If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 251 to 275 of 276
  1. #251
    Jim Cattanach's Avatar
    Join Date
    Mar 2003
    Larnaca, , CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: GRYPHON - build thread (sports/trainer 2m composite jet)
    Finished building the Gryphon today. It is powered by a Merlin VT80.
    With 500grams of lead in the nose, along with a 4000ma ECU battery & two 2.2ma Rx batteries, it weighs 8.8Kg with full UAT.
    Unfortunately the weather is unusually bad for Cyprus over the next few days, so the maiden will be delayed.
    In a weeks time, I am also having a part removed (gallbladder), so more delay.
    JET FLYING:- Resistance is futile. You will be assimilated.
  2. #252
    Join Date
    Mar 2005
    GhajnsielemGozo, MALTA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Jim,
    am also waiting to maiden mine when our site is in a better state! However mine came out to 11kg with an AMT Mercury!! I have around 450gr of lead in the nose, and have moved the turbine about 2.5cm forward. I also changed the rather heavy tailpipe to a lighter one. Has anyone's weight come out to 11Kg? Any chance of some info about the model's flying characteristics at this weight?
    Thanks and best regards
    Joseph
  3. #253
    Migf117's Avatar
    Join Date
    Sep 2005
    Perth, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Joseph
    mine is 10.8Kg so very close to yours, it flies like a fast pattern ship.
    very stable, I think at this wight give it a bit of ground speed before you pull the stick (that is what I do) so you get a smooth & scale like takeoff.
    the landing speed is not high, I mixed a bit of up trim with the flaps, it doesn't pick a lot of speed if the nose dropped a bit on the landing.
    the stall speed is quit low.
    I fly it just like flying a pattern ship even I do the basic routine of the IMAC with & it dose it perfectly.
    good luck with your maiden.
    Regards
    Moatasem
  4. #254
    Join Date
    Mar 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Moatasem,
    thanks for the info, will let you know how it goes.............
    best regards
    Joseph
  5. #255
    Join Date
    Sep 2004
    Sydneynsw, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Guys,
    What throws are you running for sport flying and also C fo G.
    Cheers, Craig.
  6. #256
    Join Date
    Mar 2003
    Larnaca, , CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lost my Gryphon yesterday. It had about ten flights on it. It was a nice & easy jet to fly. I started an Immelman turn, with good speed, at the top of the turn all control was lost & the jet spiralled to the ground. All the control surfaces are fine, as are the servos. I can only think that the large wings blocked the airflow over the elevator, the jet stalled & went into the spiral dive.
    I have seen a similar thing happen on Viperjets. Just a point to watch out for.
    This post is just to warn others, not to complain.
  7. #257
    Join Date
    May 2010
    Herveybay, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Is there any info on the orion jet , how to find price , avaliability , more pictures , colour schemes ?
  8. #258
    marc s's Avatar
    Join Date
    Jan 2007
    farnborough, , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes indeed please email me - note you are talking the Orion which is a different jet to the one on this thread?
    marcs
  9. #259
    Join Date
    Jan 2004
    Irvine, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Marcs
    I am testing a different set of landing gear for other Gryphon. What landing gear do you recommend? I am thinking about using electric version.
    Mike
    Global Jet ARF PRO, Air-C-Race-Germany, CNC-Italy, Feibao, Der Jet, Jet Legend, Flying Legend, Xcalibur, Skymaster & more - globaljetclub.com, we keep our members flying
    UAS CERTIFICATE NUMBER: FA34E9PRFE
  10. #260
    marc s's Avatar
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Electron 50 series electric retracts and jet1A legs and wheels - very good combo.
    marcs
  11. #261
    ceffi's Avatar
    Join Date
    Dec 2003
    34590 WabernEurope, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Mike,
    Dirk and I ordered yesterday an Electron 40, should be strong enough.
    Legs, Brakes and Wheels from Gaspar.
    Will keep you informed.
    Christian
  12. #262
    tirley154's Avatar
    Join Date
    Dec 2003
    Norfolk, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi All,
    Just thought I would chip in with my thoughts. I have had several flights with my Gryphon now and have to say it's awesome. As I fly off a 100 meter grass strip, the barn door flaps and large wing area were essential in my choice and have proved a perfect combination. Fitted with a JetCat P80SE, kit supplied thrust tubes, Electron 40 retracts & sprung struts, it needed all batteries up the nose to obtain the CG. Landings are at walking pace into a headwind with good control, even with over half a tank on board. Flying characteristics are akin to a pattern ship, smooth, accurate and with an impressive turn of speed. I dislike the fuel tank shape, it's a poor design for fuel pick up during aeros. I opted to put a 500ml header tank (Sullivan Vee type + bubble trap clunk) in the wasted space underneath it, which so far has been great. No bubbles, no flame outs, I'm happy. All in all, a great sports Jet!
