Reload this Page >
A4 Skyhawk build
A4 Skyhawk build
Old 01-03-2013, 05:51 AM
  #176
ZivBit
ZivBit's Avatar
Default RE: A4 Skyhawk build
ORIGINAL: Alex48
Hi Ziv, will do...
What model are you going to wash? Whats the finish, this technique will only work on satin or Matt finishes, if its gloss then oils will have to be used. I'll include more info in the next video.
Cheers, Alex
Hi Alex,
Thanks.
my planes is exactly the same... A-4 from SM in the IAF colors in matt colors.
what colors of Tamiya I need to buy? gray?black?
Ziv
Old 01-03-2013, 06:33 AM
  #177
Alex48
Alex48's Avatar
Looks good!
Buy white, black and a dark brown. A couple of each should do. Don't use the black or white purely as they always need softening, I use dark brown with a touch of black, the white with some black to make a light grey. Do the light wash first perhaps only over the brown on your scheme then the darker wash over the sand and green, you'll have to experiment to see which shade of wash looks better. Start with a watery wash and try the technique on the underside first. Make sure you use the pads don't substitute with normal wet & dry as this is too harsh as it doesn't spread the applied pressure very well.
Good luck and any issues just email.
Cheers
Old 01-03-2013, 11:49 AM
  #178
Alex48
Alex48's Avatar
Is there a way to embed you tube videos into the thread? It just comes up with this? I'm sure I'm doing something wrong.
<iframe width="560" height="315" src="http://www.youtube.com/embed/81fnWrUufqE" frameborder="0" allowfullscreen></iframe>
Thanks, Alex
Old 01-03-2013, 12:53 PM
  #179
Robrow
Robrow's Avatar
Alex, not sure if its any help, managed to do this but not sure how to get the youtube pic in there (IT not my thing) [] I'm sure there are plenty of folk on here who will know. My iPad could not do it (same as it won't upload images) so had to use the MacBook.
[link=http://www.youtube.com/embed/81fnWrUufqE]A4[/link]
Rob.
Old 01-03-2013, 01:09 PM
  #180
marc s
marc s's Avatar
Alex are you using the YouTube button or the link button - I use the link and just copy and paste the url from the Youtube video in and job done.
marcs
Old 01-03-2013, 01:17 PM
  #181
Robrow
Robrow's Avatar
Not sure how the youtube button is supposed to work.
Rob.
Old 01-03-2013, 02:15 PM
  #182
Geoff White
Geoff White's Avatar
u mean like this?
[youtube]http://www.youtube.com/watch?v=81fnWrUufqE[/youtube]
If so then click on the YouTube button and between the Youtube tag and Youtube closing tag, paste the long version of the URL for the video. Do not use the short version as this doesn't work.
For example the long URL is - http://www.youtube.com/watch?v=81fnWrUufqE
and the short verison is http://youtu.be/81fnWrUufqE
Old 01-03-2013, 02:19 PM
  #183
Alex48
Alex48's Avatar
Thanks guys... Thats what I was after Geoff, I was using the short version... Cheers
p.s. ignore the spelling mistakes in the video, I need to proof read the next one...
Old 01-03-2013, 02:25 PM
  #184
Geoff White
Its the full URL with the id of the video passed in the query string(i.e. after a question mark).
Old 01-04-2013, 03:48 AM
  #185
Alex48
Alex48's Avatar
Wash is all complete, it definitely needs some decals. I'm going to try and use Alsa Ghost chrome on the exhaust nozzel as I tried flight metal but I couldn't get it looking very good. Going to have a few weeks off as I'm a bit A4'd out, if you know what I mean... I need to concentrate on a friends F16 anyway.
