If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
  1. #1
    Join Date
    Dec 2002
    Woodbury, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    1/5 scale Skymaster F-86 and a P-200
    I am thinking of replacing my P-160 with a 200 and am wondering what I need to change. The turbine mount is straight forward but do I need to replace the exhaust tube? Is there enough room with the new tank location or will i need to go back to the older tanks?
    Anyone have some pictures of their installation with a P-200.
    Scott
  2. #2
    dubd's Avatar
    Join Date
    Aug 2007
    Bay Area, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 1/5 scale Skymaster F-86 and a P-200
    Can't speak for the F-86 speciically, but the times where I went from 160 to 200 required a different pipe, which I bought from Tam Jets
  3. #3
    Join Date
    Feb 2004
    oslo, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    P 200 in a 1/5 F-86!!! why???
    Tom
  4. #4
    Join Date
    Dec 2002
    Woodbury, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The main reason I am thinking about the P-200, shorter take off's run. The plane is plenty fast once in the air, but it eats up a lot of runway with the 160 even on tar. The F-86 was never a really fast jet, but we lost the only long tar runway here and it will likely fly off a grass runway from here on out, except for the few times I take to an event.
    Scott
  5. #5
    TED ANTON's Avatar
    Join Date
    Dec 2004
    Toronto, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The first SM F86 Sabers had the same problem, too much weight forward of the CG, the take off roll was very long ,
    I think a P200 is way too much motor for that plane the residual thrust would be an issue as well. I have a P160 for mine
    Do you have the new tanks, that are mounted behind the rear former ?
    Good Luck
    Ted
  6. #6
    Alex48's Avatar
    Join Date
    Aug 2006
    , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I did a small build thread which detailed some of the modifications I made. I used a mixture of the new tanks and old. Ali didn't have a problem with this setup using a 160. We were going to put a 200 in it but he changed his mind half way through the build which was probably a wise choice.
    I'll try and find the thread for you
  7. #7
    Alex48's Avatar
    Join Date
    Aug 2006
    , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    http://www.rcuniverse.com/forum/m_96...tm.htm#9659937
    It wasn't the best SM kit I've ever built but it was a pre production prototype (apparently) wish I was told that when I quoted for the build
    l
    Cheers, Alex
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
