Comp ARF Eurosport control bearings
My Feedback: (95)
Hey guys, help me out. I picked up the dreamworks canard control bearings but not sure how to install them. Do I bore into the inside wood support and fit them into it? If so, how have you gone about this?
Joe
Joe
My Feedback: (25)
RE: Comp ARF Eurosport control bearings
When you say wood support, are you talkng about the "P" brackets ? Here you can see the tops of my homemade 1/4" ply "P" brackets which have the bearings installed. The brackets with bearings are aligned at the end of the canard tube and Hysol glued to the vertical support.
My Feedback: (95)
Thanks for the response. Do you have to make new P brackets or can you use the existing one. I was hoping not to tear out the structure.
My Feedback: (25)
ORIGINAL: Joe Westrich
My Feedback: (95)
I am at work, so no pictures, but you are right. I am talking about the existing installed P-brackets. They are not set up to take a bearing. I guess I will have to try to open them up or take them out and make new ones.
Hi,
What are the benefits of this modification and is it necessary ?
Does the stock carbon shaft inside metal tube cause the canard angle resolution to be reduced and notchy ?
Thanks.
Thanks.
Julian
The carbon rods are not always round and the tube the same, I check the carbon rod with a vernier and sand the over size high spots off. I then check the rod fit in the tube-having de-burred each end of the hole. If there is any play I coat the carbon rod with thin CA and then sand with fine wet n dry. I get a nice smooth action doing this. Enjoy your Evo
Dave
Dave
My Feedback: (25)
