If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 2 12 LastLast
Results 1 to 25 of 27
  1. #1
    Join Date
    Mar 2011
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Planing my first Jet (PST Reaction)
    Hi, I am planning to buy my first Jet. I have only experience from regular RC plane.
    I have been looking around and I found the PST Reaction to be a candidate, is this good choice as the first Jet? How is it to take off and land on grass, with this model?
    I will buy a new Radio for use with Jet, what radio is recommended and how many channels should I buy. I will buy a radio I still can use if I advance to a more advanced Jet.
    What Jet engine should I buy for this model? Is the PST Jets good?
    Is it other Jet engines to recommend, or I should look at? I want to buy an Jet engine I can bring over to a new airplane in the feature. When I have learned to fly, then I will probably go for an F-4 or F-16.
    What equipment do I need to complete this model, if I buy the ARF?
    What type of servos, amounts etc do I need for this jet? What type of electronic equipment do i need?
    I’m a rookie, so I hope I can get a lot of tips.
    Thanks in advance
  2. #2
    afterburner's Avatar
    Join Date
    Jun 2002
    New City, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Planing my first Jet (PST Reaction)
    How much experience do you have with your "regular" plane?
    Marty
    Marty
  3. #3
    Join Date
    Feb 2004
    Estero, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    dartvider,
    Good first choice jet! I have been flying mine for 2 years with ??? how many flights now. I lost count.
    I have a Jet Central Super Eagle (from Eric Clapp) which was considered on the high powered side when they first came out with the upgrade to the 3.8 liter tank. I used the PST UAT and like it. The JC turbine has been flawless-Period-zero complaints and their service is 2nd to none.
    I used the pro link struts which you can get from BTE or Dream works as a PST reaction package and love them. If you fly off grass I would recommend them highly and they also will smooth out the landing learning curve a little. I used BVM's breaks & wheels, retract valve and smooth stop. I had that just happened to have the wheels and breaks from there F-86 ducted fan kit that were spares and the right size.
    I use all JR radio gear a 2.4 12X, DS 8411 on all controls 2 ail, 2 flap, 1 elev, 1 rud, 1 nose wheel steering. Read all the threads on BTE's site for updates and building tips and suggestions. (3) Dura-lite batteries 2 flight 1 ECU lith-ion a power box dig. switch w/regulators.
    Good Luck and welcome to the world of addiction-Jets
  4. #4
    Join Date
    Oct 2008
    miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hhelllo i am a fellow miami man myself
    there are a few options
    best advice get into a jet with not bad flying characteristics
    also get an engine with capability of flying more advanced jets
    i believe pst will need atleast a 120 size or 28 lbs engine
    maybe might be a bit much or overwhelming
    my best suggestion for first jet would be
    1 boomerang elan rated best choice for first jet fast slow and acrobatic
    i have one with a 19 lb jet central rabbit flies great i ve had two at over 400 flights
    and they dead stick wonderfully
    2 cermark f 16 is also a good idea there is one on r c u in ft lauderdale my buddy is selling
    make an offer and we can fly this weekend
    3. with all the changes that jr is doing i would suggest to go with futaba 10c i have this as well and very economical
    call me with questions i will be at markam saturday am 3-26
    jet central for life have them all mammoth x 3
  5. #5
    Join Date
    Oct 2004
    Redding, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have hundreds of flights on my PST Reaction, 120 powered, alothough I have seen Bruce of BTE models fly his with 18 pounds and it flies very nicely as well. it is a very good flyign aircraft with no bad habits, built light with a 18 pound thrust it will land so slow it is unbelievable. never flown mine off of grass but think it would do fine.
    Kevin
  6. #6
    Edgar Perez's Avatar
    Join Date
    Dec 2001
    Gurabo, PUERTO RICO (USA)
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I had one with a super eagle and it was a blast. but too heavy (due to the extra fuel tank and nose weight required for CG balancing). For a novice, I would recommend a Rabbit. A friend of mine has that combination and it works really well.
    I you are set in 30Lbs+ , then go with a lighter Cheetah. However I manage to bend the aluminum spar in flight!, so not really recommended.
    Edgar Perez
    Puerto Rico
  7. #7
    frothingslosh's Avatar
    Join Date
    Oct 2002
    Willard, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm flying a Reaction 54 powered by a Wren 54 Mk3 (14# - 15# thrust). Sans fuel, the plane weighs 23 lbs.
