Tam's Skunkworks - Gen 3 F-16
My Feedback: (29)
TX
Tam,
Iknow you have been busy like little elf making new toys for all good boys and girls. Now it is time you let the cat out of the bag! You give us pics and info right now!!!!! If gen. 3 is even close to as good as 2, (let alone better as Ihear) you're about to be a busy little shipper!Wedemand pics and specifics now!!!!!!!!!!!!!!!!!!!!
RE: Tam's Skunkworks - Gen 3 F-16
The 3rd generation 1/8 F-16 is getting closer.
Here is few detail.
Scale gear, TJ-ProLite wheels/brakes and ailerons.
The material also chance to lighten up the kit.
The new kit is a pound lighter than 2nd generation.
Other than that.
Everything still remain the same.
Here is the 2nd generation with the mod for scale gear.
Here is few detail.
Other than that.
My Feedback: (57)
On Gen 2 adding the scale nose gear I would say is not worth it. Tam's works great. The JL nose gear has some slop on steering, which goes away once there is a load on it. IMO, Tam's nose gear is more robust.
If at all, I would focus on retrofitting the scale main gear, but only because it looks awesome.
Hey Tejas freaks, how about a bundle discount? I'm down for one.
ORIGINAL: hooker53
Tam, what size turbine is the Gen 3 good for???? Whats the smallest amount of thrust needed? Looks good.
