E flite F-4 First flights
My Feedback: (80)
CA
RE: E flite F-4 First flights
ORIGINAL: Ali
Kenny Mac.. Woooha! Go easy. Small steps my friend. Neanderthals like Dougie and I are just getting our heads around digital trims and Douglas is totally zoned about by that proportional throttle stick business
You need to come to desert jet storm in Feb Ali! Good fun and great weather.
Hi Guys,
I've just bought one of these kits, absolute bargain at £185. It's going to be a long term project as I can't afford to buy everything at once. However I am looking at different setups. It's recommended for 80mm fan but can't find a 10 blade versions just now, would kinda like that for the sound. or do I make it a real long term project and convert it to p-20??? Oh and Ali I work at Rutland Water and have often seen your jets over Luffenham....awesome
My Feedback: (22)
Hey Storm29,
I have the 80mm Stu Max in my Habu 32 and really love it... I have run the stock fan and it, both of 6s 5000mah. The Stu Max has a little more performance, mostly in the vertical, but the sound is great!!
You can contact Stu direct: http://www.stumaxaircraft.com/pages/contact.htm
or maybe find one at esprite: http://www.espritmodel.com/edf-stuma...het-motor.aspx
There is also the Jet Fan 80 which has a nice sound also: http://www.effluxrc.com/Jetfan-80mm-...t-JF-80EDF.htm
or the Wemo 80: http://www.extremerc.com.au/estore/i...oducts_id=1297
Hope that helps... all great fans, but I like Stu's the best
Ron
Ron