    Most pilots would consider this severely underpowered, but it flys fine off asphalt - gets off in about 300 ft. I think it would take off OK on grass, given a couple hundred more feet. In the air it isn't what I would call slow. Estimate 110 - 120 mph at full throttle. In my opinion, it's a perfect trainer if you don't overpower it. It has no bad habits that I can find.
    It's extremely easy to takeoff, land, and fly. Landings are in the 30 mph + range with 80 degrees (full) flaps.
    PM me if you have any questins, or post them here.
    The ARF kit is very well done . . . everything fits perfectly (on mine at least), and there is more than enuf room to install all your equipment. The new (redesigned) brake system that PST makes for it is excellent. I strongly recommend you use a "progressive" brake valve because the brakes are very strong and will lock up at full pressure.
    Frothingslosh
  8. #8
    Join Date
    Mar 2011
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So what size engine should a starter use on this model.
    I will prefer to buy a Jet engine I can use for the feature, and maybe also on feature models like FB F-4 & F-16.
  9. #9
    rcguy!'s Avatar
    Join Date
    Jan 2002
    Chesterland , OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: dartvidar
    I will prefer to buy a Jet engine I can use for the feature, and maybe also on feature models like FB F-4 &*F-16.*
    Get the new JetCat P100. SUPER simple install. Get a JR 9 or 12 channel radio. Get the DreamworksRC landing gear and wheels package. Use good quality digital servos. Go have fun! Remember....... "I can't afford cheap" applies to turbine powered models AND helis.
    Dave
  10. #10
    Join Date
    Dec 2001
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    For size, I think 20-24 Lbs is best for starter in the Reaction. If you want an engine that can be used in many airframes, I think 30 Lbs is best. However you want to avoid a heavy engine. So look for newer generation, lightweight ones (hence my recommendation for the Cheetah)
    For brand, you can do a search here. a lot of threads discuss the pro and cons of each brand. I own 3 Jet Central and I think its the best combination of value, service and warranty.
    Fully agree on the dreamworks struts package. Get good servos for Elevator and flaps at least.
    Good luck
    Edgar Perez
    Puerto Rico
  11. #11
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Kent, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    On the radio front get something that will grow with you with as many channels as possible, the Futaba FG8 is upgradable to 12 proportional channels and two switched, with an S-Bus Rx its capable of 18 channels, if you can look at the Futaba 12FG more mixes built and very capable for not a lot of outlay, it also can use the S-Bus Rx.
    Mike
    My Gast is Flabered.
    No matter what anyone say's 100% is the maximum you can get.
    If you see a deleted post, my Avatar say's it all.
  12. #12
    zonker123's Avatar
    Join Date
    Apr 2003
    Grifton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My first jet was also the PST Reaction. Over 150 flights before doing something different. 95% of my flying was off grass. I originally had the pst gear ( the old non trailing link) I later went with The Dream works trailing gear and eliminated at lot of gear related issues. I flew mine with a Jet Central Falcon @ 22lbs of thrust for about 35 flights or so and had good performance. No problems off grass and the speed is in the 150 MPH range. I had the opportunity to trade up to a 30lb thrust Super Eagle and now I had more vertical performance and the speed picked up to the 175-180 MPH range. But I had to install extra fuel tanks to maintain a decent run time and I had to add some additional lead in the nose, (mine is the original short nose), to compensate for the heavier motor. plane handled the extra weight fine.
    For most of my flying I actually turned my Super Eagle down to 26-27 lbs of thrust with little degradation in overall performance but picked up a bit more run time on the same fuel load.
    If I were to build a new Reaction I would power it with the Jet Central Cheetah. Slightly more more power than my Super Eagle and much lighter and better fuel economy.
    Turn the motor down to around 25lbs of thrust for your first flights and you will have great performance that will put a smile on your face.
    If you are getting the plane from Bruce Thorpe @ BTE, he will provide excellent service and advice if you need it.
    If you go with a Jet Central turbine, Eric Clapp @ Jet Central USA will do the same.
    Since this is your first turbine you will have questions and those two guys will make it a pleasant experience
    Here is a vid of mine with the turned down Super Eagle. Go to my you tube channel (pamlico123) there is also some video with the smaller Falcon also.
    Good luck.
    Mike S.
    [youtube]http://www.youtube.com/watch?v=20e5iLjgb_8[/youtube]
    KINSTON NC AEROMODELLERS
    A & E JETS
    Team 2DogR/C
  13. #13
    FILE IFR 's Avatar
    Join Date
    May 2006
    Clinton, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Great first jet.
