If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 12 of 15 FirstFirst ... 21011121314 ... LastLast
Results 276 to 300 of 369
  1. #276
    Boomerang1's Avatar
    Join Date
    Jun 2005
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thorpe F-20 build
    If you have problems with tape goo try kerosene (not jet A & with out oil mixed in it.)
    Don't ask me why but it seems to disolve tape & sticker adhesive & is usually kind to paint.
    Saw a sticker on a restored 60's car in a magazine - ''built, not bought''. No need to explain.
    Must go, time to do some painting myself, crap weather here & a BVM Sabre needs some colour.
    John.
  2. #277
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the tip. I'll try Kero after I get the paint to harden up a bit more. Checked the yellow today and it is dry and not tacky at all. The blue is still tacky. I set the plane out where it will be in the sun today. See if that doesn't help harden it up. Anybody have any better ideas?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1791175   Click image for larger version.
ID:	1791176   Click image for larger version.
ID:	1791177   Click image for larger version.
  3. #278
    FenderBean's Avatar
    Join Date
    Feb 2006
    Clarksville , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    if u have a enclosed trailer or shed that is in the sun will help cure better. Humidity is most likely causing your paint problems, damp air is bad to paint in.
    Keith who?
    Xtreme ARF Rep
    Contest Director AMA # 8394
    FAA Registration # FA3W99AXCX
    https://www.youtube.com/channel/UCE_...BAxA8bHVCw3VQQ
    https://www.facebook.com/FenderbeanRCBuilds
  4. #279
    Join Date
    Mar 2006
    West KirbyWirral, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I will be interested in the weight of the model once assembled, lets know. I think we have all shared your heart ache having been there many times. I ended up ''peeling'' the soft paint off my BVM Sabre after six months of waiting till it hardened... it never happened. Hope you have more luck. A great model and well done, Ron.
  5. #280
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Setting the plane in the sun today has helped dry the blue paint. Only a few tacky spots left. Another day or two and I think it will be OK.
    I weighed the plane tonight at 5 1/2 lbs. I extimate glassing, priming, and painting has added about 1 1/2 lbs to the model. That seems like alot to me. The last time I weighed it was before the tailcone was sheeted and the canopy was made. At that time it was 4 lbs.
  6. #281
    Join Date
    Aug 2002
    Cincinnati, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry,
    I am betting that when all is said and done it will be right at 10lbs 12oz. That's my official guess.....any other guess.
  7. #282
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Is that with fuel Glenn?
  8. #283
    Join Date
    Aug 2002
    Cincinnati, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dry,....I believe that was about the weight of Bobby's F-100... I have spoken!!
  9. #284
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think I just got served! It's on now!
    Trimed the old canopy until I got a good fit. Then traced the perimeter onto the newer canpoy with a felt tipped pen. Cut it out with siccors and sanded the edges with 600 paper. This is an older canopy that I got from Glenn. It was used to make the plaster mold to vacuum form more canopies with. It is a bit scratched up but I decided to used it anyway.
ID:	1791759   Click image for larger version.
  10. #285
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Glued the canopy on with 30 minute epoxy all around the inside edges. Put a piece of wax paper under the hatch to keep it from getting glued to the fuse. Used some blue masking tape to hold the canopy in place until the glue hardens. I used too much glue but I didn't want to have any gaps around the edges.
ID:	1791761   Click image for larger version.
ID:	1791762   Click image for larger version.
  11. #286
    Xairflyer's Avatar
    Join Date
    Dec 2002
    Co. Donegal, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    what about the pilot?
    www.letterkennymodelflyingclub.com
    www.jmaireland.com
  12. #287
    Join Date
    Jan 2002
    Carrollton, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    As a suggestion, next time attach your canopy during or before the glassing stage so that it can be faired in smoothly and allow you to mask the canopy frame to be painted with the plane. Also, RC-56 canopy glue is spectacular at holding canopies down.
  13. #288
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I may put a pilot in latter. I have masked off the canopy and plan to paint around the edges. I don't plan to fair it in. It would look a little better but it doesn't look bad. I have tried RC-56 with mixed success. The last one failed so bad that I swore never to use it again. Epoxy works everytime.
  14. #289
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I spray painted around the edges of the canopy and also painted the inside of the inlets and exhaust nozzle. At least as far as I could reach with a small paint brush.
ID:	1792691   Click image for larger version.
ID:	1792692   Click image for larger version.
ID:	1792693   Click image for larger version.
  15. #290
    Join Date
    Oct 2007
    london, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    looks great
  16. #291
    Bob_B's Avatar
    Join Date
    Nov 2003
    Bluegrass State of Mind
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks great! youll have her done just in time for the cooler fall flying weather.
