Kingtech K-140E/F owner
Reply
Old 11-14-2011, 01:16 AM
passagealanglaise
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Kingtech K-140E/F owner
Hello
I thought it may be interesting for the K-140E/F owner to share some information about the setting
I have 2 - K140F, both on 2S - 4000mha.
The Factory Setting are :
Menu Start :
Auto +2
Pump Start Ramp 5
Glow Power 7V
Low Batt 7V
Start Power Ignit 130
Starter Power Fuel Ramp 110
RPM 100% Starter 17000
RPM Stop 20000
RPM Reconnect 18000
RPM Ignition 3000
Pump PW Ignition 18
Engine Min Flow 50%
EGT End 120°C
RPM Preheat K 5000
RPM Fuel Ramp 6000
Preheat Fuel 45%
Ignit Time Out 27s
Start Mode AUTO KERO
Menu Run :
Full Power 120000
Idle SPeed 33000
Stop Peed 20000
Start Min 100°c
Max temp 844°C
ACC DELAY 8
DEC DELAY 5
Stability Delay 100
Pump Limit 448
My Setting :
[youtube]www.youtube.com/watch?v=yyONsjjlTAM[/youtube]
An exemple of start :
[youtube]http://www.youtube.com/watch?v=WPMK_..._order&list=UL[/youtube]
and an other exemple :
[youtube]http://www.youtube.com/watch?v=3tW1b..._order&list=UL[/youtube]
Hope that interest you...
passagealanglaise is offline
Old 11-14-2011, 05:33 AM
ddlstang
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Kingtech K-140E/F owner
You need more battery, Kingtech is recommending a 9.9v life or the Nihm.
ddlstang is offline
Old 11-14-2011, 07:27 AM
SniperWj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how bout 3s lipo?
SniperWj is offline
Old 11-14-2011, 11:02 AM
passagealanglaise
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No lipo on 3S with the ECU
With this setting works perfect on Lipo 2s but with min 4000mha
I consume 370mha per fly actually
Old 11-14-2011, 02:32 PM
ddlstang
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was running a 2S LiIon - 43mah, Barry had me switch to the 7cell Nihm which improved the start dramatically. You could tell the starter sounded stronger also during the start. I could get about 3 starts out of the LiIon but with the Nihm 5-6 is easy.
ddlstang is offline
Old 12-05-2011, 06:39 PM
mun_iz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I am about to purchase a K140 and would like some help in deciding on either a K140E or K140F. I will use the engine to power a CARF Flash. I would prefer automotive diesel as the fuel of choice.
From previous posts, I had gathered the following information:
K140E
Pros
- No changes in factory default parameters to run diesel.
- No special battery requirements.
- Low risk of hot starts with proper precautions taken during refueling.
- Faster start ups.
Cons
- Need separate gas can for starting
K140F
Pros
- COOL FACTOR...
- No need for start up gas.
Cons
- risk of hot start (fire) after a failed start (need help to verify this... can someone help advise?)
- Need to tweak parameters for smooth starts. (not an issue)
- Need 3S LiFe pack
- Slower startups
I like the autostart feature of the F version (the cool factor). Since the turbine compartment is not accessible in the Flash once the wing is attached, I am very concerned with hot starts, kero sprays and long flames.
Can K140 owners help advise?
Many thanks in advance.
Isaac
mun_iz is offline
Old 12-06-2011, 04:54 AM
franktcs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just go for the cool factor[8D]The fueling can be fine tuned to eliminate hot starts
franktcs is offline
Old 12-06-2011, 05:15 AM
rolsen12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a 140f and had some problems with startups. The cure for this is to make sure that you prime the burner fuel liner up too the engine before atempting to start the first time.
Once that line is primed the engine will start every time without fail. Also, set the throttel to half expo. It makes a fast responce.
rolsen12 is offline
Old 12-06-2011, 06:02 AM
mun_iz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi, thanks for the tip.
By half expo, do you mean the throttle setting in the ecu?
Also, does anyone know if a K140E can be converted to a K140F?
mun_iz is offline
Old 12-06-2011, 06:44 AM
passagealanglaise
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello
Yes it's possible to upgrade an E version en F but I think it's more interesting to use an F version.
Look at mine on 2S.
http://www.youtube.com/watch?v=FiX3d...&feature=g-all
and I confirm that once thr line is primed the engine will start every time without fail.
Old 12-06-2011, 09:11 PM
marquisvns
marquisvns's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: passagealanglaise
Hello
Look at mine on 2S.
An E can't be upgraded to an F without gutting out all the innards, that said, we still be happy to provide a trade-in for those wish to upgrade to a fuel start KingTech.
Thank you,
Barry
marquisvns is offline
Old 12-08-2011, 10:30 AM
tony5548
tony5548's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flap test fails,Shows the importance of jet turbine acceleration.
I trust K-140F.
[youtube]http://www.youtube.com/watch?v=RJY7BO34_aM&feature=channel_video_title[/youtube]
tony5548 is offline
Old 12-08-2011, 10:46 AM
marquisvns
marquisvns's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Congrats Tony, nice take off and landing, considering the IDF main gear locations and no flaps? wondering if you could move the mains forward...
Old 12-08-2011, 11:05 AM
tony5548
tony5548's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found that the size of the model can not use the landing flaps.
Thank you,
Barry
tony5548 is offline
Old 12-09-2011, 03:43 PM
RCKen.
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will this engine fit in the plane I build see pic below
RCKen. is offline
Old 01-14-2012, 04:23 AM
passagealanglaise
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do other owners could compare kingtech K140-f setting?
For the Star menu and Run menu?
Old 01-14-2012, 08:21 AM
AndyAndrews
AndyAndrews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: tony5548
Thank you,
Barry
Maybe reduce the flap throw? Yes and I had a similar situation with my Skymaster F4 Phantom. Stalled it out inverted and the only thing that saved it was the near instant power my K-170 gave me. These are great turbines.
AndyAndrews is offline
Old 01-14-2012, 01:04 PM
ModellbauUK
ModellbauUK's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thinking of fitting a Kingtech K140F in a Jet Legend F15C. Any thoughts?
ModellbauUK is offline
Old 01-14-2012, 01:07 PM
KC36330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: ModellbauUK
i think the 140 would be a good choice, I've got a Titan SE in mine.
KC36330 is offline
Old 01-14-2012, 01:21 PM
passagealanglaise
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use 2 k140F
One in a Rafale Xtremjet
one in a l39 jetlegend 21kg take off
Old 01-14-2012, 01:29 PM
ModellbauUK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Should be fine in the F15c then?
Old 01-14-2012, 02:25 PM
KC36330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes.
KC36330 is offline
Old 01-14-2012, 03:26 PM
tms261
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Howdy, Reaction X has made it to Alaska on its way here to east coast. Should be here Tuesday. Still have not bought turbine but leaning towards the k140 still. Not decided on retracts either. I like the Electrons for simplicity, but properly done air may be more reliable and Prolinks complete set for Reaction X is less expensive.
It's 38 degrees here and 15-20 mph winds. Weather has sucked lately and havent been out to fly for 5 weeks now. My best flying buddy will not fly if its below 45 and full sun. For him wind has to be 0-10 mph. Usually I dont go unless he is, but that may have to change or I may never fly again! Flown any of your jets today?
tms261 is offline
Old 01-14-2012, 03:31 PM
KC36330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tim,
flew my K170 powered Flash today, was 28 deg and 10-15 winds, didn't make it an all day event but got in some stick time none the less.
KC36330 is offline
Old 01-14-2012, 03:36 PM
tms261
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oops, meant to PM that! Sorry KC.
tms261 is offline
