Where can you get bulk airline?
RE: Where can you get bulk airline?
Does he have a website, hey what is the typical airline we use made of?
ORIGINAL: WhoDaMan
Tom Cook has some great stuff
My Feedback: (164)
CA
http://www.jetmodelproducts.com/
ORIGINAL: FenderBean
ORIGINAL: WhoDaMan
Dreamworks, has one a six line in air accessory
ORIGINAL: kelly vallee
On the air line subject, I need a five hoses quick connect?
My Feedback: (23)
cheapest place i have found period.
http://www.protubing.com/od-18-inchid-06618066.html
$7.20 for 50 feet
Or if you want 8 tube ribbon-
http://www.protubing.com/8m013110432...282925818.html
$159.16 for 100 foot roll
$7.20 for 50 feet
My Feedback: (12)
Or you could throw it in an Excel Spreadsheet if you're feeling saucy Thomas!!! I used to buy from a local Freelin distributor for about the same price but had to pickup at will call. Now I can just have it shipped to me!!
You know I started doing this for helis, I made a list of all the places I bought from and just passed it on to people who needed info. All my favorite websites for info as well, kinda like a newbie guide for rc helis
I can't remember right now who posted this list, but here it is for McMaster Carr. I call it the Master List
McMaster Carr Jet List
Heres a list a friend gave me a long time ago of some jet related stuff you can find there: The prices are old btw - use for the part numbers:
Air Gauges & Fittings:
38105K33 Gearless Mini ABS-Case Gauge 5% Full Accuracy 29/32" Dial, 1/8" NPT Center Back, 0 To 160 Psi $8.82 EA
38105K32 Gearless Mini ABS-Case Gauge 5% Full Accuracy 29/32" Dial, 1/8" NPT Center Back, 0 To 100 Psi $8.82 EA
5779K123 Glass-Filled Nylon Instant Tube Fitting Female Straight Adapter For 1/8" Tube OD, 1/8" NPT $2.85 EA
50785K141 Extruded Brass Threaded Pipe Fitting 1/8" Pipe Size, Locknut $0.52 EA
91862A511 Hex Thin Nut Nickel-Plated Brass, 1/8"-27 NEF, 1/2" W, 1/8" H $2.00 PK
8063K33 Brass Air Tank Valve 1/8" NPT, 15/16" Overall Length $2.40 EA
8063K39 Brass Air Tank Valve 1/4" Tube, 1-5/8" Overall Length, Barbed $4.00 EA
Air System:
5648K22 Choose-A-Color Ether-Base Polyurethane Tubing .066" ID, 1/8" OD, .030" Wall, 7 colors avail $0.16 FT
51605K13 Mini Acetal Snap-Lock Tube Coupling Socket W/Barb, Straight Through, 1/16" Tube ID $1.18 EA
51605K11 Mini Acetal Snap-Lock Tube Coupling Plug W/Barb, Straight Through, 1/16" Tube ID $1.95 EA
51605K23 Mini Acetal Snap-Lock Tube Coupling Socket W/Barb, Shutoff Valve, 1/16" Tube ID $7.72 EA
51525K121 Quick-Turn Tube Fitting Nylon, Male X Barb, For 1/16" Tube ID, Packs of 10 $3.56 PK
51525K211 Quick-Turn Tube Fitting Nylon, Female X Barb, For 1/16" Tube ID, Packs of 10 $3.11 PK
51525K131 Quick-Turn Tube Fitting Polypropylene, Male X Barb, for 1/16" Tube ID, Packs of 10 $4.05 PK
