GRYPHON - build thread (sports/trainer 2m composite jet)
#81
RE: GRYPHON - build thread (sports/trainer 2m composite jet)
ORIGINAL: marc s
Invoices are one thing I have yet to master opening.......
#82
I think the Hawk Union Jack scheme may suite this well, and it would be nice to see something other than a US navy scheme on a sport jet.
Mike
Mike
#83
Banned
1 Post
The schemes shown remind me of what some body once said to me that if beauty is only skin deep you must be inside out............ I am not sure that it was a compliment
#85
Marc S,
Take heart mate I like your jets with loud colour schemes, I may even have to have one.....as loud as possible please.
Kind Regards, Craig.
#86
My Feedback: (9)
AZ
Being a non-jet guy I just stumbled in here from the RCU Heartbeat page. I was examining the pics, admiring the craftsmanship, until I hit this one…
I think I winced so hard I had an aneurism!? [X(] But by the time I the fog of my mini-stroke had subsided the OP had already determined that future customers were less than thrilled with the paint, provided some options, asked for suggestions and provided a template for their input. That is impressive!
Even more impressive is this all took place with good nature and no one’s feelings getting hurt (other than a little Boomerang detour).
Sharp plane! I think a Union Jack is a must, then maybe pander to markets with Tricolore, Old Glory schemes, etc.
#88
1 Post
One of those on the way too, cheers for the feedback....
Any design ideas out there?
If you dont have time to draw it, post a picture of something along the same lines as you like - I can always to a 'version' of it.....
marcs
marcs
#94
1 Post
OK the build is on......
First up are the control surfaces, all require hinging and its probably the most time consuming part of the build so decided to make a start here.
The control surfaces are all fully moulded with curved front edges, these have holes already made along the length and directly below each hole in the moulding is a pilot hole in the airex/glass cloth sandwiched former which sits on the hinge line. I opted to make nice large openings for the hinges so fitting them was easy rather than fiddly, also the cut-outs for the hinge rotation is almost invisible when the surface is at neutral. I cut each slot 10mm wide using my small milling machine and some guide marks using masking tape.
Hinges are Robart pin types, and on inspection it seemed that a portion of the hinge would be proud from the mounting surface in the wing trailing edge section so I have experimented with some Graupner flap hinges which have an 'extension' section just by the hinge pin which I hope will provide the required stiffening support for the pin side which glues into the wing - with luck it will work out.
First few pictures of the hinge locations, cut-outs in the aileron and flaps, hinge types with the slight modification made to remove lugs from the hinge shaft and hinges glued into two control surfaces.
I will be looking to use 'economical' components for the build and will keep a running total so the end result will also give a spend for fitting out the airframe.
marcs
marcs
#95
Interesting, all the Graupner pin hinges I have come with two hinge points and are grey rather than the single hinge point white one's shown in your pic, have Graupner changed the product?
Mike
Mike
#96
They've been white since I first saw [link=https://shop.graupner.de/webuerp/servlet/AI?ARTN=3360]them[/link], granted not long in the grand scheme of things.
#97
1 Post
As mentioned a few post ago I will post ongoing costs for the build to as to arrive after completion at a final figure which shows a realistic build cost.
Parts:
Graupner hinge pins 3 x 10 pin packs @ £8.99 - £26.97
Running total £26.97
marcs
Parts:
marcs
#98
ORIGINAL: marc s
Parts:
marcs
Parts:
marcs
#100
I have never seen the white ones before, must be a new product, always seem to find these at my local model shops: https://shop.graupner.de/webuerp/servlet/AI?ARTN=128.47 in various dia.
Mike
Mike
