If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 33 of 47 FirstFirst ... 23313233343543 ... LastLast
Results 801 to 825 of 1173
  1. #801
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: The New F86D Dog Sabre
    I get 4 minutes flight, then land. I have about 1 inch of fuel left in each tank. Maybe could push it to 5 but no room for go arounds.
    You guys must fly like my grandma to get that much flight time.
    Kingtech K180g, K140g, K100g
    Jet Legend viper
    Skymaster Mig-29
    Yellow Aircraft Single (under construction)
  2. #802
    Join Date
    Apr 2006
    Notteroy, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lol... or you have a turbine with "grandma"-technology
    My VT80 burns around 250ml per minute at full throttle. Each tank is 1000ml total of 2000ml/2L.
    So...if I fly WOT the entire flight, I get 8 minutes
    At 1/2 throttle ?
    Kim
  3. #803
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Kim, thats exactly what the K80 is supposed to burn per min, 250 ml per min.
    I must be running 3/4 throttle the whole flight, with some WOT in there. So 4 mins then land leaves me with a min or so to spare.
    My next flight will be 4 min fly, then land. I will shut down asap on landing. I'll send a pic of what is left in the tanks. I do use a taxi tank.
    I can tell you 6 minutes would require throttle management in the grandma style!
    PS due to the geometry of the tanks I cannot get all the fuel out the bottom of them. So my tanks are .8L each or 1600ml total. So 6.4 mins to empty for me.
    So I fell 4 mins then land leaves me with some room should I need to make some go arounds, which to date after 9 flights I have not needed because I fly off a real runway.\
    PS again" 1/2 throttle = grandma on the dog.
    Jet Legend viper
    Skymaster Mig-29
  4. #804
    Join Date
    Apr 2006
    Notteroy, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hmm.. I check the specs on the VT80 again...220grams per minute. That is around 190ml/min.
    The K80 states 250grams/min or around 220ml/min. With these numbers I am a bit puzzled why you do not get more flight time than you do.
    Maybe I am wrong believing the tanks are 1000ml each?
  5. #805
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I thought 1L each sounded a bit big. To me it looks liek they are maybe .75L each, and if you account for the geometry you get about .55L each or so, giving us 1.10L total to drink.
    So 4.4 mins at wot looks about right to me. I can tell you after 4 mins of mixed flying its getting low, maybe 1" or so of fuel left in the bottom, Very easy for clunks to start sucking air!
    I also have my tanks in parallel, clunk to clunk, feeds the UAT, Should I try serial, vent to clunk to uat?
    Jet Legend viper
    Skymaster Mig-29
  6. #806
    Join Date
    Mar 2009
    Dudelange, LUXEMBOURG
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello,
    The empty weight of my Sabre is 7870g or 17 lbs and 5 oz with the Wren Supersport an a cockpit.
    My tanks are in parallel with T-fitting going to a hopper tank. Needed to add some weight to the clunks to get them on the bottom in normal and inverted flight. Having the 2 tanks in line will raise the current draw of the fuel pump.
    The heavier planes need more power to fly. So they will use more fuel. I feel that my model has a good speed at 1/2 power (lets say stick in the middle).
    I dont like to fly all the time at full power. On Meetings I to one or two fast fly by and then show the slow speed characteristic of the plane with a climb out at the end.
    until next time
    Flilek
  7. #807
    Join Date
    Apr 2006
    Notteroy, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hmmm. Essyou, I always hook my tanks up in series. I am not sure what you mean by the geometri of the tanks, but my fuel system empties the first tank almost completely before starting to drain the from second tank. With "grandma" style flying, I could certainly achieve 5-6 min flight time, which has had me thinking of using the other tank for smoke oil
    With smoke on and grandma flying style, this lady would definately become a GILF (sorry guys.... I just had to )
  8. #808
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OH BTW. I have had issues with the Festo fittings on my K80. The other day I noticed there was some fuel running on the underside of the jet. I pulled the turbine and cut the tubes, and pushed them back in. The next time I want to start, the K80 nwould not get going. It was literally pouring fuel out the bottom.
    At the field, I pulled it again and pushed the tubing in again, no difference than last time, but this time it did not leak. I swear at 1/2 throttle it felt more powerful. That day it was getting to dark due to the delay but it really felt faster and my wife thought so too.
    So maybe I had a small leak that was causing me to push throttle more? I need to go post in the K80 forum.
    Jet Legend viper
    Skymaster Mig-29
  9. #809
    Join Date
    Apr 2006
    Notteroy, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, fuel leak issues are serious matters! Good luck sorting out the problem!
  10. #810
    Join Date
    Mar 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello,
    Ther are very nice tools to cut Festo tubes. With this tool, you never crush the tube and the end is square. Never get leaking. But pay attention. Chines copy of Festo tubes are slighty bigger and they distroy the Festo fittings when you want to get the tube out again.
    Flilek
  11. #811
    Mike06659's Avatar
    Join Date
    Jun 2006
    Mercersburg, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If anyone is interest I have gear for sale.
    Mike
    http://www.rcuniverse.com/market/item.cfm?itemID=854377
  12. #812
    Join Date
    Mar 2005
    Pembroke Pines, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just flew mine the other day, flew great. 12 oz of epoxyed bb's in the nose and a Rabbt 100 in the rear end. Had to tune it down to 16 lbs. Here are some pics.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1778013   Click image for larger version.