Cheers, Alex
ID:	1836638   Click image for larger version
ID:	1836639   Click image for larger version
Old 01-15-2013, 09:18 PM
  #186
kiwijet
Hi Guys,
All set to test fly last Sunday and it blew like.....[&o] never mind public holiday here next Monday so planning on test flight then! good old NZ summer
Here in New Zealand we have a requirement to register/certify our aircraft if they weigh between 15 & 25kg and special CAA approval for over 25kg. Part of the certification requires listing certain specs including wing area which is a figure I could'nt find published anywhere so for those interested the SM A4 comes out at around 1250 sq in (79.80 sq dm) and with my aircraft tipping the scales at 16.90kg gives a wing loading of approx 69 ozs/sq.ft (212 g/sq.dm).....a figure probably not wanting to think about to much
Anyone else that's built an A4 care to share your finished weight? the 16.90kg for mine is dry and I would be keen to know what the total fuel capacity is with the 2x side conformal tanks and the smaller rectangle shaped tank under the intake ducting, another figure I could'nt find listed in any specs...anyone know the tank capacities?
Some may notice the Kangaroo roundals have now been repainted with Kiwi's making it now officially an RNZAF aircraft!
Cheers.........Rene
Old 01-16-2013, 01:01 AM
  #187
Alex48
Alex48's Avatar
Hi Rene, from memory the total fuel capacity is 4 litres. My models final installed and balanced weight is 16.10kg this includes a full CAT. This is slightly lighter than yours although mine was weighed before painting just in primer. It flew very nicely at this weight. I'm hoping to fly mine soon and finish the set up. Do you have a gyro installed? It really needs an aileron gyro to help it present well or it will be wobbling all over the place. Good luck.
Cheers, Alex
Old 01-16-2013, 01:21 PM
  #188
kiwijet
Hi Alex,
Thanks for the info, my A4 has had around a dozen or so flights with the previous owner and apart from slightly different turbines of similar size there has been no great changes to equipment or structure
I purchased a Powerbox Igyro for the A4 at xmas but intend flying it in another model prior to fitting to the A4 just to check the system out and get the feel of operation.
Thanks again mate!
Rene
Old 01-29-2013, 08:19 AM
  #189
Alex48
Alex48's Avatar
Finished Thanks to Ali Machinchy for all his input on the scheme and weathering etc... Hopefully his advice has resulted in a better model.
Fingers crossed for friday's weather...
Old 01-29-2013, 08:24 AM
  #190
megafly
That's a beautiful model! Congrats!
Old 01-29-2013, 08:25 AM
  #191
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
your bird looks great amigo!! good luck with her.
cheers
Old 01-29-2013, 08:36 AM
  #192
Ali
Ali's Avatar
Pleasure mate. Its quite amazing to see how its turned out, especially considering what condition the kit was in when you got it!
Old 01-30-2013, 03:13 AM
  #193
Alex48
Alex48's Avatar
Thanks guys... Yeah it was definitely a kit and not an ARF, I don't remember you explaining that to me when I bought it though
Just finishing all those little details... The pilots bone dome has had a make over
ID:	1845929   Click image for larger version
Old 01-30-2013, 03:25 AM
  #194
Ali
Ali's Avatar
Bought it ??
Old 01-30-2013, 03:28 AM
  #195
Alex48
Alex48's Avatar
lol...good point, well made as always...
Old 02-01-2013, 02:03 PM
  #196
Alex48
Alex48's Avatar
What a day! Sunshine, 5kts of wind down the runway. Five back to back flights which I thoroughly enjoyed. The model is good fun to fly but more set up critical than most, just about there with the last flight. I'll post my findings and some more photos to round the thread off tomorrow.
Cheers,
Old 02-02-2013, 01:31 AM
  #197
madmodelman
madmodelman's Avatar
Congrats.
Old 02-02-2013, 07:39 AM
  #198
bang68
Congrats .-))
Has followed your tread from the start - super build !
I look forward to maiden my CARF.
Best looking aircraft ever .-))
Peter B
Old 02-02-2013, 10:30 AM
  #199
Alex48
Alex48's Avatar
Cheers guys. A few more from yesterday.
Old 02-02-2013, 10:55 AM
  #200
Alex48
Alex48's Avatar
Helps if I attach the photos
ID:	1847154   Click image for larger version
ID:	1847155   Click image for larger version
ID:	1847156   Click image for larger version
ID:	1847157   Click image for larger version
ID:	1847158   Click image for larger version
ID:	1847159   Click image for larger version
ID:	1847160   Click image for larger version
ID:	1847162   Click image for larger version
ID:	1847163   Click image for larger version
ID:	1847164   Click image for larger version
