FEJ F16 1/5.5 with slats, speed brake etc
Hi All:
NewFEJ F16 1/5.5 scale withleading slats, speed brake and chute functions.
Dry weight is about 19-19.5 KG with new P180RX or Behotech JB180or similar engine.
some photos
PS: Company also offers servo installation service if needed.
Slats photos
some photos
Slats photos
RE: FEJ F16 1/5.5 with slats, speed brake etc
Fender:
Yes, your are right.
No more servos or servo wire or pushrods on wings for F16 1/5.5.
Very easy to put wings onto fuselage.
James
James
I like the idea, would like to see how it works. The only thing I would be worried about is any kind of play. Great idea, no linkage a more solid wing and you save a little weight. 42 - 43 pounds dry is nice for all the options
ORIGINAL: FenderBean
I like the idea, would like to see how it works. The only thing I would be worries about is any kind of play. Great idea, no linkage a more solid wind and you save a little weight. 42 - 43 pounds dry is nice for all the options
Byron had a very bulky square rod fitting tightly into a control horn inside the plane
there is no play on that. We have very hard aircraft plywood with extra ABS glue on that area to prevent that.
Hi All:
All new FEJ F16 1/5.5 scale model.
Now, we offer electric gear to come with the model together. See some gear photos.
The new gear has been upgraded to be much beefy with electric fucntion.
electric gear video: http://www.youtube.com/watch?v=76yohLn9Fak
heavy landing test: http://www.youtube.com/watch?v=Xbt_4...ature=youtu.be
PS: Strut with air pressure, no spring.
some more photos for new F16 1/5.5 version
and a video: http://www.youtube.com/watch?v=auQ8h_nbDEw
Yes, gear doors will be electric doors together too.
see video: http://www.youtube.com/watch?v=52sRW...ature=youtu.be
electric gear and electric doors will come with F16 1/5.5 automatically without extra fee.
James was that K170 in the 1/5.5? if so thats a super light bird thats the same turbine I have in my 1/6. Awesome setup does the control box offer a gear door sequencer?
Well if I manage to sale mine at KY jets it shall be mine!!! You know I have been wanting the 1/5!!!!!!
I really like the way FEJ has done the electric gear, the threads go in and out of the actuator! The gear door struts look nice and scale and beefy!!! And no extra fee for the electric!
That was going to be my next question but still even with all the bling a 40+ thrust class would be more than enough [:-] From the pics it does not have the options.
ORIGINAL: Wap4life
Great!
In the video w/ the k170 does that model has all the options, leading edge slates, chute, speed brakes?
Great!
My down and locked version does not wear at all, these parts turn so slow and with proper grease I have no wear at all in mine. I would dare to say you will probably never have to replace them for wear. I have about 25 flights on mine with probably 100 cycles over the time I have had mine.
ORIGINAL: bluescoobydoo
how many cycles has the electric gear been put through ,when testing does the screw thread wear much?
Hi All:
Company will have one electronic valve to work with electric gear, gear doors set. This valve will work as 5 way valve (EV5U valve).
The valve will have LCD display and timer set up for every single gear and gear door. The valve will work well for different size of electric gear.
valve also has mode 1 and mode 2 choice. (mode 1 is regular function, but mode 2 is used to for those models that need to close doors after gear down)
James
Bad boy James!! why couldnt you release all these features 6 months ago?!! Can i sent back my 1/6 scale and get the new one??
vey nice indeed!!!!!!!!!
Nicos
Nicos
