AMT Mercury bearing replacement UK?
Hi guys,
My old AMT air start Mercury is due a bearing replacement ... is there anybody in the UK that can do this with a rebalance ... I am in two minds as wether it is worth sending to AMT as cost is almost unjustifyable ... (and im skint)
Any info on bearing sizes etc and if there is a place in the UK that can suppl the bearing and or fit them and rebalance that would be great.
Scott.
Scott.
CT
RE: AMT Mercury bearing replacement UK?
Scott, AMT USA is now US mirco jet. I'm sure they would be more then happy to take care of your engine. Flew both my 180 and 280 this weekend both air starts.
Give Russ Adams a call 888-894-5387, 900 Glendale-Milford Rd, Cincinnati OH 45215. they have done berrings in both my engines recently and I must say they did a super job.
Jeff Lynds
Jeff Lynds
TX
stay a way from us microjet they screw me 2 mercury spend over $2,500.00 and 2 pegasus 280 , after they do work on it turn out junk !! ether you send it to Netherland AMT if you can, they will take good care for you or get another the brand of turbine ,US Microjet ? good luck to you my friend be cause you really needed!
My Feedback: (13)
ORIGINAL: tuan lam
ORIGINAL: chrigui
recently i changed bearing in a old OLYMPUS price 63 euro each...
i rebalance the engine with my sheck balancer machine
Thanks for posting, did you by anychance take any pictures when you were dissasembling it etc? It would be nice to know what im up against ...
Is the sheck balancer commerically available?
Any further information would be very helpfull in my descision as to tackle the job myself or not.
Best regards,
Scott.
i'm repairing olympus
changed compressor ( the previous compressor was not original)
changed bearing with GRW ceramic full complement ball (previous was standar steel!!)
changed intake cone
shenck
amt
changed intake cone
shenck
amt
They sound noisey, very much so compared to my jet cat and the wren .. and they stick some times more often than never []
Scott.
Scott.
My Feedback: (7)
ORIGINAL: siddus74
Scott.
Scott.
Danno
The turbine runs great, I wouldnt say that the sticking was in a particular place at all and when I flick it over by hand its mint and always starts on the money.
From the pictures I can not see and fixing to hold the rear of assy in the can, does it just push in and then is fixed only at the front?
I wish we had like Chrigui in the UK.
Regards Scott.
Regards Scott.
ORIGINAL: siddus74
Regards Scott.
Regards Scott.
what is that you don't see in the assembly?
Its not clear how the rear of the turbine assy is attached, my can is doesnt have any rear external fittings visable like the wrens and the jetcats.
Some great work, very inspiring ...
Scott.
Scott.
From the cut away view it looks like the entire inner assy slides out of the case forward?
Scott.
Scott.
Scott
are you sure it needs bearings? Bennie once told me he has never had to change a Mercury bearing unless it's had a lube problem or crashed.
BTW, I have changed bearings on a Mercury before and I got them directly from AMT in the Netherlands and the engine was hand balanced fine.
Jason
Jason
ORIGINAL: siddus74
Scott.
Scott.
Thats right, but can be difficult to pull apart so I made a tool that bolted inplace of the inlet. This could be held in a vice or pulled by another person. The one ne I did needed heat on where the NGV slides in the case to get apart.
Jason
Jason, your not that far from me ... I dont like to ask but if I can get some bearings and give you some cash - drive down etc etc could you give me hand?
Interesting you should say that they never need replacing? mine do sound rough and do stick .... a lube problem ... hmm - not sure where that leaves me ...
Any more interesting info Jason?
Scott.
Scott.
ORIGINAL: Ruizmilton
Sides:
You can get the bearings from WrenUK or directly from GRW in germany, the part number is D608/602, The size is 8mm x 22mm x 7mm, I can later tell you how to remove the case...
Sides:
Best regards,
Scott.
ORIGINAL: siddus74
can you tell me how to remove the case please?
Remove cap head screws round periphery of case and glow plug.
Best remove anything that can melt on front of can, eg FESTOs.
Warm up case especially NGV area and pull. Be carefull not to destroy the large O ring that seals the front of the case.
(Unless you have a lathe and can make up a mandrill in place of the bell mouth.)
GOOD LUCK
ORIGINAL: chrigui
you can use also GMN (fitted in most jetcat) code HYS608CA7
PA
ORIGINAL: chrigui
changed intake cone
shenck
amt
changed intake cone
shenck
amt
Hey... do you have a big version of the AMT cutaway???