51525K261 Quick-Turn Tube Fitting Polypropylene, Female X Barb, for 1/16" Tube ID, , Packs of 10 $3.60 PK
5116K11 FDA Nylon Single Barbed Tube Fitting Tee For 1/16" Tube ID, Packs of 10 $2.18 PK
5116K16 FDA Nylon Single Barbed Tube Fitting Coupling For 1/16" Tube ID, Packs of 10 $1.84 PK
5116K21 FDA Nylon Single Barbed Tube Fitting Reducing Coupling For 1/8" X 1/16" Tube ID $1.84 PK
53415K101 Polypropylene Single-Barbed Tube Fitting Coupling for 1/16" Tube ID, Packs of 10 $4.05 PK
53415K285 Polypropylene Single-Barbed Tube Fitting Tee for 1/16" Tube ID, Packs of 10 $7.00 PK
53415K114 Polypropylene Single-Barbed Tube Fitting Reducing Coupling for 1/8" X 1/16" Tube ID, Packs of 10 $4.29 PK
53415K289 Polypropylene Single-Barbed Tube Fitting Reducing Coupling for 3/32" X 1/16" Tube ID, Packs of 10 $4.29 PK
7757K41 Polypropylene Spring-Loaded Ball-Check Valve 1/8" Barb X 1/8" Barb $2.90 EA
2774K11 Nylon Barbed Tube Fitting With Check Valve Coupling For 1/8" Tube ID $3.70 EA
Axles:
94380A525 Zinc-Plated Hardened Steel Clevis Pin 3/16" Diameter, 1-1/2" Length, Packs of 25 $5.79 PK
92390A108 18-8 Stainless Steel Clevis Pin 3/16" Dia, 1-1/2" Length, 1-23/64" Usable Length, Packs of 10 $8.06 PK
94380A560 Zinc-Plated Hardened Steel Clevis Pin 1/4" Diameter, 1-1/2" Length, Packs of 25 $6.67 PK
92390A163 18-8 Stainless Steel Clevis Pin 1/4" Dia, 1-1/2" Length, 1-23/64" Usable Length, Packs of 10 $11.04 PK
Bushings (which fit Trim or Air Power wheels):
6338K311 SAE 841 Bronze Flanged-Sleeve Bearing for 3/16" Shaft Diameter, 5/16" Od, 1/2" Length $0.47 EA
6391K116 SAE 841 Bronze Sleeve Bearing for 3/16" Shaft Diameter, 5/16" Od, 1/2" Length $0.33 EA
6391K127 SAE 841 Bronze Sleeve Bearing for 1/4" Shaft Diameter, 5/16" Od, 1/2" Length $0.46 EA
Ducted Fan:
6972A24 Ball-Point Blade 1/4" Hex, 6-13/32" Blade Length (DF starter dog replacement) $1.72 EA
9464K29 (Same as 9464K342) Viton O-Ring AS568A Dash Number 116, Packs of 50 (Exhaust header seals) $9.70 PK
9396K29 (Same as 9396K6) Silicone O-Ring AS568A Dash Number 116, Packs of 50 (Exhaust header seals) $8.55 PK
9452K93 (Same as 9452K342) Buna-N O-Ring AS568A Dash Number 128, Packs of 100 (Pipe hanger o-ring) $6.90 PK
Epoxy, Dispensing Gun & Nozzles:
6430A29 Loctite Hysol Adhesive Cartridge E-20NS Metal Bonder Epoxy, 1.7-oz (like Aeropoxy but hard in 2 hr) $9.72 EA
6430A19 Loctite Hysol Adhesive Cartridge E-20HP High Strength Epoxy, 1.7-oz $9.72 EA
6430A33 Loctite Hysol Adhesive Cartridge 9462 Epoxy, 50ml (same as BVM Aeropoxy??) $9.80 EA
74695A71 Duo-Pak Dispensing Cartridge Gun and Mixer Dispensing Gun With 1:1 & 2:1 Ratio Plungers $22.86 EA
74695A12 Bayonet Mixer Nozzle 5.9" Long 1/4" Taper Tip For Duo-Pak Dispensing Cartridge Gun and Mixer $1.00 EA