    I going on my 3rd year flying mine. P-80SE powered with smoke and Pro-Link gear, it tips the scale at 31 LBS, 10OZ (full fuel and smoke oil).
    ... It's fun jet and super easy to fly/land.
    Mike * Intercepting The Localizer* AMA# 365566
    Bud Nosen C-310 Club #32 * J.P.O. Member 2302
  14. #14
    Join Date
    Mar 2011
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What type servos to use on this model, how strong and fast, and how many for different function?
    If I use Hitec servos, which servos to use?
  15. #15
    FILE IFR 's Avatar
    Join Date
    May 2006
    Clinton, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: dartvidar
    BTE has a list of servo sizes suggested for the surfaces.. it's a list of Futabas, Jr's and Hitechs, I think he has the list on his website.
    **EDIT** Here's the page. Click the link at the bottom of the page. http://www.btemodels.com/rarf-equipment.html
  16. #16
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: zonker123
    Over 150 flights before doing something different. 95% of my flying was off grass. I originally had the pst gear ( the old non trailing link) I later went with The Dream works trailing gear and eliminated at lot of gear related issues. No problems off grass and the speed is in the 150 MPH range. If you go with a Jet Central turbine, Eric Clapp @ Jet Central USA will do the same.
    Good luck.
    Mike S.
    Now that made me laugh if you consider that flying off grass, that is flatter than most Asphalt in Europe.
    Mike
  17. #17
    zonker123's Avatar
    Join Date
    Apr 2003
    Grifton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: dartvidar
    I used Hitecs on mine also. You will have to cross reference to the 79 series as mine were installed a couple years back. One 5985 on each aileron, rudder, and elevator. 5645 on the flaps with with one reversed using a Hitec servo programmer and a "y" harness. A 5645 on the nose gear steering and a couple of JR standard sport servos on the retract and brake valves.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    A & E JETS
    Team 2DogR/C
  18. #18
    zonker123's Avatar
    Join Date
    Apr 2003
    Grifton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BaldEagel
    Mike
    Oh mike mike mike,
    We reallllllly need to meet one day!
    You do have a point as the fellow that takes care of my home field has it pretty well manicured. In the states we try not to fly of the same field where we grow our crops and raise our cattle.
    I have flown it off much worse but just don't have a vid to show for it.
    Wait a minute, here is one with some taller grass for your viewing pleasure. In fact while taxing you can actually see the landing gear springs stretch just a little bit.
    [youtube]http://www.youtube.com/watch?v=VnhWHVLa4HA[/youtube]
    Always a pleasure.
    Take care my friend.
    mike s.
    A & E JETS
    Team 2DogR/C
  19. #19
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yep just watched the video of you flying off another snooker table, I just hope you guys know how lucky you are.
    Mike
  20. #20
    rcguy!'s Avatar
    Join Date
    Jan 2002
    Chesterland , OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BaldEagel
    Mike
    If you think our flying fields are nice you should try OUR golf courses to play 18 holes on!
    Dave
  21. #21
    Join Date
    Mar 2011
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just got 6 DVD's with JET Porn from SKS, this will be a nice sunday.
  22. #22
    zonker123's Avatar
    Join Date
    Apr 2003
    Grifton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rcguy!
    ORIGINAL: BaldEagel
    Mike
    Dave
    Mike,
    In the UK, you only have sunshine 2 weeks out of the year so you don't have time to smooth a field, you gotta fly while the sun is out.
    Doesn't the snow fill in the ruts?
    A & E JETS
    Team 2DogR/C
  23. #23
    zonker123's Avatar
    Join Date
    Apr 2003
    Grifton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: dartvidar
    I just got 6 DVD's with JET Porn from SKS, this will be a nice sunday.[img][/img]
    DVD's are good but get busy spending money on the real thing.
    Trust me, nothing feeds the addiction like hearing your own turbine spin up!!
    Take care
    A & E JETS
    Team 2DogR/C
  24. #24
    Join Date
    Mar 2011
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rcguy!
    ORIGINAL: dartvidar
    I will prefer to buy a Jet engine I can use for the feature, and maybe also on feature models like FB F-4 &F-16.
    Dave
    Do you have a link to theDreamworksRC landing gear and wheels package you refer to?
    Whats the price and thrust on the JetCatP100, I like the JetCat turbins?
  25. #25
    Join Date
    Mar 2011
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: FILE IFR
    Great first jet.
    How does your model fly with the P-80, do it have enough power to fly from grass?
    Is this a good engine for the first jet?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
