Reload this Page >
Schubeler Hawk for P-20 turbine
Old 08-09-2011, 05:34 AM
Dave Wilshere
Default Schubeler Hawk for P-20 turbine
Another of my growing airforce of P-20 models just arrived this AM, these kits are so popular there is a several months waiting list. We have more coming for customers doing the same thing.
The mouldings are super light and the wing features gear doors, live hinged Flaps and ailerons. Although it looks bigger, its actually the same fuselage length as the Habu 32. I'm going to use Electric retracts when I get time for the build. I have a Cougar< Eurofighter and Mig 15 before then!
Dw
ID:	1646356   Click image for larger version
Old 08-09-2011, 05:55 AM
Henke Torphammar
Henke Torphammar's Avatar
Default RE: Schubeler Hawk for P-20 turbine
Very nice! Please weigh all parts, always good too know the empty weight of the airframe :-) Do you think it will ballance with the motor mounted in the back?
I just decided I will put togeather a Savex L39 for my turbine, will try to mount it in the tail to make room for a fueltank at CG. (might use the in wing tank too)
Old 08-09-2011, 07:04 AM
Dave Wilshere
The fuselage and wing weighs 942 gram, too busy at the moment to even fully unpack it! It is light. I never want the turbine in the back, I like the hot gas to travel down a tube first...
Dw
Old 08-09-2011, 07:09 AM
bigplumbs
Banned
Is the Mig also for the P20 or a larger one
Dennis
Old 08-09-2011, 07:43 AM
Doksa
Hello Dave:
I also have the Hawk and have started gathering parts for the build. The electric retract sound like a good idea: possibly a weight saving idea.. I did purchase the semi scale mechanical retracts.
I did weight all componets to be 7.8 lbs dry. I have a new L-39 in the swiss colors with w/wing tank option as well. Looking forward to your build thread
Best Regards
John
Old 08-09-2011, 07:46 AM
Doksa
deleted
Old 08-09-2011, 07:59 AM
Vincent
My Feedback: (61)
Vincent's Avatar
Dave,
I have a P-20 powered Tams F-16 with 52 flights and it is a very sweet combo. Recently i have been looking for other suitable scale airframes for the P-20 and dont see many choices out there yet. For some reason i dont like the Hawk (in any size) but i would really like to see maybe Horizon follow up their Habu 32 with some scale offerings for EDF or P-20.I have recently converted a RC Lander T-33 (all foam) but have not been able to test fly it due to a recall on all the defective elec retracs. An all foam jet is not really my idea for a P-20 airframe but for right now this jet has good size and should work on turbine power.Longevity is another matter...
Vin...
Old 08-09-2011, 08:46 AM
Dave Wilshere
John
Larger.
I figured less that that with the electric retracts and my turbine set up. We will see.
Vince...Just wait a little while and you will be happy soon
Dave
Old 08-09-2011, 08:55 AM
Vincent
My Feedback: (61)
Vincent's Avatar
ORIGINAL: Dave Wilshere
John
Larger.
Dave
Vin...
Old 08-12-2011, 01:27 AM
Henke Torphammar
Impressive! thanks!
Old 01-12-2013, 02:37 PM
Henke Torphammar
Did this one fly?
Old 01-12-2013, 11:40 PM
POWER JET
I have a P-20 powered Hobbyking's L59 with 32 flights and it is a very sweet combo!
This jet has good size and it's not heavy.Including fuel 750ml,the weight is at 4 kilos.
I really enjoy this plane....
ID:	1839755   Click image for larger version
ID:	1839756   Click image for larger version
Old 01-12-2013, 11:42 PM
POWER JET
and some more...
ID:	1839758   Click image for larger version
Old 01-13-2013, 01:31 AM
Henke Torphammar
ORIGINAL: POWER JET
Then imagine this Hawk that is 1kg lighter!
Old 01-13-2013, 02:13 AM
corndog2
Banned
ORIGINAL: POWER JET
Hello
I have the same L59 with a P20 in it and am having trouble with the nose wheel. I wonder if you could tell me what retract you have in the nose.
Also the model is quite light on the nose wheel even after adjusting the cg
Old 01-13-2013, 02:55 AM
Dave Wilshere
Henke
Another project sitting on top of my office waiting for time. I do have two customers doing them also, one is close to flying
Dave
Old 01-13-2013, 04:45 AM
POWER JET
ORIGINAL: Henke Torphammar
ORIGINAL: POWER JET
As Dave said, the fuselage lenght is like Habu 32.
The Habu has a lenght of 1200mm and wingspan 1000mm.
The L59 has wingspan 1200mm and fuselage length 1323mm.It's a big difference.
If you notice, i said total weight is 4 kilos including the fuel 750ml.So without fuel is 3250.Is very light for the dimensions and considering
the hardware has on it..retracts ,struts,two batteries Flightpower 2100,UAT 60ml etc.
So you are telling me that the total weight of the Hawk will be 2250?Seems hard to believe.
Old 01-13-2013, 04:55 AM
Henke Torphammar
ORIGINAL: POWER JET
ORIGINAL: POWER JET
So you are telling me that the total weight of the Hawk will be 2250? It's hard to believe it!
I'm pretty sure it was 2800grams fueld up. As you can see it takes of in a very short distance and goes straight up.
[youtube]http://www.youtube.com/watch?v=veUpBsrwECo[/youtube]
Old 01-13-2013, 05:51 AM
POWER JET
Henke, maybe it is, but you must have in mind that is quite smaller.
13 cm more on lenght and 10 cm on wingspan is a big difference.
I beleive i kept the weight very low on my L59 for the size of it and consider that it has 200gr on the nose for balancing!!
The L59 has a very heavy tail that's why i add these 200gr on nose..
If i don't take in mind these 200gr then the plane weight is 3 kgrempty..
Old 01-13-2013, 06:02 AM
POWER JET
ORIGINAL: corndog2
ORIGINAL: POWER JET
Hello
That's why i add 200 gr on nose for balancing the model..It has a very heavy tail.
The struts and retracts are from Hobby king..
http://www.hobbyking.com/hobbyking/s...dProduct=25499..
http://www.hobbyking.com/hobbyking/s...ke_Large_.html
Old 01-13-2013, 07:13 AM
john josey
Henke
Dave
Just a pity i'm not a bit closer, i could probably lighten the load for you as this is my quiet time of year.
Old 01-13-2013, 08:14 AM
Felix Barrao
This is my CMP T-45 with a Jetjoe Junior turbine. 1140 mm wingspan and 1220 mm lenght.
Electric retract, flaps and double receiver battery, the wheight is 2.800 g dry, and 3.200 g. ith 500 ml of kero. It flies very well, and would be perfect for a P-20
Maiden and second flight.
https://www.youtube.com/watch?v=Hmx1vYyy-dc
Regards
FĂ©lix
Old 01-13-2013, 08:37 AM
POWER JET
The CMP Hawk was one of my first projects...but never flew..even now i don't know what went wrong...
Maybe it was too much tail heavy and i didn't pay attention...did you balance it ,exactly where the manufacturer gives the CG?
DId you put weight on the nose?
Old 01-13-2013, 09:01 AM
husafreak
husafreak's Avatar
Tam had/has one of these and I stared at it quite a lot! Perfect size, shape, and finish on that one. TJ80 though.
Old 01-13-2013, 10:01 AM
Felix Barrao
ORIGINAL: POWER JET
No, the point that is indicated on the wing as CG is at 150 mm from the LE. This is wrong, the correct one is between 105-115 mm. Mine is at 110mm. For sure this was your problem..
Regards.
