If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 32 of 33 FirstFirst ... 2230313233 LastLast
Results 776 to 800 of 806
  1. #776
    dubd's Avatar
    Join Date
    Aug 2007
    Bay Area, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fly Eagle 1/6 scale F-16 Build Thread
    James, seems to me that a plastic tube (ABS) is more prone to wear, especially on planes that are flown hard. Do you feel that the ABS is superior over bearings?
  2. #777
    Join Date
    May 2007
    Seoul, KOREA, REPUBLIC OF (KOR)
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Fender,
    You said all what I want to say. I really really agree that elevator should be bearing.
    Whatever material used for this elevator support, at the moment this elevator is very stiff without any modify.
    I'm wondering what Mr,Liu did do his jet, and configuration.
    James,
    That's very good approach. The buyer definetly want bearing on the elevator even it is option.
    By the way James, can I also buy elevator support parts with bearing to modify it like old version style same as Fenders's one?
    I need whole related parts.
    Jake,
  3. #778
    Join Date
    May 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks, I'll do.
    But I'm still thinking what is the best solution to clear this issue.
    I'm expecting FEJ supporting.
    Jake,
  4. #779
    FenderBean's Avatar
    Join Date
    Feb 2006
    Clarksville , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey suhakkogi, give it a try, It can always be changed later and that way you can make your own determination on the new design. I am a product of tradition and just like when 2.4ghz started people were very reluctant to switch over. It could be a solid design for this application, and if it does work its kinda a good thing since you lose some weight from the wood/bearings of traditional setups.
    Keith who?
    Xtreme ARF Rep
    Contest Director AMA # 8394
    FAA Registration # FA3W99AXCX
    https://www.youtube.com/channel/UCE_...BAxA8bHVCw3VQQ
    https://www.facebook.com/FenderbeanRCBuilds
  5. #780
    Join Date
    May 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for your advice.
    After long thinking I decided to go original application.
    But there is still remained thing to be solved. I just try it.
    Jake,
  6. #781
    Join Date
    Jan 2010
    glasgow, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: EagleJC
    Hi
    here are couple photos to show the new set up on elevators.
    James
    Hi james, The basic idea on the elevators is good, but the geometery could be better. For me the pick-up point on the servo would have to be much further back (or forward) from the pivot point on the elevator ideally at least halfway between pivot point and trailing or leading edge to give a much greater mechanical advantage to the servo.
    The only downside would be you might see the 'curved slot' above and below the elevator because your moving away from the thickest part of the surface (pivot point)
    Cheers
    john
  7. #782
    FenderBean's Avatar
    Join Date
    Feb 2006
    Clarksville , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The only problem with that the further u move away from the shaft the more the more travel required and u can only cut a small slit for servo arm.
    Keith who?
    Xtreme ARF Rep
  8. #783
    Join Date
    Jan 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you cant get enough movement with the servo further away, then for me it's not a viable way of doing things.
    I really hope the smal F-18 doesnt have this set-up, if it does and i cant modify it, it's a deal breaker.
  9. #784
    FenderBean's Avatar
    Join Date
    Feb 2006
    Clarksville , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well if if servo arm sits in the same place it does with the old style rods, torque applied doesnt change and you take out linkage slop. The more i think about that part of the design i like it, but i personally feel the bearing on the shaft is better. Over time there will be some wear, dirt and g loading is normal wear.
    Keith who?
    Xtreme ARF Rep
  10. #785
    Join Date
    May 2005
    Norman, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Anyone have a good RTF weight for a new all honeycomb 1/6 f-16?
    Parker Ferguson
  11. #786
    FenderBean's Avatar
    Join Date
    Feb 2006
    Clarksville , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    from what I was told its about 6lbs less, but thats what I was told.
    ORIGINAL: BoomerSooner
    Keith who?
    Xtreme ARF Rep
  12. #787
    Join Date
    May 2005
    Norman, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What did yours weigh again?
    Parker Ferguson
  13. #788
    lookilook's Avatar
    Join Date
    Jan 2008
    NICOSIA, CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Boomer see my post#661 on page 27 for weight with honeycombe.
