help on power box champion rrs
Hi all looking for some confirmation from those with more experience using PB's.
Have a model with the champion rrs fitted twin receivers in it, set up with 14ch 6014s and 14mz.
I set it up with primary controls in separate power box channels with the exception of flaps which are on one matched channel, then direct from the receiver gear, brake valve, steering, plus a micro switch via a servo for lights.
Problem I have is there was an occasional glitching on the ailerons when operating rudder or brake valve. both of these were set up with mixes i.e. rudder to steering wheel brake to down elevator etc.
After a number of hrs I think I have found a problem where any channel not going through the PB that has a mix to a channel that is going through the pb appears to trigger a minor glitch ( even if mix is disabled and I then use just the joystick function to control the channel. I have now moved channel assignment around so more is on the PB using the matching but then I loose some of the mixing functions.
Anybody have seen this, perhaps I'm doing something fundamentally wrong appreciate any advice.
RE: help on power box champion rrs
Keith,
Alex posted this recently. Any similarity? May be something to do with mixing across PB and RX? Although I don't think I've ever had this on dozens of PowerBoxes.
All the radio and electronics are now set up and working nicely. Had an interesting problem with the powerbox in that freshly charged 5000mah Lipo's were only reading 5.5 - 6volts on the LCD display and the display itself was heavily pixelated and difficult to read. My problem was this.........the Airpower valve takes power from both the brake and gear extensions. I had the gear plugged into the powerbox for redundancy but had the brake plugged directly into one of the receivers. The voltage to the receivers is always regulated but the voltage to the servos is selectable because of this disparity in voltages to the multi valve I had some strange issues showing on the Powerbox to cure this I simply removed the +ve connection on the brake line to the reciever and now all is good. This isn't a problem I've come across before so thought I'd share it.
Thanks Mark, very similar, just strange, when connected direct to a receiver by-passing the PB altogether it works 100% no issues.
This may or may not be related to your problem, but the powerbox feeds a current limited amount of voltage to the receiver, I am not certain, but I think it is around 1 ampere. If servos are connected directly to the receiver and draw more than that, it can brown out the receiver. The fix has traditionally been to use the signal wire only from the receiver to the servo, and scavenge the voltage from a free output on the power box.
All makes sense, i think the issue is triggered if there is a mix \ interaction in the radio between a channel from the pb and rec direct where as you say the voltage could vary. The gear channel does not cause the problem whereas the steering \ rudder does. Thanks for the advice I guess using a signal wire and power from the pb is an option or get more from the pb direct. guess just my luck to find a problem bet there are 100's running with no issues.
Keith,
I'm running a mix from Channel 4 (Rudder) on my Royal to channel 10 in the RX (nose steering) and Channel 2/5 on the Royal (Elevator) to channel 11 (Brake valve) with no issues?? Not that you wanted to hear that but I don't think Powerbox as a company would allow this "mixes across PB/RX" problem to exist.......would they?!
M
M
Hi
I am also running a Power Box RRS with this set-up mwith no issues. What serv o are you using in the steering wheel. I use a low current cunsuption servo (Futaba 3050) - more than enough for the wheel if you take mechanical advantage the right way
Regards
Nuno
Regards
Nuno
The steering servo is a multiplex profi I believe and the others mini servos to operate brake and retract valves, nothing that would \ should draw high current.
These are the fs versions I assume they are by standard in normal ?.
I just tried different servos connected to the channel for steering, futaba 9451,and JR8411, hitec 649, same jitter but a mini futaba no issue. The problem also goes if I put the steering on a matched channel from the PB i.e. rudder, and leave the gear and lighting direct on receiver. Concern is it seems to work for other people, but then a few have experienced similar jitters and used only signal wire in rec. Madness........... with 1 receiver and no power box it is fine
Have you tried to read this http://www.rcuniverse.com/forum/m_8038701/tm.htm
I also have this issue with PB RRS http://www.rcuniverse.com/forum/m_10...m.htm#10501492
Emmerich from PB says its normal[&:]
Regards
Nuno
Regards
Nuno
ORIGINAL: kjb
Sort of exactly the sort of thing you would hope such an expensive gizmo would NOT do.
Your best bet is as suggested before is to "borrow" the power from the PB direct and only use the orange wire to the RX.... The danger here is that if you dont, your RX is not going to be happy with such poor voltage regulation
All many thanks for the feedback, shame though seems like it is not my set up as such. I had hoped I made a small error that explained this. Will get it working 100% with the workarounds suggested.
