If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 10 of 15 FirstFirst ... 89101112 ... LastLast
Results 226 to 250 of 369
  1. #226
    Join Date
    Aug 2002
    Cincinnati, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thorpe F-20 build
    Terry,
    Both my F=106A and my X-35B were painted with Klass Kote it works great. Very easy to work with. To get flat colors you need to add a flat powder to the hardner. The flat colors seem to set (cure) faster then the glossey ones. I did not use their primer, I just used automotive primer/filler in a spray can . Their plaints cover very well and you will be surprised how little paint it takes to cover a plane. I do recommend their thinner. I did use a cheaper thinner for cleaning my gun, however.
    Glenn
  2. #227
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Glenn,
    I bought the grey primer and thinner along with three gloss colors- red, yellow, blue. After flying the grey F-16, I want high visability on this small plane. Decided against the flat paint since it won't be a military scheme. Didn't get the clearcoat yet. Wasn't sure I would need it. I didn't know you could use primer from a spray can with this stuff. Thought it had to be epoxy so I bought their's.
    Did you have to use a respirator? Or can you just use a dust mask? I'll be spraying outside so ventilation won't be an issue. I don't have a paint booth anyway.
    Did you clearcoat the 106 and X-35? Have you had the chance to fly either one yet? Any additional tips would be appreciated.
    Terry
  3. #228
    Join Date
    Aug 2002
    Cincinnati, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry, I sprayed in my garage and used just a simple mask. It has charcoal filters on it, but a simple particle mask I think would be fine , especially outside. I did not clear coat. I do not think you will need to. The glossy hardener cures to a very glossy wet look. With the high temps. We are getting curing time will be shorter. Also watch the humidity. Check the website for the humidity warning you do not want the paint to blush, but this paint seems to tolerate a lot. The 106 and X-35 are ready but the weather has not been cooperating . I have been trying for a couple weeks to get the Jackal in the air but it has been either a heavy cross wind or HOT…for three weeks. Let me know when the big day comes for the first flight so I can video it.
    Glenn
  4. #229
    Join Date
    Oct 2007
    london, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Great job on the glassing-This is one of the best threads going-because its craft's man ship and a labour of love- not just an open your wallet and i will have one of those.....
  5. #230
    Join Date
    Aug 2002
    Cincinnati, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry, I forgot to mention I use one part thinner, one part hardener , and one part color. I put it in a bottle, and shake it well….then let it react for 45 minutes before spraying it.
  6. #231
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank you Agent Adds.
    Glenn- I thought the reducer was added after letting the mixture set for 1/2 hour. Is that not right?
    Started making the canopy hatch. Floor is 3/32 balsa. Bulkhead is 1/8 ply. Held wood to model and traced the shape on with a pencil. Cut the bulkhead 1/16 lower to account for sheeting later.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1783411   Click image for larger version.
ID:	1783412   Click image for larger version.
ID:	1783413   Click image for larger version.
  7. #232
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Line drilled the pin holes to get good alignment before gluing bulkhead to floor sheeting. Used a small round file to get the holes perfect.
ID:	1783415   Click image for larger version.
ID:	1783416   Click image for larger version.
ID:	1783417   Click image for larger version.
  8. #233
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Put the 3 mm carbon pins in without glue and pushed them so they just held the bulkhead in place. Then zapped the floor to it with only a few drops. Pulled the floor and bulkhead off together, removed the pins, then zapped all the way around the joint. Drilled the pin holes into the floor using the hole in the bulkhead as a guide. Put a drop of medium CA in the hole first then quickly pushed the pin in place. Did the same thing to the other pin. Then cut the pins to equal length with a small hand saw. Tested the fit and it is very good.
ID:	1783419   Click image for larger version.
ID:	1783420   Click image for larger version.
ID:	1783421   Click image for larger version.
  9. #234
    Join Date
    Aug 2002
    Cincinnati, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry, you are right about the reducer. The instructions say to add after waiting 45 minutes. I got the idea of adding it when I mix the part A and part B together from a video that Dave Platt did. He was mixing everything all at once…. I guess either way works. You probably should follow Nate’s instructions
  10. #235
    Join Date
    Nov 2003
    MT SHASTA, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I opened my kit and started looking over all the laser parts in preparation for the build, but I am still in need of a canopy if anyone has an extra or can direct me to where I could purchase one?
    Mike
  11. #236
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Paint arrived. More work on the canopy hatch latch...
ID:	1784132   Click image for larger version.
