original oil and feulpump sophia j850
RE: original oil and feulpump sophia j850
oh ,but i can change it ,no problem .
if somebody tells me how much oil /second is need ,i can make it my own ,way.
The important thing is that the bearings getting the lube , and how ,i dont think that matters.
I will test it ,and let you know.
i am not happy with two pumps , they can stop running you know , i dont like that.
less electronic as possible .
But the feul pump ,thats bothereing me , i dont have one , i have to search for a solution.
Thanks for the info.
When i am going to take it apart ,i will post some pictures here.
Regards,
Martin.
Regards,
Martin.
ORIGINAL: mick15
Sure, the bearing# is GMN MHY SO 4837C' MXA A7
m
m
Are they expensive?
#33
Mick, somehow I have not been succesful in locating the part number with your number but I did locate the part under my number. Also, there does not seem to be a part number starting with MHY. Could it be that they do not do them anymore?
#34
I did here a rumour they had stopped, it was a bearing made especially for Mr Hoya and is an odd size. I did fit some Boca equivalent but they are rubbish.
m
m
#36
My Feedback: (25)
More literature on the Sophia 850 can be found here...
http://www.rcuniverse.com/forum/m_44...tm.htm#4400791
#42
ORIGINAL: Countryboy
Let me see if I can get my scanner up & running, and I will see what I can do. PM me your e-mail address
ORIGINAL: frema
is it possible that you can copy the instruction manual ,and sent it to me thrue email?
Oke thank ,i will sent my adres to you.
Martin.
#43
Martin,
Are you currently trying to sell the 850?
http://cgi.ebay.co.uk/SOPHIA-J-850-T...item5642c7ae23
Martin,
No , but i saw this on ebay a few days back.
Its the same as i have ,but my camera is broken ,and i cant take pictures of mine,soi i used these pictures from this ad to let you show how my engine and ecu looks like.
its just the same ,only i have more wires from the ecu ,but i dont have the pump and terminal and instruction manual like this one .
Regards,
Martin.
#44
My Feedback: (25)
ORIGINAL: frema
Martin.
ORIGINAL: frema
Martin.
Please disregard, got the PM.
#46
I will go to LosAngeles from Japan in July.
Can I purchase with a credit card the J-850 engin directly?
Thank you to contact you.
[email protected]
hashimukai
[email protected]
hashimukai