ID:	1778014   Click image for larger version.
  13. #813
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    why on earth would you tune it down!!!!
    Jet Legend viper
    Skymaster Mig-29
  14. #814
    Join Date
    May 2012
    , MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This has me puzzled, why do the engine mount rails angle result in the thrust center-line so low at the aft fuse?
    checking with plywood plate and cf rod
    if I align the pipe to the turbine as it is , there will be a 2" gap above the pipe at the tail and will have to scallop 10" or 12" along the bottom of the fuse..
ID:	1778046   Click image for larger version.
ID:	1778047   Click image for larger version.
  15. #815
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    not sure, but it works. Mess with the thrust angle and you will need trim.
    Jet Legend viper
    Skymaster Mig-29
  16. #816
    Join Date
    Oct 2003
    Denver, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am selling my NIB Dog Sabre if anybody is interested. It does come with the retracts. $575 shipped via Greyhound. Pm or email me if interested. Thanks Jon
  17. #817
    InboundLZ's Avatar
    Join Date
    Oct 2004
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have their MB339 and my thrust angle was so bad I had to rip eveything out and start over. As matter of fact, the mounting rails were not parallel to eachother and the poorly glued in place. I was able to remove them in about 4 seconds. I have rebuilt this area and I would bet money you would have to destroy the fuse to egt them out now. I used a laser to align everything and get the thrust angle correct.
    All I know is I will never buy a MB kit again, too much work to get them up to my standards....
    Good luck with yours....
    Dave Bottita
    Jet Cat Factory Pilot
    JR America Team Member
    Smart-Fly
  18. #818
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I love the dog but man it had me cussin putting it together!
    9 flights on it seems to be holding up, but it does not seem to be very popular for some reason. I wonder why.
    Jet Legend viper
    Skymaster Mig-29
  19. #819
    Join Date
    Apr 2006
    Notteroy, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jetbro
    Β*This has me puzzled, why do the engine mount rails angle result in the thrust center-line so low at the aft fuse?
    if I align the pipe to the turbine as it is , there will be a 2'' gap above the pipe at the tail and will have to scallop 10'' or 12'' along the bottom of the fuse..
    Sorry to say, but you need to have a sharp eye when "building" the Dog. As you obviously have that knowledge, no need to worry My Dog required lots of modification to be finished like I wanted. That
    ment ripping some formers out and glue them back strait, or rebuilding turbine mounts and nose wheel mounts/formers...
    But when you have delt with all the issues, this model is a blast to fly and operate, just don't take short cuts during assembly
    I personally love my F86d
    Kim
  20. #820
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Kim how does the speed of your dog compare to your other jets? I've heard (never seen) the tornado is faster. I did see several falcon 120s flyh and they were slower than my dog.
    Jet Legend viper
    Skymaster Mig-29
  21. #821
    Join Date
    Apr 2006
    Notteroy, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: essyou35
    My dog has the drop tanks installed, which isnΒ΄t helping increasing the topspeed To be honest I would have to admit that the Dog is not very fast, but I will say it is fast enough to get the smile on my face! Lots of people ask "how fast is it?" My answer is mostly "too fast". Personally I am more interested in how well models fly, than how fast they go.
    But to answer you Q based on the models I now own:
    Elan/P80se is marginally faster than/same as the F86d
    C-arf Mig-15/P80se is -//-
    Habu32/P20sx is a tad faster
    C-arf Eurosport/Behotec 180 Gold, never tried topspeed and never will
    A had a Boomerang Sprint (sold it)/P80se, and I would say that model is comparable to my Dog regarding topspeed.
  22. #822
    Join Date
    May 2012
    , MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guess what? If you go by the center of the circle cutout in the former between the turbine and the tanks...the datum is on the topside of the mounts(opposite teh hatch)
    everything lines up nice this way without changing vertical engine thrust angle
    no wonder so many pipes were low on other pics...
ID:	1778659   Click image for larger version.
ID:	1778660   Click image for larger version.
ID:	1778661   Click image for larger version.
  23. #823
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks like you are doing some great work there. I looked into doing what you did but being my first turbine I opted to use the status quo. I over analyzed mine and in the end it all works out of the box.
    These dogs have small reynolds numbers so it is not going to matter if it is exactly on the datum or not, a few mm wont count. The only thing that will is the thrust angle and I got mine right on thank god. Get that wrong, which you can do with the dog,, and you'll have a trim issue that is speed dependent.
    Make sure you plan carefully how you will get the wings off and on so you can ensure that will not become a huge chore. I use just steel flange bolts and a socket wrench.
    Looking forward to another dog flyer!
    Jet Legend viper
    Skymaster Mig-29
  24. #824
    Join Date
    May 2012
    , MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm just happy I can mount the turbine and pipe without rebuilding the woodwork or butchering the tail of the dog...
    I plan on using a single shc screw for each wing at this time ... and quick-connects on the air lines , molex connector for the two servos..
    should make for fast and error free connections..
    ps.. i just lay the turbine on the mount, i will have the glow plug between 10 and2 on final install.
  25. #825
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    shc shc screw?
    Jet Legend viper
    Skymaster Mig-29
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