    2017 Fall Jet Classic - Event Dates October 4-7, 2017
  17. #292
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks guys. I can't wait to fly it.
    Glued on the control surfaces tonight. Had to do some sanding and fitting due to paint build-up. Used 30 minute epoxy with Robart hinges. Put glue in the holes with a toothpick first. Made sure I had plenty of glue in the holes for the elevator rods to slide in to. Put some oil on the just the hinge area on each Robart hinge before gluing to keep them free. Taped each control surface good and tight and waited for the glue to set.
ID:	1792936   Click image for larger version.
ID:	1792937   Click image for larger version.
ID:	1792938   Click image for larger version.
  18. #293
    Join Date
    Oct 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    BEEN A NICE THREAD TO WATCH -
  19. #294
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Had to switch over to digital servos and make new plywood servo trays. The analog servo on the retract would move when the receiver was turned on causing the gear to collapse. Put a digital servo in there and the problem went away. Also noticed the analog servos would not rotate as smoothly as the digital servos. The were more jumpy and twitchy. So I switched to JR 821 servos and they work fine. Soldered together the control cables and hooked everything up. Tested with the radio. Have a little bit more play in the rudder than I would like. The ailerons and elevator are not too bad. Just a little bit more play than if linked direct. This appears to be due to the gap in the tubes with the cables. For some reason the rudder has more play in it. Probably because it is the longest run of tube and has more bends in it as it snakes through the bulkheads. Getting about 1/8" or so play. Would like to know what others got. The cables are not sticky at all. Just concerned about the rudder at this point.
ID:	1795584   Click image for larger version.
ID:	1795582   Click image for larger version.
  20. #295
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are a few pictures of the cable connections to the control horns on the elevator and ailerons. These look better and work pretty good. Better than I thought they would.
ID:	1795589   Click image for larger version.
ID:	1795590   Click image for larger version.
  21. #296
    Love To build's Avatar
    Join Date
    Feb 2002
    Edison, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So how close is it to the maiden? With that 1/8" play, Can you see the cable housing through the fuse. I usually lock down the outer sheath of the cable with CA everywhere I can. Some models more then others. Same thing happens to me with the Sullivan NY-rods. Hopefully it will be another tack and it will be gone.
    M4A3, M41, Elefant, Marine M4A3, Building M4A1E8
  22. #297
    Join Date
    Sep 2005
    LondonSurrey, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Love the plane, love the thread, can't wait for the outcome!
    They were so popular in the late 80's and 90's, with the power of a 44 it will go like a missile!
    Paint job looks good, very slippery!
    JT
  23. #298
    Bob_B's Avatar
    Join Date
    Nov 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tlj125
    Had to switch over to digital servos and make new plywood servo trays. The analog servo on the retract would move when the receiver was turned on causing the gear to collapse. Put a digital servo in there and the problem went away. Also noticed the analog servos would not rotate as smoothly as the digital servos. The were more jumpy and twitchy. So I switched to JR 821 servos and they work fine. Soldered together the control cables and hooked everything up. Tested with the radio. Have a little bit more play in the rudder than I would like. The ailerons and elevator are not too bad. Just a little bit more play than if linked direct. This appears to be due to the gap in the tubes with the cables. For some reason the rudder has more play in it. Probably because it is the longest run of tube and has more bends in it as it snakes through the bulkheads. Getting about 1/8'' or so play. Would like to know what others got. The cables are not sticky at all. Just concerned about the rudder at this point.
    Terry it looks like your rudder cable comes up out of the fuselage at a pretty sharp angle. Then you're bending it with your horn placement.
    Robart makes a horn with a ball built into it and Hamilton Hobbies stocks them. I think if you change the horn position to match the angle of the cable you'll eliminate the slop to an acceptable amount.
    http://www.robart.com/products/58-ball-control-horns
    Looking forward to seeing your new jet fly so let know when you plan to do the maiden flight.
  24. #299
    Join Date
    Aug 2002
    Cincinnati, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry,
    I am getting excited!........it looks great. Let us know when. Don't forget to weigh it.
    Glenn
  25. #300
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bob- I agree the angle is not very good. It looks better when one of the inner holes is used. I move to the outer holes to see if it would help but it made no difference. I think that I am just going to have to live with it for now.
    Glenn- I weighed the plane tonight with most of the components installed except tanks and solenoid valves. Came it at 9.9 lbs. Checked the CG and it is about 1.5" back. I'll have to put some lead in the nose.
    Made a tray for mounting receiver, ECU, etc. It sets just above the servos. I'll have to cut the canopy floor for clearence for wiring and the main fuel tank. Here are a few pics.
    Current plan is to maiden at the DOGS show in Dayton on Friday.
ID:	1795943   Click image for larger version.
ID:	1795944   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
