Yellow F-4 and Rabbit 100
NJ
Any thoughts about this combo? I was planning on going with the Bee but wen't with the Rabbit.After watching Dominics build I gotta get mine started and built.
Frank
Frank
RE: Yellow F-4 and Rabbit 100
I have flown them with Golden West, AMT 180, Jetcat P-80 and Jetcat P-120. Just put a K-80 in old one I have and will fly soon. The light ones fly better. You need 15 degrees flap for take off and none for landing. elevator gets too soft with flaps on landing. I have 5 tanks totalling 77 ounces in mine.
Wow,,
I briefly owned a Yellow F4 powered with a OS 81DF. It flew fine (for a ducted fan) . Probably had 6-7 lbs static. Yellow recommend a 5 ¼ fan and a model weight of 11-13 lbs.. I could not comprehend a Jetcat P120 in one.. Are you sure we are talking about this model.. http://www.yellowaircraft.com/jets/f4.htm
Roger
Roger
Hi,
I've flown it on a P-80. Only difference with a 120 would be more thrust. I do think the P-60 is ideal. I haven't had first-hand experience with the P-100 yet, but I imagine that would be the best engine for this plane. I agree with Kevin on all points.
ORIGINAL: kevinthoele
H
Yes It is the Yellow F4
H
My Feedback: (22)
ORIGINAL: HarryC
Who thought it was a viable idea to fit a p-120 into a 44'' span model weighing around 15lbs? And was there any space for fuel other than enough to taxy out to the take off point?! I fitted a PST600 of 14lbs thrust and struggled to squeeze in enough fuel even with custom made saddle tanks either side of the engine and another tank between the intakes. At around 16lbs weight it was a lead sled.
H
H
Had all that it needed for 5 minute flights. There is a left stick use it. At vertical climbs full throttle was great. I have over 6000 flights on multiple yellow F4's so I know what makes them work. I think I have flown 10 in all and this one is almost 10 years old.
I'm just gobsmacked it flew at all with that weight in it. Are you sure it was flight and not a ballistic trajectory? I fancy getting another one but based on the handling due to weight in the one I had I was thinking about a Wren 44 of 10lbs thust and low weight and small fuel load, and a straight pipe not bifurcated. The thought of it with the weight of a P120 and associated fuel does not give me a good feeling. It's not that I don't cope with high wing loadings and high landing speeds, I am used to flying an F-104, but my YA F-4 would not have been improved by more weight!
H
H
One problem I had was that the bifurcated pipe seemed to cut a huge amount of thrust. It didn't fly like a 17lb plane with 14lbs of thrust, it flew like a 17lb plane with 8lbs of thrust. It was a Tam's pipe for the YA F-4, I couldn't get a reply from Tam on what gap to use between engine and pipe so went with the engine maker's recommendation. I don't have a test rig to try it on but it felt like a massive reduction in thrust. It was also extremely loud. That's why I felt like trying again with a single pipe and cutaway the underside of the tail if I can get my hands on another kit. What gap do you use and have you found the pipe loses a lot of thrust?
H
H
