Thorpe F-20 build
Reply
Old 07-01-2012, 05:48 PM
  #201
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Thorpe F-20 build
Started to plane and sand the bottom sheeting, 1st and 2nd base, into shape. The plans show a general outline of the shape but not very clear. Just have to do what looks about right.
ID:	1777692   Click image for larger version
ID:	1777693   Click image for larger version
tlj125 is offline
Old 07-04-2012, 05:32 PM
  #202
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Worked on blending the bottom of the fuse around the LE extentions, inlets, and nose. Plans are a little vague here as well. Roughed in with 100 grit paper. Just tried to make it look right.
ID:	1778692   Click image for larger version
ID:	1778693   Click image for larger version
ID:	1778694   Click image for larger version
tlj125 is offline
Old 07-04-2012, 05:37 PM
  #203
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Put some light balsa filler all around to try to blend sharp corners and fill holes and joints.
ID:	1778698   Click image for larger version
ID:	1778699   Click image for larger version
tlj125 is offline
Old 07-04-2012, 11:28 PM
  #204
ron Sweeney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can't beat some good old balsa bashing, this one brings back some great memories, Ron.
ron Sweeney is offline
Old 07-05-2012, 02:21 AM
  #205
Bob_B
Bob_B's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Terry youre almost there. Keep up the hard work.
Bob_B is offline
Old 07-05-2012, 05:36 PM
  #206
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ron- any advice on finishing this model? Plans are a bit vague on final shaping.
tlj125 is offline
Old 07-05-2012, 05:40 PM
  #207
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob- I appreciate the encouragement. Wanted to get it done in time for KY Jets. Not going to make it.
tlj125 is offline
Old 07-05-2012, 11:28 PM
  #208
ron Sweeney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finished mine in 0.6 ounce glass cloth and resin. I think there is a video clip posted earlier. Ron.
Old 07-06-2012, 02:10 AM
  #209
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ron- I meant as far as shaping. For example, the bottom sheeting where it mates with the tail cone and elevators. Not sure what to do there. Watched the video several times to figure out the bottom up by the inlets. The back of the plane wasn't as clearly shown though. I appreciate the help and positive comments.
Terry
tlj125 is offline
Old 07-06-2012, 12:21 PM
  #210
ron Sweeney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Terry, it was a long time ago that I built my F20. I don't remember what I had for lunch today!! I think the tail plane to fus' joint was square on top and blended with a fillet on the under surface. I think the rear outer edges of the fus' base were tapered into rear facing bullet pods. The BVM agressor and maverick illustrate a simple blend with their detachable tail cone. Ron. p.s. I have a half built thorpe F20 waiting patiently for completion.
Old 07-07-2012, 03:53 PM
  #211
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, Git-R-Done Ron!
Prepped the bottom of the model for glassing first. Got everything together and ready to start.
ID:	1779618   Click image for larger version
ID:	1779619   Click image for larger version
tlj125 is offline
Old 07-07-2012, 04:01 PM
  #212
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mixed 1 oz resin, 1 oz hardener, and 1 oz MEK to thin for brushing. Laid the 1/2 oz cloth over the model and brushed the glue through with a small paint brush. Tried not to use too much glue. I mixed just enough to do the bottom. Clean-up of the brush was done with MEK so I can re-use it. The glue is suppose to set in 20 minutes and cure in 3 hours. Mixing in the MEK slows this down. I extimate it takes twice the normal time. I will wait for tomorrow to glass the top.
ID:	1779631   Click image for larger version
ID:	1779632   Click image for larger version
tlj125 is offline
Old 07-07-2012, 04:04 PM
  #213
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A few additional pics...
ID:	1779634   Click image for larger version
ID:	1779635   Click image for larger version
tlj125 is offline
Old 07-08-2012, 05:09 PM
  #214
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Used a #11 exacto to trim the glass cloth. Then sanded the edges with 150. Prepped the top and started glassing the nose and wings.
ID:	1779998   Click image for larger version
ID:	1779999   Click image for larger version
tlj125 is offline
Old 07-08-2012, 05:11 PM
  #215
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A few more pictures...
ID:	1780001   Click image for larger version
ID:	1780002   Click image for larger version
tlj125 is offline
Old 07-08-2012, 05:14 PM
  #216
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glassed the hatch and flying surfaces...
ID:	1780004   Click image for larger version
ID:	1780005   Click image for larger version
tlj125 is offline
Old 07-11-2012, 06:12 PM
  #217
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glued on the front pieces for the vertical fin faring. Started carving and sanding into shape. Of course lots of sanding after fiberglassing.
ID:	1781017   Click image for larger version
ID:	1781018   Click image for larger version
ID:	1781019   Click image for larger version
tlj125 is offline
Old 07-11-2012, 06:15 PM
  #218
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A few more pics...
ID:	1781021   Click image for larger version
ID:	1781022   Click image for larger version
tlj125 is offline
Old 07-12-2012, 12:40 PM
  #219
John Tancock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have followed this thread all the way along, and your build/building skills are impressive! It's been a joy to follow so far, I'm sure this will go well on the MW44 (Ballistic I think)!
Keep the good work!
All the best
John.
John Tancock is offline
Old 07-12-2012, 06:05 PM
  #220
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks John. I hope it has good speed and vertical performance.
Marked and carved on the faring more tonight...
ID:	1781263   Click image for larger version
ID:	1781264   Click image for larger version
tlj125 is offline
Old 07-12-2012, 06:08 PM
  #221
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sanded it into rough shape...
ID:	1781266   Click image for larger version
ID:	1781267   Click image for larger version
tlj125 is offline
Old 07-15-2012, 06:13 PM
  #222
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More glassing on the top and rear of the plane. Also glassed the inlet lips on the front where it is balsa.
ID:	1782330   Click image for larger version
ID:	1782331   Click image for larger version
ID:	1782332   Click image for larger version
tlj125 is offline
Old 07-15-2012, 06:16 PM
  #223
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More glassing pics...
ID:	1782336   Click image for larger version
ID:	1782337   Click image for larger version
ID:	1782338   Click image for larger version
tlj125 is offline
Old 07-15-2012, 06:18 PM
  #224
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And a few more...
ID:	1782342   Click image for larger version
ID:	1782343   Click image for larger version
tlj125 is offline
Old 07-16-2012, 06:05 PM
  #225
tlj125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sanding, sanding, sanding...
Ordered paint tonight from Klass Kote. Anybody have experience with this type of epoxy paint? I really liked their website. Lots of info and testimonials. Picking out what I needed seemed not too difficult. Would like to hear from others on what they have experienced with this paint.
If all goes well, I'll be spraying primer over the weekend!
Terry
tlj125 is offline
Reply
Display Modes
