Reload this Page >
Skygate/CARF Viperjet
Old 07-10-2021, 03:12 PM
  #701
ECalderon
ECalderon's Avatar
Hi, I also fly ate 600 mt above sea level. My landing flap is about 65º-70º and I use about 5 mm crow with elevator mix (about 2 mm up elevator) only for landing flap. I have a Jet Central Cheetah 160. For landing, on upwind I lower the gear, when it is down I go to take off flap ,and once in downwind go to landing flaps between 1/4 and half throttle depending on wind. On final I keep the throttle at about 1/4 managing altitude with throttle so that it touches down a little past me. When I know I have reached the runway I go to Idle, usually at about 2 mt altitude. Some time we have a lot of wind and to bring it in throttle on final has to be more, it slows almost to a crawl with no bad habits.
Regards
Eduardo
DenisFerrari (12-23-2021)
Old 07-10-2021, 11:07 PM
  #702
Dave Wilshere
If you have 2mm UP mixed with flap you are running nose heavy.
The Viper’s huge tail hides this situation well, it’s why people have been flying this aeroplane nose heavy since it was designed.
Dave
DenisFerrari (02-01-2022)
Old 03-25-2022, 08:02 AM
  #703
Hans Hilmar
Hi Guys,
Very helpful tread, thanks for that! Just a quick question, what size pilot will fit this plane?
Hans
Old 03-25-2022, 08:16 AM
  #704
Asif
My Feedback: (30)
Originally Posted by Hans Hilmar
Hi Guys,
Hans
I have 1/4 scale pilot from warbirdpilots.com The pilot is 15" tall and fits just fine in my Viper.
https://www.warbirdpilots.com/Search...ilot-Red-White
DenisFerrari (03-25-2022)
Old 03-25-2022, 08:21 AM
  #705
Hans Hilmar
Thank you so much!
BR. Hans
Old 01-20-2023, 06:51 AM
  #706
Dave Wilshere
Near 10 year old CARF Viper brought up to date. It was in quite a state when it came to me for a running issue. Cleaned and polished, new canopy, totally ripped out and re wired with Powerbox wire, Mercury fitted, changed to Core. Fuel system was rebuilt and turbine serviced at JetCat. Ready for another 10 years!
The following 2 users liked this post by Dave Wilshere:
DenisFerrari (01-20-2023), paulhat (01-20-2023)
Old 02-27-2023, 10:36 AM
  #707
Dave Wilshere
Test flight done…does not look it’s age!
DenisFerrari (04-03-2023)
Old 02-27-2023, 11:15 AM
  #708
A7Bldr
My Feedback: (40)
Dave, I bet by now you can test fly these "Blindfolded".
Jim
Old 02-27-2023, 02:04 PM
  #709
Bob_B
Bob_B's Avatar
Dave is that a 2m Viper Jet
Old 03-03-2023, 12:04 PM
  #710
Dave Wilshere
Jim
Jim
Yep…probably don’t even need to be on the airfield 🙂 Set up correctly they are just like flying a leather arm chair. The owner will be shocked when he next flies it as I moved around 12oz of batteries from the nose and put them by the fuel tank! It flies even better with a correct balance.
Bob, no CARF Viper’s are all 2.6m
Old 09-07-2023, 09:06 PM
  #711
damagedgoodes
Default Help with Unilight installation
Can anyone help with spar position in the wing please and how you routed the cable? I’d like to install Unilight nav/strobe units on the ends of the wings but I noticed the wing is sealed outboard of the aileron servo. I also want to make sure I’m either in front or behind the spar when I cut a slot in the wingtip. Any help would be appreciated.
Old 01-08-2024, 06:57 AM
  #712
Dave Wilshere
DenisFerrari (01-08-2024), Hans Hilmar (01-08-2024)
Old 01-08-2024, 07:38 AM
  #713
A7Bldr
My Feedback: (40)
Love it when you skid around the corner with the rudder on the slow passes!
Bob_B (01-09-2024)
Old 01-08-2024, 09:48 AM
  #714
Dave Wilshere
There was a cross wind that day from memory, but slow turns with a jet is all about the rudder…it’s why so many run into trouble trying to fly slow, they just use aileron!
DenisFerrari (01-11-2024)
Old 01-09-2024, 05:25 AM
  #715
jvaliensi
Do these photos help?
https://carf-models.com/en/products/viper-mk2