    Updates over the next few weeks,
    Dave
  13. #263
    marc s's Avatar
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    For anyone interested I have a hand made tank for the Gryphon which I made for mine as I too felt the tank shape was too long and thin to allow proper fuel collection during aeros, the tank I have slots straight in the space between the ducts as per the original but is deeper and more 'square' in shape so much better for fuel delivery.
    If anyone is interested then PM me as I don't have a requirement for it anymore.... the tank is fully plumbed with my Pro-Filler end cap.
    A few pics of the tank...
    marcs
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  14. #264
    ceffi's Avatar
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi all,
    today I had the maiden with the Gryphon.
    One click on hight, thats all I had to trim.
    It flies great.
    I use a JetsMunt VT 80, electron retracts and struts and elektric brakes from JetsMunt.
    Works all fine.
    But dry wight is 10,6kg.
    CG is 185mm.
    Christian
ID:	1876803   Click image for larger version.
ID:	1876804   Click image for larger version.
  15. #265
    tirley154's Avatar
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Christian,
    Congrats on your successful maiden! Looks a nice tidy install, certainly neater than mine, lol. You might want to pull that CG back when you get used to it though. The Gryphon comes alive at 200 to 210mm. Not sure what mine weighs, will let you know. I expect they always come out at around 10kg dry though, it's quite a big jet.
    Dave
  16. #266
    ceffi's Avatar
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi,
    I think, CG can more to the rear.
    Short to the front of the wing tube should be a good position.
    I will try it.
    But next week we have a nice model fair (ProWing) and I will fly the Gryphon as DemoJet.
    All changes I will do later.
    Christian
  17. #267
    tirley154's Avatar
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi,
    Just weighed mine and it's 9.8 kilos dry (plus 2.5kg wet) with the fairly heavy JC P80SE and kit tail pipe. Batteries are 2 x 3000mah Life & 1 x 3200mah Lipo, mounted on a plate, right up the nose. Hope this helps?
    Dave
  18. #268
    sandrocacciola's Avatar
    Join Date
    Aug 2006
    Grosseto, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    These is my Gryphon...
    I have a problem with the exaust pipe: it's too heavy. Does anyone know how I can find one a lot lighter? And it's possible use one exaus pipe single?
ID:	1881882   Click image for larger version.
  19. #269
    ceffi's Avatar
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Sandro,
    I would not use a single pipe due to the heat.
    I removed approx 200g lead. CG nearly by 200mm.
    Pics from the ProWing fair.
    The smoke by landing is from my JL Viper, flown by a friend.
    Christian
ID:	1881896   Click image for larger version.
ID:	1881897   Click image for larger version.
ID:	1881898   Click image for larger version.
ID:	1881899   Click image for larger version.
  20. #270
    Join Date
    Aug 2006
    Grosseto, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello!
    how did you remove 200 grams from the exhaust pipe?
  21. #271
    tirley154's Avatar
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think he removed 200g lead from the nose to get the CG to 200mm. Not removed weight from the tail pipe.
    Dave
    ps. Love the scheme on your Gryphon!!!
  22. #272
    ceffi's Avatar
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    that's right
    Christian
  23. #273
    Join Date
    Aug 2006
    Grosseto, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have the opposite problem: have too weight rear becosuse my plane it's very light now: 8,1k dry..
  24. #274
    tirley154's Avatar
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi all,
    Had a dozen or so more flights now and must say it just gets better! With full rates and the cg at about 210mm, it's completely neutral and fully aerobatic. I settled on 15 degrees take off flap and 50 degrees for landing. Just for fun I GPS speed tracked it today, peaked at 188mph. Not bad for a little ole JetCat P80SE. Final AUW dry is now 9.5kg (21lbs), definately a keeper now it's all sorted.
    Dave
  25. #275
    voodoodb's Avatar
    Join Date
    Jun 2002
    Flora, MS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just wandering if any others had experienced the fuel draw problems as Marc and a few others had commented on? Also is there another solution to this problem using the stock tank? I am planning on using a standard BVM uat installed on front tray bulkhead.
    thanks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
