Building my first Jet. Viper 2m questions.
Hi guys,
As title says this is my first jet and have some questions on the building.
The jet is a Viper 2m and I am done with the servo installation of stabs, ail and flaps but have some questions and hope you can help me.
1. What is the best way to mount a regular size servo on the rudder? The space inside is so tight, what have you done to fit it in? Pics will be great!!
2. I am a little worry about toasting the tail servo extensions(stabs & rudder), what have you used or how you route them to prevent burning them? Pics will be great!!
3. Is it mandatory to use the springs or elastic band to tension the steering cable?
4. How to program the 14mz to center the steering wheel before retracting it? How to stop the steering servo after retracting it?
Thanks a lot for your help and patience.
Regards,
Vic
Regards,
Vic
My Feedback: (30)
RE: Building my first Jet. Viper 2m questions.
This link should help you on most of your questions...Couldnt tell you on the 14mz though
http://www.rcuniverse.com/forum/m_98...tm.htm#9823666
My Feedback: (73)
as to the elastic bands, they are not mandatory .. all they to is help pull the steering cables out of the way as the nose gear retracts so it does not bind up on its way back down later when you are dropping the gear ..
the thread link posted should give you all the other info you may need on this specific airframe ..
all the best !
~V~
My Feedback: (44)
ORIGINAL: furycham
Hi guys,
Regards,
Vic
Hi guys,
Regards,
Vic
http://www.rcuniverse.com/forum/m_96...13/key_/tm.htm
Look at post #308 & #312 if you want an alternative method for doing you nose steering...I hate cables!
Post #322 for the rudder.... p.s. a HS 5225 works great for the rudder and Elevators
Post #325 & #331 for the servo extension routing
Post #357 for battery mounting
