Air Fittings
NC
Air Fittings
Can anyone tell me what to use to transition from a regular size air line for retracts to the smaller size line used for brakes? I have a sequencing valve that only has the larger air nipples. The brake line won't fit the valve nipple. I need a fitting with the regular air line size on end, and the smaller brake size on the other. I have looked through the dreamworks website and all I can find is standard air line size fittings.
Thanks in advance for any help.
My Feedback: (29)
RE: Air Fittings
While you can use a fitting as you suggest, the brake airline will fit on the brake air fitting, I'm assuming you are using BVM brake line, if you are using anything smaller, then it won't fit, I use the BVM brake line and what I do is apply some silicone grease all over the fitting and then work the line on it, it will go in and slide all the way down and not come out...
