If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 14 of 15 FirstFirst ... 412131415 LastLast
Results 326 to 350 of 369
  1. #326
    Join Date
    Aug 2002
    Cincinnati, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thorpe F-20 build
    Terry,
    The video did not work out, I will have to read the book about the camera.....bummer. I would call Ron Ballard or put a post in the turbine section, Ron usually responds very quickly to questions. The stumper is that it ran so well the first flight attempt.
    Glenn
  2. #327
    GrayUK's Avatar
    Join Date
    Oct 2003
    Dunstable, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Is this a gass start 44?
    If so, check you do not have your gass and fuel lines reversed.
    I have seen it before.
    Paul G
    no one told you when to run...
  3. #328
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Paul- it is a kero start but the lines are not backwards. No changes were made after the first run of the day and it went well.
    Glenn- If you read the book will the video work? I am sure Ron Ballard will respond quickly with- "Ship it to me". That's what usually happens. His turn around time is quick. I just hate paying the shipping costs.
    Ron Sweeny- I'll try your idea of jumping the pump with a battery. Seems like it is the problem at the moment. I'll check the solenoids again too.
    Bob- Aren't you the local Wren Rep? Just kidding. I am sure Ron can help me. He alsways does. Just trying to figure things out on my own first. Usually these problems are self inflicted.
    Terry
  4. #329
    Bob_B's Avatar
    Join Date
    Nov 2003
    Bluegrass State of Mind
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL:
    Terry
    I swear you told me the motor ran great on the stand?
    2017 Fall Jet Classic - Event Dates October 4-7, 2017
  5. #330
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And so it did! Three runs on the stand and all perfect. One run in the plane that was perfect. Then the problem occurred ending my day at the field.
  6. #331
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ron Ballard helped me get the Wren 44 going again by changing a few settings. Thank you Ron!
    Today was the maiden for my Thorpe F-20 Tigershark. And what a perfect day for it. Sunny, about 78 degrees, light winds pretty much right down the runway, not a cloud in the sky. I raised the nose gear strut about 3/8" to give more angle of attack for take-off from the previous attempt. Went down the runway at about 35-40 mph and lifted off at about 300 ft or so. Then it rolled to the left as it was out of trim. Got it to about 150-200 ft and slowed it down to about half throttle and started working on the trims. Had to give quit a bit of up trim and right aileron. I noticed pretty quickly that the ailerons had a dead spot around neutral which caused me some difficulty. I think this is due to the slop in the cables. It would tuck in the turns if you went to slow and weren't quick on the aileron return. Had to really stay on the ailerons. Elevator was fine. Flew around at half throttle and about 90-100 mph. Set up to land and that is when it got interesting. The dead spot got worse as the plane slowed. It swayed back and forth until touchdown. It slowed down more than I expected to about 30 mph and sort of dropped down the last few feet to the runway then bounced back in the air and came back down more gently. This plane needs more elevator! Second flight was better but I ran out of elevator on the landing again and bent one the the main struts. Third flight was better still and I did a few rolls. Very axial and straight without any tendency to barrel. I landed at a higher speed around 35-40 mph which helped. But still it swayed back and forth on the airlerons. Flight time from take off to touchdown was about 5 minutes for each flight. Fuel remaining at the end of each flight was about 16-20 ounces. Not bad. I think I will begin increasing flight time by another 30 seconds or so and see how it goes.
    After flying today I am convinced that these cables have got to go! I just have to figure out how to make that happen. Overall I am pretty happy. The plane looked good in the air and flew with authority. I did not try any high speed passes as I didn't feel comfortable with the ailerons around neutral. And it didn't seem like I had enough elevator throw. So I will work on that.
    Thanks to all those who provided helpful comments and advice and especially to the Thorpe Brothers for their design. If I ever get someone to take a video of me flying it, I will come back and post it. Good luck to others who build this plane. Of course, if anyone has any questions....
    Terry Jacobs
  7. #332
    juanjulian's Avatar
    Join Date
    Nov 2003
    guatemala, GUATEMALA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good job
  8. #333
    roger.alli's Avatar
    Join Date
    Aug 2008
    Sydney NSW , AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Glad you had success Terry.
    This has been a very interesting thread to follow. I really like this style of modelling. It is a rare thing you have created in a world of ARFs
    Thanks very much for taking the time to put it up for us.
