If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 6 of 15 FirstFirst ... 45678 ... LastLast
Results 126 to 150 of 369
  1. #126
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thorpe F-20 build
    Per the Wren website, the Wren 44 burns 5.8 oz of fuel per minute at full throttle. My current plan is to install two 11 oz ducted fan tanks along with the 17 oz Kavan center tank for a total of 39 oz. Flying at or near full throttle would result in a 6.7 minute flight time. With some throttle management I should be able to get 7-8 minute flights.
    My concern with the 44 is performance at take off and going vertical. I remember Bob's F-100 and it flew with authority. What a neat model it was. I am currently flying a Tam F-16 with a Wren 75 and I would prefer better take off and vertical performance than that combo.
  2. #127
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ron- I fly from a paved runway. The video below was taken at our club field.
    http://www.youtube.com/watch?v=KOfn8LKozbc
  3. #128
    Join Date
    Mar 2006
    West KirbyWirral, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Terry, Good video. Personally I would be more than satisfied with a performance similar to your F16. I assume you have fitted a good thrust tube to maximise the available power. I imagine acceleration will be a little slower than the F16. I fly an Avonds F15 with a wren 70, great turbine. Ron.
  4. #129
    GrayUK's Avatar
    Join Date
    Oct 2003
    Dunstable, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The 44 gold will be perfect for this model.
    No issue at all.
    Paul G
    no one told you when to run...
  5. #130
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I plan to use a Tam pipe I got from Yellow Aircraft when I bought a Starfire years ago. It is rated for a 10-12 lbs turbine and the length is about right.
    Sheeting the main hatch with 1/16 balsa. First piece was the center section and it was glued and pinned with 30 minute epoxy while the hatch was in place on the fuse. The second sheet was glued with medium CA without being attached to the fuse. Sanded around the edges and the fit so far is pretty good. A bit concerned about the shape of the hatch when viewed from above. Has an hour glass shape. Probably would not have looked this way if I had built the hatch and sheeted it with the fuse and cut it free as described in the building instructions.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1707142   Click image for larger version.
ID:	1707143   Click image for larger version.
ID:	1707144   Click image for larger version.
  6. #131
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finished sheeting the hatch and rough sanded it for a tight fit. The hatch latch and locating pins work very well. This was different than what the plans called for. I decided to go this route to avoid having two hatch pins sticking out of the top of the model and to give the hatch a solid locating point.
ID:	1707211   Click image for larger version.
  7. #132
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sheeted the rear of the fuse that I was using for access to the hatch screws. Also sheeted the small flat area near the wing roots. Use 1/16 balsa and 30 minute epoxy.
ID:	1707504   Click image for larger version.
ID:	1707505   Click image for larger version.
ID:	1707506   Click image for larger version.
  8. #133
    GrayUK's Avatar
    Join Date
    Oct 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tlj125
    I would use a Wren tailpipe, very light, and more thrust than a Tam due to the way it is designed.
    You need to keep the weight down in the rear and get the engine as far forward as is reasonable.
    Price is around £50.0 i think, check with Wren they do different lengths.
    Paul G
  9. #134
    Join Date
    Mar 2002
    Colorado Springs, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tlj125
    You might want to consider a Wren/Wright pipe. Wren sells single wall versions, Gary Mueller at Jet Tech makes a dual wall that is super light, designed for the '44. You will see a 5% thrust gain over a straight '44 pipe.
    Greg
  10. #135
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Paul and Greg- Thanks for the info on the exhaust tubes. I realize there may be better exhaust tubes out there but I have already paid for this one. I am trying to keep cost low on this plane. If I like they way that it flies, I may make a mold and build another one out of fiberglass and go all out with it.
  11. #136
    Join Date
    Oct 2007
    london, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ron-hows the maverick?
  12. #137
    Join Date
    Mar 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Currently static. Just built a Quaker Flash and half way through a big Tucano during the recent non flying weather,,,,,,,,,,,,,,, but we digress.
