p200sx FOD screen
RE: p200sx FOD screen
The one that Jetcat sells should work with a bypass. The OD diameter is slightly smaller than the overall diameter of the turbine. I have been using them on my P-200s without any problems.
With a sieve for the soup with fine stitch in stainless steel that works so very well cost 15€ in France in the supermarket beam "Dishes". Then it is enough to cut the plastic handle, to make a hole in the stainless stitches for the starter and to congeal the whole with some epoxy glue. View in my F18 1/7 of FEJ
