Jet crash at the Nall ?
My Feedback: (10)
RE: Jet crash at the Nall ?
Guys I hate to see this crash, but IMHO 2.4 GHz has been WAY oversold. everyone figures a hundred guys can turn on at once and everything will be fine.......everyone wants a concrete answer,you are going to have a very hard time finding it, the science of spread spectrum has become almost political now.
Sorry for your loss David. Was this the one you just finished? At least no one got hurt. As big as Joe nall is, I dread the day something really bad happens. I almost hit Don Lowe one year with a fibreglass 500# bomb off of my P-47 and he was in a tent near the impound area.
Anthony
Anthony
http://www.rcmodelreviews.com/
Take a look at the videos here. Very good info on the 2.4 band and what happens when its overloaded. very easy to understand.
My Feedback: (24)
ORIGINAL: Countryboy
Friggin great! Just received my Ripmax module to convert my 10X to the Futaba Fasst while getting rid of the Spektrum conversion. I swear, I believe this is the reason why Maj. Woody jumped ship. I believe he decided the risk was just not worth it after having several back to back crashes due to radio failure. I still feel the Fasst is the better option though.
My guess is at the Nall, there are just so many transmitters on that the noise floor goes up and all systems start having problems. If enough TXs are on, the band just gets saturated and everybody is going to have problems - its just pure physics...
I thought that they were thinking about limiting the number of TXs on in the pits this year at the Nall?
Bob
Bob
#32
My Feedback: (303)
SORRY DAVE!!!! Can I send you a HITEC Radio?? I have had them all and have HAD NO ISSUES with this radio..... I lost 2 jets in one day due to lock outs.....used JR at the time.....Sorry but I had to switch..... I know I will get hate mail for this but it is what it is! Did you have it insured??
#34
My Feedback: (36)
"Basically I was 2000' away (guess) looking up the tailpipe, through the motor, full fuel tanks and to top it off the mirror plexiglass cockpit floor over the RX's. "
I guess this is why Spektrum uses multiple antenna's. More to love....
Sorry for your loss David,
Sucks anytime anyone crashes.
Tim
Who crashed the T-45?? What radio were they using??
Tim
#36
My Feedback: (23)
ORIGINAL: rolsen12
I lost 4 jet with Futaba before I found that the transmitter would turn itself off at variou times.
.....there is a power saving mode where the transmitter turn it self off.and you can set it in deferent times or inhibit it.have you check that out?
#39
ORIGINAL: DelGatoGrande
ORIGINAL: rolsen12
#40
Banned
1 Post
ORIGINAL: FILE IFR
That's true, if you don't move a stick, switch or button in 30 minutes.
ORIGINAL: rolsen12
Sounds like a worrying piece of software that that if it went rong it would spoil your day.......... Also not sure a powersave is that necessary
#41
MO
ORIGINAL: gjhinshaw
If I change my name to DAVE, would you send me a Hitec Radio?...... tired of my Spektrum stuff
#42
My Feedback: (25)
ORIGINAL: Rider-60
Does anyone know if the latest Fasst Rx are still heat sensitive?
Early ones could go wild if left on the sun
#44
My Feedback: (40)
ORIGINAL: HORNET FLYER
interesting......im still old school using nicads( i Know)......but I do not use power boxes, regulators and such extras( i have a yellow twin, classic flash , kingcat, firebird,electra and kangaroo.....all without fancy extras)
Could power boxes and such be causing issues?
I fly jr dsm2
Paul
I fly jr dsm2
Paul
Craig
#46
My Feedback: (84)
For what it's worth when Iswitched from 72 to 2.4,Iconducted a series of tests with Futaba and Spektrum. Inever consirered JRat that time (years ago) since they had "issues then")This was done primarily in electric planes by placing esc's on top of or underneath the rx's! One plane was loaded with CF so Iplaced the 2 FASST antennas outside the plane's fuse in 2 short pieces of yellow sullivan pushrod pieces! Ithen flew these planes out to riduculous distances using binocularsoccasionally to maintain control. Ihad "0"issues with FAAST and some minor ones with Spektrum (these antennas were inside the plane but had multiple rx's )
Based on this Iuse FASST and Istill place the antennas outside the plane and have had "0" issues, see atached pics. These are from a C-Arf Ultra Lightning, Skymaster Viper MKII, Pirotti Tuono and a Boomerang TUONO. Irealize this looks a little wierd BUT I'd rather fly safe than worry about a little aesthetics! ROBBE now makes accessory antennas for FASST that are longer so it would be easier to place them in larger planes, each antenna is 400 mm long .. part # F0959400. Ihave not had to use these yet but they are available.
#47
Having spent my entire military career doing tactical electronic warfare (EA6B's), and doing developmental test on systems, I can say this is something the manufacturers should have anticipated. Any signal can be overcome. Spreading a signal across a bigger section of the spectrum helps, but if you flood enough of those small "slices", enough data is lost that the system ceases to function - especially a "one way" system like our transmitter/receiver systems. I applied electromagnetic energy (jamming) to attack key parts of air defense systems, but the the physics are the same in this environment. Any dense electromagnetic environment, like a meet with a lot of transmitters, can easily produce effects similar to jamming as seen by the airborne receiver(s).
I'm just sorry to see that folks are losing airplanes as a result. It was predictable though. Once you start adding processing in the transmitter/receiver interface, there's a number of issues that come to play, some are weaknesses, and I suspect there are a couple more "gotchas" out there waiting to happen. For those in the industry that read this, and are interested in talking, just PM me.
It's for this reason that I'm still using 72Mhz. Not a panacea to be sure, but at least the issues are known.
#48
My Feedback: (13)
I think we all need telemetry that will send us an alarm when the signal quality drops, yet still with control. No foolproof against a total band issue, but better than the blind systems out there today. Couple that with frequency hopping and we have the best we can get at this time.
Fortunately Weatronics have that for several years now
#49
NC
As someone has been to just about all the Joe Nall events, maybe its just got toooooo big. Love going to Joe Nall but it just hasn't been the same to me the last couple years. I still enjoyed it.
