7.00am meeting with Andy at PMFC and a trimming flight by me, followed by Andy's first flight for my camera.
Dw
Dw
#211
Dave, I've been looking for the IRL rpm and EGT of the P-20 at WOT without finding any numbers. Maybe you want to share the info :-)
Which is the maximun RPM limit of the Jetronic fadec? same 250000rpm as the Gaspar one?
thanks.
thanks.
#212
EGT during start spikes around 900 degrees and idle 480ish WOT 615-620 on most of my installations.
Max RPM is above 250,000 but I don't know what it is...and Gaspar's is too, my original T-32 is set to 254,000...
Dave
Dave
#214
Dave,
care to share how to set max rpm to 254000?
I hv been look tru the hand held and almost eat it for dinner no wat I can adjust anything
more then preset 245000rpm
typo? if that so I will sleep very well afterall
yiming
yiming
#215
My T-32 was the very first #1 and the very early supplied ECU unit allowed 255,000. The early engines were much less powerful, mine is 1.2kp so needed a high RPM, Martin asked me not to run it past 248,000 normally with the hand produced turbine wheel.
Regards
Dave
Regards
Dave
#216
ORIGINAL: SniperWj
Dave,
yiming
Dave,
yiming
#217
that is nice to void warranty exchange for more speed henke!
I will do that if I know what to do to after open up the jetcat CPU box...
tune up bit by bit and pay attention on the temp....
ah... talk is cheap! I know I'm dreaming.
I'm having bad habit on *****g out everything I'm playing with,but not this time on this p20.
#219
ORIGINAL: marc s
marcs
marcs
#220
Banned
1 Post
ORIGINAL: schroedm
Biggest issue appears to be the proof reader's abilities - should have read ''...world's most experienced'' [8D]
ORIGINAL: marc s
marcs
marcs
#221
Banned
1 Post
ORIGINAL: Dave Wilshere
Dw
Dw
Dennis
#222
Dennis
Do you just get out of bed and...
No, I just don't know Tams figures. Anyway, haven't you got something to build...
Your biggest Fan
Your biggest Fan
#225
Dennis,
I do not usually get involved in stone throwing but your just a pain in the arse.
Do you have nothing better to do? From your post a few months ago i thought you would have - how are your 500 staff etc etc etc - for such a BIG BOY you seem to have a lot of time on your hands.
If you have nothing nice to say it is usually best to say nothing at all and by all accounts - empty vessels usually speak the most!
Love always
your number 1 fan
Love always
your number 1 fan