    OWNER OF
    F16 1/8 K80E
    F16 1/6 K170F
    F18F K180G
    TD VIPER EV90
  14. #789
    jetspud's Avatar
    Join Date
    Dec 2001
    shreveport , LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was looking but may of missed it, do you have a pic or can you tell me were the elevators sit in the nuteral position
    Thanks david
  15. #790
    Join Date
    May 2013
    Centre, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Fender closed his account as stated in his f-15/14 his friend maybe able to help you get in contact with him.
    http://www.rcuniverse.com/forum/m_11...10/key_/tm.htm
    Looks like M3Baker knows him
  16. #791
    RCflyerCT's Avatar
    Join Date
    Oct 2012
    Southbury, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    We did the maiden of my FEJ 1/6 scale F16 this week - thunderbird scheme. The jet flys very well and I am very happy with the quality and great customer service from FEJ. I really like the honeycomb as I believe it is stronger and lighter than conventional construction (all stress bearing formers and mounts are plywood). Many thanks to my builder (Nir Schweizer), who did another awesome build job for me and also did the initial test flights. Also thanks to all the awesome dudes at Farview Flyers for the advice and help. The jet flys on a Rhino, has DFS lights, and a Tam custom pipe. Weight is estimated at about 35lbs with CG at 220.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1896443   Click image for larger version.
  17. #792
    Join Date
    May 2013
    Centre, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Its funny you say customer service, these guys even blew off fender who helped fej turn their crappy reputation around. Yeah great service
    ORIGINAL: RCflyerCT
  18. #793
    RCflyerCT's Avatar
    Join Date
    Oct 2012
    Southbury, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was posting my experience in what has been a constructive build thread. There are other multiple "bash FEJ" threads that are probably more appropriate for your negative and confrontational vitriol.
    ORIGINAL: Area51.5
    ORIGINAL: RCflyerCT
  19. #794
    Erik R's Avatar
    Join Date
    Jan 2002
    Fogelsville, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wes,
    It was good to see you and Nir again,and we're very happy about your successful outing. Good luck with your beautiful new airplane,and come back and hang with us soon. Take care,
    Erik
  20. #795
    Join Date
    May 2013
    Centre, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just saying it is well known their service sucks, and when you need parts and you will need parts remember this statement.  I wish fender would let everyone here read all the emails from these guys, keith kept every email from both James and Lowell since the first day he started in jets. I'm just glad I called him before ordering. I do wish you good luck and hope my comment is wrong.
  21. #796
    acabrera11's Avatar
    Join Date
    Oct 2004
    Opa Locka, Fl.
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello
    can somebody help me whit some pictures about elev servo installation?
    Angel
  22. #797
    FenderBean's Avatar
    Join Date
    Feb 2006
    Clarksville , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote Originally Posted by acabrera11 View Post
    Hello
    Angel
    Hello, if you look at post # 100 there are a few pics of the elevator install...Cheers
    Keith who?
    Xtreme ARF Rep
  23. #798
    acabrera11's Avatar
    Join Date
    Oct 2004
    Opa Locka, Fl.
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks FB, I was looking your thread, just excellet.
    but my Falcon goes whit the servos outside, I think that this way is not as good as yours, IMHO a shaft 90degres of servo arm reduces the servo torque, and that shaft is not tight enough, so the flutter can come whit a lot of problems.
    please I need to know if somebody did whit the outside servo? How it works? And what hardware use to that.
    thanks
    Angel
  24. #799
    acabrera11's Avatar
    Join Date
    Oct 2004
    Opa Locka, Fl.
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Another question, how to avoid that the elev main shaft go out? Whit a collar? How to avoid friction between collar and plαstic PVC tube?
    thanks, pictures are welcome.
  25. #800
    FenderBean's Avatar
    Join Date
    Feb 2006
    Clarksville , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My stab had a small white plastic ring that kept the gap
    Keith who?
    Xtreme ARF Rep
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