    Terry what are you going to do about the hatch distortion. When I built mine I never thought of sheeting the fus'. I planked mine with 1/4 x1/8 strips. Your flying site looks great and should be great for the F20. I will be interested in your retract installation. A little bit of positive incidence in the ground angle will help with rotation. Ron.
  13. #138
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ron- I am not planning on doing anything about the hatch. Doesn't look that bad to me. Retracts will be Spring Air #305. Ordered them several weeks ago. They have not arrived as yet. Planking with thicker balsa sounds interesting. Would leave more material for sanding.
  14. #139
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Glued on the second base for the rear of the fuse. It is made from gluing together 3/8" x 4" sheets with medium CA and cutting to shape on plans. Then gluing it to the bottom of the fuse with 30 minute epoxy and pin in place.
ID:	1707902   Click image for larger version.
ID:	1707903   Click image for larger version.
ID:	1707904   Click image for larger version.
  15. #140
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Before making the ailerons, wanted to match wing tips and aileron pockets. Made a pattern from scrap balsa sheet of the wing trailing edge, wing tip, wing root, and aileron pocket. Then compared to the wings on the model. One side was close. The other was about 1/4" off. Glued some scrap balsa to the wing tips to make them longer to match the pattern.
ID:	1707909   Click image for larger version.
ID:	1707910   Click image for larger version.
  16. #141
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Trimmed and sanded the wing tips and aileron pockets. Made several measurements to check the accuracy of the wings and how they matched up from one side to the other. Got them to match within 1/16" feature to feature. Then traced out the wing tip on 1/16 plywood and cut the caps out on the scroll saw. Glued them on to the wings with 5 minute epoxy. Sanded them flush after the glue cured.
ID:	1708351   Click image for larger version.
ID:	1708352   Click image for larger version.
ID:	1708353   Click image for larger version.
  17. #142
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Made the ailerons from 1/2 and 3/16 x 4" balsa sheet sandwiched together with 5 minute epoxy. Fit them to the wing pockets and put two Robart hinges in each one. Put a piece of balsa shaving in the gaps at the trailing edges and touch zapped with thin CA. This holds the aileron in place during shaping and sanding.
ID:	1708357   Click image for larger version.
ID:	1708358   Click image for larger version.
ID:	1708359   Click image for larger version.
  18. #143
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Used a small hobby plane to get the left aileron into rough shape. Then sanded with 150 grit on an aluminum bar until flush with the wing.
ID:	1708361   Click image for larger version.
  19. #144
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Same method on the right aileron.
ID:	1708400   Click image for larger version.
  20. #145
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cut the ailerons free with a hand saw. Sanded bevels on the leading edges to get the proper throw listed on the plans- 3/8" up/down. Made control horn plates from 1/8 ply and carved out pockets for them in each aileron.
ID:	1708527   Click image for larger version.
ID:	1708528   Click image for larger version.
  21. #146
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Glued the blocks in with 30 minute epoxy. Made blocks for the elevator and rudder the same way.
ID:	1708530   Click image for larger version.
ID:	1708531   Click image for larger version.
  22. #147
    Join Date
    Mar 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry, happy new year. Don't worry about the lack of response, your building faster than we can post, great work. Ron.
  23. #148
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Ron. In case anyone is interested, the plane weighs 4 lbs so far.
  24. #149
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Removed the glue clamps and sanded the blocks to give a clean and flush feel. Dremel sanded the block if it stuck out too far. Mounted the control horns onto the ailerons, elevator, and rudder. Used #2 x 3/8 wood screws. Predrilled the holes with a 1/16 drill. Tried to line up each control horn straight with the control cable at the central position of the flying surface.
ID:	1708795   Click image for larger version.
ID:	1708796   Click image for larger version.
ID:	1708797   Click image for larger version.
  25. #150
    Join Date
    Mar 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cut former F12 from 1/8" plywood on the scroll saw. Traced the tailpipe on the ply to ensure a good fit. Used a sanding drum on the dremel to fine tune the fit. Glued in place with medium CA.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
