Shulman Aviation Turbinator ARF
#76
RE: Shulman Aviation Turbinator ARF
thanks a lot for the info! you're great! but will be possible to do some pics of how you do it? how do you conect all the air tubes and servos conections?
thanks
thanks
#81
Chris,
What size or type / brand retracts is best for the turbinator? I wrote and email to Shulman Aviation but never got a reponse back from them.
Best Regards
Ken
Best Regards
Ken
#84
My Feedback: (38)
Well, I recieved my Turbinator ARF a few days ago. No progress yet, just getting a few things in line for the assembly.
Big thanks to Shulman Aviation and Jets Over Kentucky! I was lucky enough to pick up a 50% off certificate at the pilots dinner.
After the demise of my Shokjet, I needed a new anytime, anywhere jet. I will push it through ahead of the BIG 18 and get it flying hopefully before the New Years Day Fly In and Turkey Fry.
Will be pushed by an ancient amt 180 and some of the stuff out of my Shokjet.
#88
Hi,
I got the retract/brakes/wheels set from David directy. Brakes/wheels are from Intairco.
http://tief-flieger.de.tl/Shulman-Av...Turbinator.htm
Best regards
Philip
Best regards
Philip
#90
My Feedback: (38)
She flys!!! test flights went great. definitely need a different brake valve. up6 on it's way. It a perfect plane for club fields and everyday flying.
#93
ON, CANADA
Just received my turbinator!
how is everyone fastening the canopy to the hatch? I was thinking of trimming the canopy, then gluing and or screwing it to the hatch?
any thoughts or help would be appreciated!!
regards,
regards,
#94
My Feedback: (24)
Screwed mine on with 5/16" button heads since I was pressed for time(backed up with 1/32 ply), seems to work fine. I would have glued it with Formula 560 if I was not in a rush....
#97
ON, CANADA
Thanks for the help guys. I appreciate it.
I've got another question,....pertaining to the decals....
Whats the clear sheet of film for? I'm assuming its a release film.?, what the best way to apply the decals? With or without the release film.
thanks again!
thanks again!
#100
My Feedback: (24)
This thread covers the ARF, your scratch building one from plans. Not sure if it all translates over, I imagine the plans would have accurate detail for CG and throws for this version?
ARF Control Throws
Aileron
High Rate
Up: 1 inch 25% Expo
Down: 1 inch 25% Expo
Low Rate
Up: 3/4 inch 10% Expo
Down: 3/4 inch 10% Expo
Elevator
High Rate
Up: 1 inch 15% Expo
Down: 1 inch 15% Expo
Low Rate
Up: 3/4 inch 8% Expo
Down: 3/4 inch 8% Expo
Rudder
High Rate
Right: 1 1/2 inch 12% Expo
Left: 1 1/2 inch 12% Expo
Low Rate
Right: 1 inch 5% Expo
Left: 1 inch 5% Expo
Flap
Mid/Take-Off 1 inch
Flap Full/Landing 2 ½ inches
Note: Measurements are taken at the inner or widest point on the control surface. These are general guidelines measured from our own flight tests. You can experiment with higher rates to
match your preferred style of flying.
ARF Control Throws
Aileron
High Rate
Up: 1 inch 25% Expo
Low Rate
Elevator
High Rate
Up: 1 inch 15% Expo
Low Rate
Rudder
High Rate
Low Rate
Flap
Mid/Take-Off 1 inch