    Roger
  9. #334
    Join Date
    Mar 2006
    West KirbyWirral, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry well done, a relief no doubt. Re elelvator response, have you checked your c of g? Re wren settings what did you alter,? Ron.
  10. #335
    Xairflyer's Avatar
    Join Date
    Dec 2002
    Co. Donegal, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Glad you got it flying after all your hard work.
    Only suggestion I could think of for the ailerons servos is to use two Hitec 5125 thin wing type servos, not going to be easy now to run cables.
    You could also try to support the inner cable more as it comes out of the wing & at the servo, or what about just changing the inners to like what are used on the sullivan cables rather than the bowden cable you are using.
    www.letterkennymodelflyingclub.com
    www.jmaireland.com
  11. #336
    Boomerang1's Avatar
    Join Date
    Jun 2005
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Congratulations Terry, I've enjoyed your build a lot.
    Hope you get it sorted soon. - John.
  12. #337
    Bob_B's Avatar
    Join Date
    Nov 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry congrats on the maiden. It is nice to see someone actually build and have success with their project. I'm sure you'll sort out the issues quickly and have it flying on rails! I should have payed attention to Mikes text saying the field was virtually abandoned yesterday.
    Bob
  13. #338
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for all the kind words. Here are a few more pics of the plane that might be helpful to other builders. CG was spot on where the plans call for it to be, 11.75" forward of the inboard trailing edge.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1802314   Click image for larger version.
ID:	1802315   Click image for larger version.
  14. #339
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A few more...
ID:	1802317   Click image for larger version.
ID:	1802318   Click image for larger version.
  15. #340
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ron- Here are a few pics showing the ECU settings that were changed. I increased each by 5 and the engine started and ran good. Shut it down, let it cool, then tried to restart. Got 6-8" of flame out the tail pipe on transition so I shut it down. Put the settings back to where they were and tried again. The engine started just fine. Shut it down and restarted again adn it worked well. Maybe something was stuck and came loose. Except for doing some popping on start-up, the engine is running fine now. Took it to the field and did the maiden without any further problems.
    Bob- you missed a great day at Joyce for sure. But there is always next weekend...
ID:	1802323   Click image for larger version.
ID:	1802324   Click image for larger version.
  16. #341
    Join Date
    Mar 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Terry, it looks as though you gave the pump a bit of a kick start, been there, done that, thanks, Ron.
  17. #342
    Bob_B's Avatar
    Join Date
    Nov 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry i noticed that your rx is very close to the ecu. It would be good if you can seperate them a bit more.
  18. #343
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bob- I agree. How much space do you think I need? I tried stuffing the RX further down with the battery but it was too tight.
  19. #344
    Bob_B's Avatar
    Join Date
    Nov 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    2-4" minimum if you have the space
  20. #345
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I now have 10 flights on the Thorpe F-20. Each flight I get more comfortable with it. I have done a few high speed passes at about 3/4 throttle and it appears to be going about 150 mph. Vertical performance is very good. At full throttle it goes straight up for about 1000 ft or so. I haven't tried to go higher as the plane gets small quick. It's still sensitive on the ailerons but I am getting use to it. Slows down pretty good for landing even though I do not have flaps. I comes in at about 1/4 to 1/2 throttle and nose high about two inches. Just enough to see the yellow on the bottom of the wings. If I don't see yellow, it is coming in too fast. Flight times are now 5-6 minutes with at least 10 ounces to spare. I'm really enjoying the plane. Everyone is surprised when they see that it is made of wood.
    Terry
  21. #346
    Bob_B's Avatar
    Join Date
    Nov 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Made of wood?? What is that! LOL
  22. #347
    Join Date
    Mar 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Terry, well done. I remember struggling with my JMP Phantom on landing approach and a full size Phantom pilot advised me that in real life if you could see the runway on finals then you were going to crash!! Keep you chin and your nose up. How about some video? Ron.
  23. #348
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ron- No one has shown up with a video camera as yet! As soon as I can talk someone into doing a video, I will post it. I'm sure you would like to see it fly. It looks similar to your videos at high speed but has beter take-off and vertical. Of course I try to land on the runway.
    Terry
  24. #349
    GrayUK's Avatar
    Join Date
    Oct 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well done.
    Nice job.
    I would get rid of the cables too!
    Paul G
  25. #350
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It will be a winter project for me. Already bought the servos and wire. Plan to fly it for now while the weather is still good.
    Terry
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
