If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 14 of 14
  1. #1
    Henke Torphammar's Avatar
    Join Date
    Oct 2002
    Ljungby, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Falcon 120 "wingmod" *video*
    I bought a Falcon 120 kit some years ago. Due to the low quality of the kit I put it away for some years to dig it out this summer. My plan was to use it as a flying wing which needed relocation of the landinggear... opening the wing I saw the disaster and the amount of work needed to make it durable enough for grass field operation... so I jumped the gear and decided SOG (slide of ground) would be good enough :-)
    For power I use the Haoye 5" EDF with a Scorpion 4035-800 motor, the setup uses 159A from a 10S pack and provides enough thrust for unlimited verticals. Topspeed seem to be around 125mph due to my Android app which dopplers the plane in the air, flight times about 4min on my 5000mAh packs with power to spare for a couple of aborted landings.
    I was surprised of the amount of power the fan put out, even with a turbine setup very fiew planes have the oumpf to go straight up from the start.
    I'm not saying this is better then anything else, just that I with inspiration from the guys at rcgroups.com came up with a pretty cheap way of flying a pretty large jet model with an EDF setup.
    [youtube]http://www.youtube.com/watch?v=Jy8NNlGUApY[/youtube]
    /Henke
    www.youtube.com/henke2
    Ready2fly - T45 Goshawk, Lambert Kolibri T35. Perfect if I want to do carrier training!
  2. #2
    Join Date
    Jan 2002
    Elk Grove, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    Well done modification.....great flight....
  3. #3
    Join Date
    Dec 2001
    WEST PALM BEACH, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    KOOL..C/G STILL 13 INCHES?? STOCK??
  4. #4
    Join Date
    Oct 2002
    Ljungby, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    ORIGINAL: RAPPTOR
    About 10,5" CG, you also need to cut away the flaps part of the wing and align it with the motormount, or rather cut 4/5 and crack it up, then fill the gap with balsa and the glue of your choice. :-)
    /Henke
  5. #5
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Kent, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    Now that is impressive, I don't mean the Falcon, but how flat your grass patch is. LOL I would kill for a grass patch that flat even the sheep poo forms bumps bigger than the wheels at our site. and if you ever run out of epoxy use sheep poo, its impossible to get off once its dried.
    Mike
    My Gast is Flabered.
    No matter what anyone say's 100% is the maximum you can get.
    If you see a deleted post, my Avatar say's it all.
  6. #6
    Join Date
    Jan 2002
    Lawrence, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    I'm not sure what you meant regarding the flaps. So you are flying with elevons and no flaps? And the wing inside the stabs are inline with the motor mount? Looks like rudders, but I can't see the servos.
  7. #7
    erbroens's Avatar
    Join Date
    Nov 2003
    Curitiba, Parana, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    ItΒ΄s a smart and quick Idea... nice! As a bonus you can fly it easily on snow too.
    Enrique
  8. #8
    Join Date
    Oct 2002
    Ljungby, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    ORIGINAL: rocketman-RCU
    The upper surface of the trailing edge needs to be level with the motor mounting platform. Flying it with only two servos.
    /Henke
  9. #9
    Join Date
    Mar 2010
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    Anyone building the Falcon 120 needs to see the 6 part instructional video on Youtube.
    It is the BEST one out there. Covers every aspect of the build. Sure wish I would have know about this before I built my first one.
    http://www.youtube.com/watch?v=OYYo4...ature=youtu.be
  10. #10
    Xairflyer's Avatar
    Join Date
    Dec 2002
    Co. Donegal, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    Love it (the wing mod not the edf )
    So who is going to be first with a turbine version?
    www.letterkennymodelflyingclub.com
    www.jmaireland.com
  11. #11
    Join Date
    Jun 2004
    Reut,Israel
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    Cool wing mod ! how bad would it be on the stock gear location ? perhaps adding trailing link struts could help ?
  12. #12
    Dr Honda's Avatar
    Join Date
    Apr 2005
    Latrobe, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    ORIGINAL: Henke Torphammar
    About 10,5'' CG, you also need to cut away the flaps part of the wing and align it with the motormount, or rather cut 4/5 and crack it up, then fill the gap with balsa and the glue of your choice. :-)
    Is this to ad reflex to the design?
    ORIGINAL: Xairflyer
    I have a falcon that's stripped to be "Beefed-up" a little. Maybe this is what I need to do to it. If I added canards... it would be a Jr Rookie.
    Tony
  13. #13
    Join Date
    Oct 2002
    Ljungby, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    ORIGINAL: i3dm
    As the CG moves forward by about 3" you need to follow with the landing gear, trailing links would make it worse. A quite easy fix if you got materials and a proper jigsaw and a good rectract system to use. I didn't at the moment.
    /Henke
  14. #14
    Join Date
    Oct 2002
    Ljungby, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Falcon 120
    ORIGINAL: Henke
    ORIGINAL: Dr Honda
    Yep!
    /Henke
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