74695A57 Bayonet Mixer Nozzle 3.4" Long 3/16" Taper Tip For Duo-Pak Dispensing Cartridge Gun and Mixer $1.00 EA
Festo Type Instant Fittings:
5225K61 Metric Glass-Filled Nylon Instant Fitting Coupling For 4mm Tube OD $1.90 EA
5225K77 Metric Glass-Filled Nylon Instant Fitting Tee For 4mm Tube OD $2.85 EA
5225K85 Metric Glass-Filled Nylon Instant Fitting Wye For 4mm Tube OD $2.85 EA
5225K62 Metric Glass-Filled Nylon Instant Fitting Coupling for 6mm Tube OD $2.50 EA
5225K78 Metric Glass-Filled Nylon Instant Fitting Tee for 6mm Tube OD $3.63 EA
5779K11 Glass-Filled Nylon Instant Tube Fitting Coupling for 1/8" Tube OD $2.70 EA
5779K31 Glass-Filled Nylon Instant Tube Fitting Tee for 1/8" Tube OD $4.03 EA
5779K14 Glass-Filled Nylon Instant Tube Fitting Coupling for 1/4" Tube OD $2.25 EA
5779K34 Glass-Filled Nylon Instant Tube Fitting Tee for 1/4" Tube OD $3.43 EA
Fuel Jugs:
4224T75 Polyethylene Fuel Can 5 Gallon Capacity, 10" W X 10-3/4" L X 16" H, Blue (Kerosene) $8.23 EA
4224T73 Polyethylene Fuel Can 5 Gallon Cap, 15" L X 8-3/4" W X 15" H, Yellow (Diesel or Smoke) $8.23 EA
4224T72 Polyethylene Fuel Can 2 Gallon Capacity, 7-3/4" W X 9-1/4" L X 9-3/4" H, Red (Smoke?) $4.38 EA
Fuel System:
8220K32 Delrin Miniature Gear Pump 12 VDC $49.32 EA
5187K61 Fuel and Lubricant PVC Tubing 1/8" ID, 1/4" OD, 1/16" Wall, Clear Yellow $0.27 FT
5552K22 Tygon Fuel and Lubricant PVC Tubing 3/32" ID, 3/16" OD, 3/64" Wall, Translucent $0.62 FT
5552K23 Tygon Fuel and Lubricant PVC Tubing 1/8" ID, 1/4" OD, 1/16" Wall, Translucent $0.61 FT
50315K22 Choose-A-Color Metric Polyurethane Tubing Ether-Based, 2.4mm ID, 4mm OD, .8mm Wall $0.17 FT
51605K24 Mini Acetal Snap-Lock Tube Coupling Socket W/Barb, Shutoff Valve, 1/8" Tube ID $7.66 EA
51605K14 Mini Acetal Snap-Lock Tube Coupling Socket W/Barb, Straight Through, 1/8" Tube ID $1.14 EA
51605K12 Mini Acetal Snap-Lock Tube Coupling Plug W/Barb, Straight Through, 1/8" Tube ID $1.79 EA
5116K17 FDA Nylon Single Barbed Tube Fitting Coupling For 3/32" Tube ID, Packs of 10 $1.84 PK
5116K18 FDA Nylon Single Barbed Tube Fitting Coupling For 1/8" X 1/8" Tube ID, Packs of 10 $1.84 PK
5116K13 FDA Nylon Single Barbed Tube Fitting Tee For 1/8" Tube ID, Packs of 10 $2.48 PK
53415K157 Polypropylene Single-Barbed Tube Fitting Tee for 1/8" Tube ID, Packs of 10 $7.38 PK
53415K103 Polypropylene Single-Barbed Tube Fitting Coupling for 1/8" Tube ID, Packs of 10 $4.29 PK
53415K102 Polypropylene Single-Barbed Tube Fitting Coupling for 3/32" Tube ID, Packs of 10 $4.29 PK
4293T76 Wide-Mouth Rectangular Poly Bottle 4 oz, 2-3/8" X 1-1/2" Base, 4" Overall Height (UAT Bottle) $1.30 EA
4293T65 Wide-Mouth Rectangular Poly Bottle 64 oz, 6" X 3-5/16" Base, 9-1/2" Overall Height (Main Tank) $12.28 EA
8860K11 Type 302/304 Stainless Steel Soft-Temper Wire .015" Diameter, 1/4-lb Coil, 414' Coil (Safety Wire) $6.49 EA
