skymaster f-18c center of gravity
My Feedback: (171)
CA
I know it has been discussed before but i can't find the answers in the search for a current f-18c .I have the factory specs but would like to move the cg back to avoid putting more lead in the nose,,any other tips would be helpfull to like aileron elevator mix ,,flap setting for take off with a aft cg setting,,thanks to all for any help
scott
scott
RE: skymaster f-18c center of gravity
Hi dsr71,
I have the Jetlegend F18C 1/8th . We might be on the same scale, but anyway I used the recommended 6inches from leading edge. I have 2 x A123 6.6v , plus 7.2 Nimh ECU pack and another 7.2 NiCd( using as a ballast ), all placed at the nose, powered and flew well with a P120SE. Total takeoff weight with all tanks full 12.5 kg. Without the ballast, this plane is just too tail heavy.
Juaffy
Juaffy
Hi dsr71
We share the same interest so here is what you need
http://www.rcuniverse.com/forum/m_53...tm.htm#5351184
In the above you can see the answer clearly for what you need
http://www.rcuniverse.com/forum/m_24...tm.htm#2451312
another good threed
Best regards
Avi
another good threed
Best regards
Avi
My Feedback: (171)
CA
Thanks for the links Bandit AV i have read both of them several time ,,mine has round cabon fiber spares not the flat metal,wonder if they are in the same place as the earlier versions ?
I read 25 mm behind spare ,or 1-2 cm behind spare or 48 inches from nose
25mm behind the center of the front round spare is just what skymaster has intructed except they take the measurement from the wing leading edge which comes out to 144mm guess i will have to start there if i get no more input .
