If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 76 to 100 of 277
  1. #76
    Join Date
    Jun 2002
    Watford, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: E Flight HABU 32- P-20SE Build thread+Videos*
    Nose weight depends on the battery used. You had a NiMH? I used a small 1600mAh Li-Po. When I do the next one I'll arrange things forward more.
    Dw
    Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Airtech Germany, Jet Tronics.
  2. #77
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Last two I missed.
    Photos by stand in photographer Roland-thanks
    Dw
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1570734   Click image for larger version.
  3. #78
    Join Date
    Oct 2009
    Athens, GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Dave Wilshere
    Dw
    You are using the LiPo battery for all?I mean for servos L/G and turbines Ecu? how many flights will give you the 1600 LiPo battery?
    No excuses...!
  4. #79
    Join Date
    Feb 2004
    Rickmansworthherts, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So long since I used the video that I can't find the lead to download it tonight. I will get one in the morning and post up the video then.
    Trevor.
  5. #80
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have two Li-Po 1600mAh. One with a Digi switch for radio and U/C electric retracts, one for the Turbine. I need to charge both tomorrow to see amounts. My guess is 20 flights radio and 10 flights turbine (on board gas), but as always I will charge after know useage and see. Unknown is flap servo use, P-20 models like my AW Cougar without flaps using a Powerbox Digi switch use 40mAh per flight! That has a 3000mAh Rx Li-Po
    Dw
  6. #81
    Join Date
    Apr 2004
    Chichester, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good effort dave! So question is, when can we get our greasy mitts on them?
    Also, what sort of takeoff length needed from grass? Did the plane handle the rougher grass conditions ok?
  7. #82
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Only the ships captain knows that! middle of March latest. Sold two more conversion sets today after the test flights. Take off run was quite long today, 45-50m, but the grass was very wet and quite long-we get a lot of worm casts and these act like wheel chocks! Also I set the plastic wheels quite tight on the legs, so they polish in nicely. It floats off and I'm set dead level with std wire leg length on the nose, I will add 6mm length with oleo. I would guess on normal grass 30-35m, landing roll today was 10max!
  8. #83
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok.
    Expo figures I'm flying are 20% on ailerons and 35% on elevator, 20% on rudder steering-if you run a separate nose steering channel, I'd run less rudder expo.
    Dave
  9. #84
    Join Date
    Apr 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Excellent, sounds like a good small field flyer, just the sort of model I'm after, prob take me a while to get a landing roll of 10m tho!
  10. #85
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    8-10mph wind today, you can hover it in with the Flap I have!
    Dw
  11. #86
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK, charged up both Li-Po packs and Rx was 168mAh...that's all the final set up and three flights! ECU was 87mAh per flight.
    So safe I have 25 flights Rx and 15-16 ECU.
    Dave
  12. #87
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The micro on board gas tank also looks to give minimum 3 starts.
    Dw
  13. #88
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys,
    Sorry about the quality but here is the video taken at the weekend. First link is to the maiden take off and lading only as these are of interest to most as opposed to the edited middle part which is of a small model at height dialing in the flaps etc.
    Second link is second flight in full.
    http://www.youtube.com/watch?v=qRbTnjwWnMQ
    http://www.youtube.com/watch?v=fdEi0z0BZ4w
    Trevor.
  14. #89
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice job Trev, Aileron differential needs a tweek still.
    Cross wind direction on our patch gives 70-80m (and ridges!!) shorter grass will defo reduce take off roll, amazing how it copes with 2 1/2" of grass!
    Dw
  15. #90
    Join Date
    Apr 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Interesting celebrations at the end of the second video, don't get that when I land at our club!
  16. #91
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OOOPS, guess I uploaded the wrong vid then
    Trevor
  17. #92
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Drums!! PMFC has allsorts of entertainment provided!
    D
  18. #93
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Uploaded the shortened version now and corrected the link. Hope you don't miss the Taiko drums.
    Trevor.
  19. #94
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Out this morning for a few hours and eight (8) flights on the Habu 32. Having got 99% of a set up I like dialed in, I have to say it flys a lot like a Bandit! Really, the elevator feel is very much the same, slightly soft in its feel. But, thats not a bad thing, feeling like a Bandit! Take-off roll in calm conditions and bumpy draggy grass is still 50m today, a little wind, the wheels bedding in and smoother grass and it will come down a lot. Landings are still slow and gentle, again, a good pull on flare is needed like a Bandit.
    Knife edge is the only thing it's not doing as I wished, I think the rudder could have done with being 20% bigger, but long slow rolls track fine with the rudder available.
    Couple of my friends had a go today and both seemed to like it.
    Winner, a really great aeroplane
    Dave
ID:	1573536   Click image for larger version.
ID:	1573537   Click image for larger version.
ID:	1573538   Click image for larger version.
ID:	1573539   Click image for larger version.
ID:	1573541   Click image for larger version.
  20. #95
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    More
ID:	1573543   Click image for larger version.
ID:	1573544   Click image for larger version.
ID:	1573545   Click image for larger version.
  21. #96
    Jamie C's Avatar
    Join Date
    Apr 2008
    Somerset, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bloody hell Dave! how close is the Motorway to your flying site?
    Habu does look to have fantastic performance with a P20 . . . . I hope that cargo ship is moving at flank speed!!
  22. #97
    Join Date
    Oct 2009
    Athens, GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hope you 'll enjoy it.....where is the CG Dave? I believe the manual says 100- 115mm...where is yours?
    No excuses...!
  23. #98
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jamie
    Long lens...a field and a bit away.
    It's a finger tip 110mm empty main tank, does feel slightly nose heavy on full tank, but 2min into the flight feels OK. I was doing some "hovering" today and no wing drop. Also just charged ECU pack after 8 flights....596mAh...so 20+ flights in my ECU pack!! Have not bothered charging Rx as voltage is 7.99-8.0v after the 8 flights, will fly again tomorrow and then charge!
    Few more pixs. You can see how much elevator is used on take off...it floats off at this setting. Did quite a few inverted spins today aswell and after each flight MAP had a tiny bubble only.
    Dw
ID:	1573602   Click image for larger version.
ID:	1573603   Click image for larger version.
  24. #99
    Jamie C's Avatar
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How are the efilte retracts standing up to grass field ops?
  25. #100
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Eleven flights now from rough grass and I've had to "tweek" by hand one main leg forward as it had moved back a fraction. Operation perfect, every time. They "wear" for the first three or four flights then they seem to stay as they are.I see no reason to "upgrade" Anyway a complete set is £75!!
    Dave
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
