How attach gear door to mains strut?
Reply
Old 12-27-2011, 01:43 AM
DominicM
DominicM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How attach gear door to mains strut?
Going to make some gear doors out of FR4 sheet for my 1.9m Futura. What are the options for attaching them to the Digitech pro-lynx trailing link struts? Any help appreciated.
DominicM is offline
Old 12-27-2011, 02:00 AM
jetster81
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: How attach gear door to mains strut?
Sierra make clamps to attach the doors to the legs which work well
jetster81 is offline
Old 12-27-2011, 04:06 AM
ozief16
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dominic,
I'm sure someone with more experience will chime in, but I've had good success with drillling into the strtut, tapping it ffr 4-40 andd then drilling matching holes in the door. I then stick the bolt\washer through the door, then a 1\4" piece off fuel tubing, then into the gear leg. The tubbing allows he door to float just a touch. It works quite nicely. I hope this helps
Dave
ozief16 is offline
Old 12-27-2011, 04:37 AM
DominicM
DominicM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Like that idea. Thanks very much Dave.
DominicM is offline
Old 12-27-2011, 05:14 AM
InboundLZ
My Feedback: (10)
InboundLZ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave's method works well, I plan on using it on my Ultra Flash conversion wing.
InboundLZ is offline
Old 12-27-2011, 05:46 AM
megafly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you post any pics?
Thanks.
megafly is offline
Old 12-27-2011, 06:57 AM
InboundLZ
My Feedback: (10)
InboundLZ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It will be a few days until I do mine....
Old 12-27-2011, 07:02 AM
quist
My Feedback: (198)
quist's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave, I drilled and tapped my Ultra Flash struts also. It looks better and it is easier then mounting the filler cups under the strut. But mine are hard mounted.
I added a filler block of wood that I tached to the strut. I sanded this down to give my cover a flush fit when retracted. Then I glued down the cover to the filler block, drilled and tapped all together.
quist is offline
Contact Us Archive Advertising Cookie Policy
