Thorpe F-20 build
Reply
Old 01-25-2012, 03:31 PM
  #176
picard1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Thorpe F-20 build
Great to here Pete is doing well...
Any chance of Sending me Pete's phone number via PM. I sure could use a canopy.
picard1 is offline
Old 01-25-2012, 03:38 PM
  #177
Love To build
Love To build's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Dave. Keep us advised on the parts. I could use some canopys for a F104 and the F20. Maybe he would like to set up a distribution entity in the US for plans and plastics.
Love To build is offline
Old 06-19-2012, 06:21 PM
  #178
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK. So now back to the F-20. Had a pipe left over from a Yellow Starfire that never got used. Cut it down with a dremel tool with cutoff wheel. Then made L shaped brackets from the cutoff piece.
ID:	1773966   Click image for larger version
ID:	1773967   Click image for larger version
ID:	1773968   Click image for larger version
tlj125 is offline
Old 06-21-2012, 02:07 AM
  #179
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wheels and brakes came in. Made a combination engine/ pipe mount and worked to get it lined up and true to the plane.
ID:	1774372   Click image for larger version
ID:	1774373   Click image for larger version
tlj125 is offline
Old 06-22-2012, 01:47 PM
  #180
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A few more pics of the engine and pipe mounting...
ID:	1774760   Click image for larger version
ID:	1774761   Click image for larger version
ID:	1774762   Click image for larger version
tlj125 is offline
Old 06-23-2012, 05:37 AM
  #181
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Didn't like mounting the pipe under the motor mount so I added a doubler to put the screws in from the top. Will also give more for the engine mounting screws to go into.
ID:	1774916   Click image for larger version
tlj125 is offline
Old 06-23-2012, 05:43 AM
  #182
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Started digging out the mounts for the retracts. Used dimension from the plans and made a starter hole with a dremel tool and sanding drum. Then made the hole bigger until I could determine where I was at. Saves making the wheel opening for last. Retracts are Spring Air 5/32 wire struts. I ordered 3/16 but received 5/32. Oh well. I am sure they will work.
ID:	1774918   Click image for larger version
ID:	1774919   Click image for larger version
ID:	1774920   Click image for larger version
tlj125 is offline
Old 06-23-2012, 05:47 AM
  #183
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Then dremel out for the wheel wells...
ID:	1774922   Click image for larger version
ID:	1774923   Click image for larger version
ID:	1774924   Click image for larger version
tlj125 is offline
Old 06-23-2012, 05:51 AM
  #184
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A few final touches, sanding here and there for clearance and free retact motion and done...
tlj125 is offline
Old 06-23-2012, 06:46 AM
  #185
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The front retract was more difficult. Since I wanted to use the sigle side steering version, the rails are higher. This created an interference with the servos and the wheel when retracted. Had to relocate the retract twice before finding a position that didn't interefere. It is close but it will work.
ID:	1774937   Click image for larger version
ID:	1774938   Click image for larger version
tlj125 is offline
Old 06-23-2012, 06:50 AM
  #186
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The F-20 standing on its new legs. Notice the slight positive angle of attack for the wings.
tlj125 is offline
Old 06-23-2012, 09:03 AM
  #187
thunderchief
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Terry, Looks great............keep on it.
Glenn
thunderchief is offline
Old 06-23-2012, 06:44 PM
  #188
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Glenn. Opened up the bulkhead to fit a 24 oz Kavan fuel tank. Used a dremel tool with a sanding drum.
ID:	1775098   Click image for larger version
ID:	1775099   Click image for larger version
tlj125 is offline
Old 06-23-2012, 06:49 PM
  #189
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Used a piece of balsa to act as a support for the tank to keep it from tilting down in the back. The air tank will go above the tank and keep it from tilting up in flight.
ID:	1775101   Click image for larger version
tlj125 is offline
Old 06-23-2012, 06:56 PM
  #190
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Added a plywood support for the back of the pipe to attach to. Glued in with 20 min epoxy. The screw is a #4 wood screw and washer. Redrilled the screw holes for the front tabs of the pipe so the #4 screws tighten from the top. The three screws hold the pipe very well. No additional support should be needed.
ID:	1775103   Click image for larger version
ID:	1775104   Click image for larger version
tlj125 is offline
Old 06-24-2012, 05:34 PM
  #191
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cut and glued in servo rails for the retract and steering servos. Then mounted the servos.
ID:	1775402   Click image for larger version
ID:	1775403   Click image for larger version
tlj125 is offline
Old 06-24-2012, 05:38 PM
  #192
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Made a support for the air valve from a plastic control horn. Mounted it to the servo rails and connected it with 1/16 wire to the servo control horn. Started plumbing the air lines to the retracts.
ID:	1775405   Click image for larger version
ID:	1775406   Click image for larger version
tlj125 is offline
Old 06-26-2012, 02:06 AM
  #193
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ran the airlines to the retracts. Kept them tucked in and out of the way by drilling small holes to run the lines through. Had to add one restictor in the line to slow the retracts.
ID:	1775860   Click image for larger version
ID:	1775861   Click image for larger version
ID:	1775862   Click image for larger version
tlj125 is offline
Old 06-26-2012, 02:13 AM
  #194
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Drilled the clearance hole for the steering wire through the bulkhead by hand. Couldn't get in there with a drill. Pretty tight. Started with a 1/16 then opened up to a 3/16. Soldered a threaded coupler onto a 1/16 wire. This will be the end that attaches to the retract steering arm.
ID:	1775864   Click image for larger version
ID:	1775865   Click image for larger version
ID:	1775866   Click image for larger version
tlj125 is offline
Old 06-30-2012, 09:23 PM
  #195
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Added a brass piece to act as a guide for the steering rod. Put a few bends in the rod to make it move smoothly from the servo.
ID:	1777356   Click image for larger version
ID:	1777357   Click image for larger version
tlj125 is offline
Old 06-30-2012, 09:29 PM
  #196
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sanded the pod on the back of the vertical stab before sheeting the exhaust nozzle.
ID:	1777359   Click image for larger version
ID:	1777360   Click image for larger version
ID:	1777361   Click image for larger version
tlj125 is offline
Old 06-30-2012, 09:36 PM
  #197
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Used some filler balsa around the exhaust nozzle to give more surface to glue the sheeting to. Sanded smooth with the last bulkhead and exhaust tube.
ID:	1777363   Click image for larger version
ID:	1777364   Click image for larger version
tlj125 is offline
Old 06-30-2012, 09:42 PM
  #198
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glued on some scrap balsa to act as a ledge for the 3/32 strips cut from sheet. A wider sheet just didn't want to wrap around the nozzle very well. Started gluing on the 3/32 strips.
ID:	1777366   Click image for larger version
ID:	1777367   Click image for larger version
tlj125 is offline
Old 07-01-2012, 05:40 PM
  #199
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finished gluing on the sheeting and started sanding the exhaust nozzle into shape.
ID:	1777671   Click image for larger version
ID:	1777672   Click image for larger version
ID:	1777673   Click image for larger version
tlj125 is offline
Old 07-01-2012, 05:43 PM
  #200
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More sanding...
ID:	1777687   Click image for larger version
ID:	1777688   Click image for larger version
tlj125 is offline
Reply
Display Modes
