E Flight HABU 32- P-20SE Build thread+Videos*
#101
RE: E Flight HABU 32- P-20SE Build thread+Videos*
What about the landing?The manual says the flap-elevator mixing at full flaps is 2mm down elevator.is that correct to you or you're not using flaps?
How many amp is the batteries you 're using?I think you must have two batteries...
#102
There are pictures and video showing the landing...and the Flap setting!! I have more flap than the manual and more down too. Still need to measure the figures for my conversion manual.
One 1600Mah 2s Li-Po, on each ECU and Rx as the build information. I have on board gas using a micro gas tank which gives around 3 starts. Gas start is very low consumption.
Dave
Pictures show flap angles
Dave
#103
Thanks for letting me play with the Habu ! When the original foam Habu came out it was amazing to fly a small foamie that handled so purely. This is definitely the next evolution of that concept, nice pure flying fun and a "proper" turbine model. I was impressed with the speed range - really nice and slow with the massive throw you've got on the flaps and it doesn't half zip along when throttle turned to "on"
Love it - can't wait to get mine. Next evolution will have twin booms for sure!
#104
Banned
1 Post
ORIGINAL: gontflyer
Thanks for letting me play with the Habu ! When the original foam Habu came out it was amazing to fly a small foamie that handled so purely. This is definitely the next evolution of that concept, nice pure flying fun and a ''proper'' turbine model. I was impressed with the speed range - really nice and slow with the massive throw you've got on the flaps and it doesn't half zip along when throttle turned to ''on''
Dennis
#106
Four more flights today on the Habu 32, Now 15 flights completed and reliability has been faultless, as expected.
Photo of fuel level and bubble trap after the last flight today, this flight was 6 min
Dw
Dw
#107
Dave
I am amazed that you don't have any problems with the Tygon slipping off, I find if I don't wire tie mine on they just slip off or let air in, have you done something special to attach them?
Mike
Mike
#108
Banned
1 Post
ORIGINAL: BaldEagel
Dave
Mike
Dave
Mike
Dennis
#109
Dennis
Does not matter what size Tygon I use once the oil and fuel gets on it, or under it they slip off, learnt this a long time ago with my petrol engines, can't say Kero is any different.
Mike
Mike
#110
Banned
1 Post
ORIGINAL: BaldEagel
Dennis
Mike
Dennis
Mike
Dennis
#111
Not sure what size tygon or nipples I use but on gas and with jeta never had one come off or leak. They are on very tight.
#112
ORIGINAL: BaldEagel
Dave
Mike
Dave
Mike
Never wired any of my models, never had a leak! Only use 3.2mm bore 1/8" 4040 Tygon. Once it's been on 24 hours, I would have to put my foot on the tank and stretch with all my strength to get off. What I actually do if I need to remove is "pinch" the tube with bull nose pliers to ravel, then it comes off. Never Never cut it off!
I'm guessing you use straight brass tube, no barb? The nipples I use on this tank are 4.8mm at the barb point, on 5/32" (4mm) brass tube pipes I slip a Dubro solder barb over, these are 5.3mm over the point of the barbs... I think I sent you some free barbs with the ducty tank?They were the 1/8 pipe size ones?
The clunk line in this tank is 1/4" od 4040 tygon with a felt clunk, the line is only 82mm long-Even I thought it might be too short, but as shown by the pixs after a flight with rolls, loops, spins, inverted it's working fine...
Dave
#113
Banned
1 Post
Just ordered my Habu 32 with the e flite electric retracts. I am going to go electric first with the recommended setup (Cost £120 excl batt and a cheaper ESC) then if I like it I will bite the bullet and put in a P20 or if I like it electric too much buy another and put in a P20. These certainly are a good little plane.
Dennis
PS The virus on this site continues to be a pain I think it is worse if you hit the quote option
Dennis
#114
Dave
I do barb my copper pipes, usually I solder a piece of paper clip around the tube and tie behind that, perhaps the barbs are better at holding the Tygon on, I have used the Dubro barbs, but found them difficult to get hold of, will have to try harder to get hold of some and try them on my Kero installations, only ever used them on Petrol previously. I did not find any barbs in with the Ducty tank, perhaps I missed them in the packaging, I have to admit the size of the box was a bit of supprise.
Mike
Mike
#115
Mike
The have multiple ridge/rings, so each of these add a seal, plus they are perfectly round.
We keep both sizes in stock ;-) guess something else to add to the web shop-only another 2000 products and we will be there!
Thought I put them in with the tank package...maybe it was another, too old to remember for sure...
Dave
Dave
#116
Video done by a club member on saturday early before the sky cleared. Thanks Nige who posted it on another site. camera was a flip screen family holiday job, not brilliant quality, but shows bits.
http://www.youtube.com/watch?v=zqJG1pYt6Lw
#119
Just found time to charge the Habu 32 Rx Li-Po after 12 flights Saturday/Sunday and it used 394mAh total, so with a 1600mAh Rx battery that's at least 40 flights on a charge.
Dw
Dw
#120
ORIGINAL: Dave Wilshere
Dw
Dw
#121
As the post on the previous page, I seem to be using 75-85mAh per flight on the ECU (Gas start) I have a 1600mAh pack on that too.
Dave
Dave
#122
ah, sorry I missed that part. Alot of numbers, digi switches here and there For the smaller more weight sensitive airframes two 350mah packs would be enough for a couple of flights too then.
#123
Henke
Yes, I fly things like my CARF Spark with 480mAh 2s pack and get 4 flights easy. Powerbox switches are great.
The Habu 32 needs the weight, so bigger batteries make sense.
Dave
Dave
#124
Another batch of 20 Habu 32 tail pipes just arrived today, perfect timing for more European orders going out.
Pix of the tail pipe/turbine today after around 17 runs
Dw
Dw
#125
First time off tarmac today with the Habu 32, five more flights. Package really has worked out very well, totally reliable model. Only comment would be need for light colour on the wing/tail LE as everything is dark and on days like today it disappears coming towards you.
Dw
Dw
