FUTABA 18MZ HAS ARRIVED
#179
RE: FUTABA 18MZ HAS ARRIVED
ORIGINAL: cairoman
Did that too. Is the update compatible with IMac?
Chris
Chris
Since the 18MZ runs Windows CE, and both the SBUS servo programming software and the SBD programming software are only available for Windows, so I have a feeling that none of the Futaba software for the 18MZ is being written for other operating systems.
#180
My Feedback: (51)
OK
I have a iMac and just got mine to update.
you just have to make sure all of the files are unzipped.
The first time I tried it did not work even though i told it to unzip all.
I went back and found there were two more that had to be unzipped once i did that it worked!
#181
Quick instructions: Download the files. Unzip the files. You should now have a folder titled Update and an instructional .pdf. In the folder are four files. Be sure you have unzipped the folder and it's contents.
Put your 18MZ's SD card in your computers card reader and open it. If you see a folder titled Update on the SD card, delete it.
Drag the Update folder from your computer to the SD card. Once the copy is complete, open the Update folder on the SD card to assure you have four files in it.
Eject the SD card from your computer and remove it from the card reader.
Place the card in your 18MZ and move the little update switch to the update position. Power up the 18MZ and follow the on screen instructions.
Once complete, power down, and move the switch back to the normal position. Your update is complete.
Steve
Steve
#182
I don't know how you guys do it, but my iMac will not unzip the file named T18MZ.exe
I keep getting a message "the contents of the file "T18MZ.exe cannot be extracted with this program" and I am using unZip, just like I unzipped the downloaded pack.
#188
ORIGINAL: haisanjafri
Just feeling like a Captain Jean Luc Picard sitting at his control seat in command & control center
#189
lolz Couch Potato
However, I bought it at full advance cash payment which I happened to be saving quite from sometime now.
I think now StarTrek Enterprise can use it for another 5 years...
#191
My Feedback: (7)
WA
ORIGINAL: Andrew Bird
Oh dear - toy planes and Star Trek references in the same place[:@] Whoever said modelling was for nerds?!?
Z
#194
By God these RC Jets are far more complexed than the stage setup of StarTrek of its time.
#195
HELP PLEASE
I need to set up CROW - it used to work fine on my 14MZ but does not anymore on the 18MZ although I copied the files and everything else seems to work very well.
I have set CROW through the "CAMBER MIX" menu under the "MODEL MENU"
Can you please check with your radios out there when you select any condition (I have made a separate "CROW CONDITION") when you press the ACT/INH button what are the alternatives on your radio. It should be ACT or INH right? Well in mine it is either ACT or OFF (see picture bellow).
Can you please check on your radios if you get the same? Is this a bug or does the "OFF" depend on something else which I'm missing????
I can't activate the CAMBER MIX and thus the CROW. Very strange.
Your feedback would be greatly appreciated.
Tassos
Tassos
#196
I am not sure about the 18, but on the 12 you set crow on the Airbrake function, this gives you aileron, flaps and elevator control without using any mix's.
Mike
Mike
#197
I'm not sure about the 18 either but do you have a switch assigned to the mix?
Are the screen options INH and OFF? If so, what happens if you flick the switch assigned to the mix? Does OFF change to ON?
#198
ORIGINAL: siclick33
Yes, option is only between INH and OFF. Can you please try it on your 18?
Tassos
#199
A long shot here as I don't have a 18MZ but in the absence of any expert assistance so far (I'm sure it will come), what happens when you press the ON button by 'switch' on the first screenshot? Do you get the option to select NULL?
#200
ORIGINAL: siclick33
I can't set CAMBER MIX to ACT.
Just to clarify things the wing layout is with 1 servo for flaps and 2 separate ailerons as per attached picture.
Can someone help please (I hope I didn't discover a bug).
Tassos
