Reload this Page >
removing aeropoxy from painted surface?
Old 10-30-2011, 09:32 AM
S HARRIS
Default removing aeropoxy from painted surface?
Anybody had any luck getting a fingerprint off a painted surface? Its a factory painted SM Hawk if that matters.Thanks Scott
Old 10-30-2011, 09:35 AM
bevar
My Feedback: (27)
bevar's Avatar
Default RE: removing aeropoxy from painted surface?
Scott,
I have been successful with rubbing alcohol.
B
Old 10-30-2011, 11:53 AM
Greg Wright
Greg Wright's Avatar
Hey scott if it's dried on you are 'SOL' unless you try wet sanding with like 3000 wet dry and then rebuff that area maybe. If it is wet just wipe with alcohol. And i don't mean MOONSHINE either.
Old 10-30-2011, 12:39 PM
rcpete347
My Feedback: (251)
rcpete347's Avatar
HI Scott, a couple of points
1-when ever you rub the surface with rubbing alcohol or Varsol, you will have to apply a finishing compound to bring back the gloss.
2- Aeropoxy can be removed with heat, but you have to be really cautious. You can open up a fuel tank, that was joined together with aeropoxy, with a hot air gun, bin their.
3- It is best to find a scrap part, with some aeropoxy on it, and try that first
just my 2 cents
Rcpete
PS, I know the finger print can drive you nuts, but the heat could warp the surface.
Old 10-30-2011, 01:54 PM
shepp
BOZO !!!!!!!
If it is dry, try raising the aeropoxy with your fingernail. Many times epoxy will not stick to a slick surface.
Glenn
Old 10-30-2011, 04:15 PM
KC36330
3M Black Beauty will take it off with a little elbow grease and preserve the shine. to save this happening in the future, a few coats of wax on painted surfaces before starting assembly keeps most of these type glue accidents off the paint.
Old 10-30-2011, 05:15 PM
causeitflies
causeitflies's Avatar
My SM came from the factory with fingerprints already applied... and it wasn't even the pro version
Old 10-30-2011, 05:23 PM
FenderBean
FenderBean's Avatar
I have to laugh about that, since I know your pain. If it's on top of clear coat try to get something with a sharp edge to lift it up. If it's in a area of flexibility that makes it even easier.
ORIGINAL: causeitflies
Old 10-30-2011, 07:19 PM
S HARRIS
Thanks guys for the tips, BOZO? Did someone say wing tube? LOL Luckly for me it's only on the bottom of the wing. Not my first rodeo. Just thought somebody with the magic stuff would jump in. Thanks again to all even you "Shepp" [8D]
Old 10-30-2011, 07:32 PM
DavidR
ORIGINAL: S HARRIS
Thanks guys for the tips, BOZO? Did someone say wing tube? LOL Luckly for me it's only on the bottom of the wing. Not my first rodeo. Just thought somebody with the magic stuff would jump in. Thanks again to all even you ''Shepp'' [8D]
It's a scale airplane......weather it!
DR