ID:	1784133   Click image for larger version.
ID:	1784134   Click image for larger version.
  12. #237
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    More latch work...
ID:	1784136   Click image for larger version.
ID:	1784137   Click image for larger version.
ID:	1784138   Click image for larger version.
  13. #238
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sanded the canopy hatch to shape to match the fuse.
ID:	1784140   Click image for larger version.
ID:	1784141   Click image for larger version.
ID:	1784142   Click image for larger version.
  14. #239
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Then I glassed it...
ID:	1784144   Click image for larger version.
ID:	1784145   Click image for larger version.
  15. #240
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Set-up for painting the primer coat today. Used a PVC tube inside a cardboard tube attached to a table to hold the plane. Stuffed rags inside the fuse to keep the tube somewhat centered. Mixed up the paint per instructions and started spraying. The first coat was very thin. Sprayed another coat and still too thin. Ended up brushing on a third coat to get good coverage. This primer does not like to be brushed on. Leaves heavy streaks that will need to be sanded out.
ID:	1784340   Click image for larger version.
ID:	1784341   Click image for larger version.
ID:	1784342   Click image for larger version.
  16. #241
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sanded alot over the last week and most all day yesterday. My hands are shoulders are very sore. Sprayed another light coat of primer last night to touch up where I sanded through the primer. First color went on this morning, red. Plan to put on the next color this afternoon, blue. Need to get more reducer. The paint has an orange peel look to it right now. I hope this smooths out as it cures.
ID:	1787214   Click image for larger version.
ID:	1787215   Click image for larger version.
  17. #242
    Bob_B's Avatar
    Join Date
    Nov 2003
    Bluegrass State of Mind
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry it sounds as if you did not flow enough paint. You could be doing more sanding.
    2017 Fall Jet Classic - Event Dates October 4-7, 2017
  18. #243
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I dare not put more. I think it would run. The primer was quick to run on me. I assume to colors would act the same. I used less reducer. Could that be the reason?
    I had to use a brush and touch-up some of the tight spots where the gun could not spray in to.
    I guess my first paint job with this stuff will not be the best. So I will learn from it and be better the next time.
  19. #244
    Bob_B's Avatar
    Join Date
    Nov 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Did you spray a tack coat and wait about 15 minutes to flow on a color coat?
  20. #245
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes. I waited 20 minutes. Then sprayed a heavier coat.
    The paint is now dry to the touch and I don't like it at all. Looks like crap. I'm going to spray another coat over top it now before it cures. Will try to spray heavier and add more reducer. Paint is mixed now. Wish me luck. This is turning into a nightmare.
  21. #246
    Join Date
    Aug 2002
    Cincinnati, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry,
    I sent you an email on paint problems...
    Glenn
  22. #247
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nightmare continues! Just spilled the paint I just mixed up! Cardboard I put on top to keep stuff from falling in got stuck just enough to cause the bowl to tip over when I went to lift it off. Red paint everywhere. What a mess. Only enough to mix up 4 oz left. Try it any way. Can't wait to see what screws up next.
  23. #248
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK, so here is the results of the second go around. Still orange peel but not as bad. Put down alot more paint. I was sure it would run but so far I don't see any runs. Now I get little bumps (POS) in the surface. I don't know if this is overspray, dirt, or something else. Also got what looks like a piece of fiber or hair on the surface of one of the wings. Looks like I'll have to sand this stuff out and put on yet another coat. 13 ounces so far with just the red! ***? I'll have to buy more paint. And this is a small model.
ID:	1787274   Click image for larger version.
ID:	1787275   Click image for larger version.
  24. #249
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Few more pics...
ID:	1787277   Click image for larger version.
ID:	1787278   Click image for larger version.
  25. #250
    fireblade5437's Avatar
    Join Date
    Dec 2005
    Leicester, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry
    I don't know what paint you are using but I use 2k light green Ti 2k filler/primer then one coat of 2k though you do need to have air fed mask on. The finish with 2k is like a mirror I don't even have to cut back and polish....
    Well worth the cost..
    The pic shows my Thorpe Red Arrows I painted with 2k around 5yrs ago red and white and blue, this was finish from gun and yes the wings are foam etc the cockpit was not finished when pic taken.
    I have just managed to pick up a little used SATA 4 mini for 129.00 in the UK, I look forward to trying it out.
    Alan
    Last pic with cockpit painted with same 2k primer onto the clear plastic again good perfect results.
ID:	1787290   Click image for larger version.
ID:	1787291   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
