Double up bandit ARF rear flex plates ?
My Feedback: (12)
My fields taxi ways are real rough. After 2 days of flying I notice the rear main flex plates are cracked. When the plane is full of fuel and smoke it puts a lot of stress on them. Has any one doubled the rear plate? I know it I go off the runway it might crack the wing. Thanks Dan Avilla BVM rep
RE: Double up bandit ARF rear flex plates ?
I've doubled up the rear plate and it works great. I always fly off grass with it and am yet to have cracked the main plates.
ORIGINAL: Andrew Bird
This BARF has been flying since 2006 and I added a second plate across the top of the retract rail, rear only. I didn't want to make it too strong and damage the wing, by doubling the rear it stops the unit going through the top skin. We have several like this in the UK and the worst it does is brake the cover plate...and that was a guy who did a really bad arrival...
Dw
I used the same tactic on my Super Bandit and it also worked very well (although I'll admit to stealing the idea for that from Geoff White).
ORIGINAL: bidrseed2
Why only the rear, why not both plates?
D
My Feedback: (57)
BARF flexplates DO have doublers. You mean adding one more? I would not double the area around the plate mounting bolts, I would want it to break as designed. I broke the hardwood frame on mine because I had doubled up and it wasn't a fun repair.
Replacing flexplates is easy compared to repairing the frame they attach to.
David
David
ORIGINAL: FalconWings
David
David
Dw
I built the model 5 years ago, I don't remember, but it never broke a plate in hundreds of flights...
Probably it had them, it was one of the very first batch of BARFS released.
Dw
Dw
It's got the doubler - it was there when I took the old gear legs out and put the trailing links on for grass ops.
Interestingly enough, I bought the BVM Barf main gear door upgrade for the plane. They supply it with balsa blocks to go under the main flex plates, presumably to strengthen the area and stop the gear puncturing the top wing surface if things go wrong. I think Dave's solution is a good one though. The plates are only doubled up on the rear plate, allowing the front to fail first and the gear to pull back and out of the plane, rather than up and through the wing skin. I've got a fair few flights on the plane now and have yet to have had to touch the plates, so it seems to work very well.
ORIGINAL: AFTERBURNER1
Or just get an Ultra Flash and a set of pro links and never worry bout those plates again...[X(]
Sorry Danjo,,,, couldn't resist!!
Dan, even with pro link struts, are you breaking flexplates? I haven't broken a flex plate since I've switched to prolinks.
Raf
My Feedback: (80)
CA
ORIGINAL: ravill
Cause then He'd have a flash instead of a REAL airplane Dougie. That's why!
Raf
Raf
Yup,,,, I've had two of em... C'mon Raffy boy!!!! Let's go runnin and pullin in the corners and see who makes it around the bend without da clappasarus!!! Doooooohhhhhhhhh. To boot. The new Ultra flash flys all day long as good as the bandito for half the jack... Oh yeah,,, did I mention two bolts to fasten the wing????