8860K12 Type 302/304 Stainless Steel Soft-Temper Wire .020" Diameter, 1/4-lb Coil, 233' Coil (Safety Wire) $6.86 EA
Heat shrink for servo plugs:
7856K16 Polyolefin Thin-Wall Heat-Shrink Tubing 3/8" Expanded Id, 3/16" Shrunken Id, 4' Length $2.03 EA
JetCat, Starter O-ring:
9262K545 (Same as 9262K41) Metric Buna-N O-Ring 3 mm Width, 6 mm Inside Diameter, Packs of 100 $7.14 PK
4985T43 Brass Miniature Solenoid Valve W/Tube Connect 1/8" Barb, 50 Max PSI, .038 Cv $43.30 EA
Misc:
7782A4 Standard Desoldering Braid 7/64" Width, 5' Length $2.72 EA
8667K52 Grade G-10/FR4 Garolite Sheet 1/32" Thick, 12" X 24" $7.15 EA
8667K241 Grade G-10/FR4 Garolite Sheet 1/16" Thick, 12" X 24" $10.88 EA
85345K21 Grade G-10/FR4 Colored Garolite Sheet 1/16" Thick, 12" X 24" $12.37 EA
6539T11 High Impact Plastic Flashlight Requires 2 D Batteries, Krypton, Yellow $5.44 EA
9619T75 Plastic Drawer Cabinet 44 Polypropylene Drawers, 32 Small, 12 Large $22.36 EA
Safety Wire:
8860K12 Type 302/304 Stainless Steel Safety Lock Wire .020" Diameter, 1/4-lb Coil, 233' Coil $7.06 EA
8860K11 Type 302/304 Stainless Steel Safety Lock Wire .015" Diameter, 1/4-lb Coil, 414' Coil $6.69 EA
Smoke Tubes:
8988K547 Precision Type 304 SS Standard-Wall Tubing 11 Gauge, .120" OD, .094" ID, .013" Wall, 3' L $8.29 EA
8988K511 Precision Type 304 SS Standard-Wall Tubing 12 Gauge, .109" OD, .085" ID, .012" Wall, 3' L $8.29 EA
8989K11 Type 304 Stainless Steel Welded Tubing 1/8" OD, .093" ID, .016" Wall, 6' Length $9.23 EA
Stainless Tailpipe Materials:
9506K14 Type 302 Stainless Steel Shim Stock Roll .004" Thick, 12" Width X 50" Length $23.79 EA
9506K16 Type 302 Stainless Steel Shim Stock Roll .006" Thick, 12" Width X 50" Length $25.41 EA
91793A074 18-8 SS Binding Head Slotted Machine Screw 2-56 Thread, 1/8" Length $3.26 PK
91841A003 18-8 Stainless Steel Machine Screw Nut 2-56 Screw Size, 3/16" WD, 1/16" HT $2.35 PK
Turbine oil:
http://store.yahoo.com/oilstore/aerturoil.html
http://store.yahoo.com/oilstore/mobturenoil.html
Wood:
Hardwood dowels & balsa sheets, pages 3354 & 3355 as of 1/25/05
UAT & UAT Bag:
From Auto Zone (not McMaster): AIRTEX p/n FS3 Fuel Strainer - about $6
Air System:
Axles:
Ducted Fan:
Fuel Jugs:
Fuel System:
Misc:
Safety Wire:
Smoke Tubes:
Turbine oil:
Wood:
UAT & UAT Bag:
WOW now thats what im talking about! man this site would have saved me a lot of money LOL
OMG im going through this stuff and I cannot believe how much I over paid for stuff going through hobby dealers [:@]
Seriously thanks this makes my next jet build even more exciting! I would order just about everything on the list, and check this out, I love this fuel can, check out the link and look at gas can "C" to cool!
http://www.mcmaster.com/#catalog/117/1706/=du62mk
