Futaba GYA352 Gyro Users?
RE: Futaba GYA352 Gyro Users?
I had one for the ailerons on my F15, I couldn't get it to perform satisfactory, or at least the corrections I was looking for. I fitted an ACT, problem solved.
m
m
Cheers Mick. I've been flying mine fine in the Cougar for last few months but just setting it up as a new model in my 18MZ and I need to be sure it only set to work in 'normal' mode and not AVCS.
Instructions say the LED will go red when in AVCS mode but I simply can't get it to go red (so I know what direction to set limits to 0%). At +100% and 100% the behaviour seems to be that of 'normal' mode but no way I'm flying it until I KNOW it isn't able to switch to AVCS mode.
Any ideas?
Any ideas?
Mark
I have one but have not used it in anger yet. As I understand it the red light is off for Rate mode and on for AVCS. 100% one way will give you Rate and 100% the other way gives you AVCS. 0% keeps it turned off.
I assume you are in “Gyro†channel. I never used or use that I always use an aux channel and assign a “control†the Fut gyro channel seems unnecessarily complicated for our use.
m
m
Mark,
I assume it is generally the same as the GY401 and that definately goes red when in AVCS mode. It should be fairly easy to confirm what mode it is in by its response. If the model is disturbed when in normal mode (e.g. tip the model onto its wingtip) then, once stopped, the ailerons should be back in the middle. In AVCS mode they will remain deflected even after the model movement stops.
Guys,
I agree but can't seem to get the behaviour I/we expect! I have a 3 way switch at the mo for testing. With the switch in the middle, when I wobble the model (yaw) nothing happens. With the switch "up" the rudder reacts by countering the swing of the nose. Switching the switch "down" has the same behaviour. I would expect one direction to react by retaining the deflection - that would then be AVCS and I could 0% that movement....
Cheers,
Mark
Cheers,
Mark
I have been flying the model fine for 6months so all the pots etc are in the right positions. When Ali delivered the Cougar we set it up on my 14MZ and I now remember he/we struggled to get AVCS to work as I seem to recall Ali did when he first installed the model. We finally decided that if we simply couldn't find AVCS mode in the workshop it wasn't going to come on in the air!!
Having the same issue again when programming model into my 18MZ has made me truly wonder if the gyro has a fundamental fault and as my rudder and ailerons are plugged into it I need to know it is working 100%. Quite simply going from -100 to 0 to +100% should see the red LED come on and it sounds like it never has....
I don't feel happy taking the same approach again. Perhaps I've been lucky the last few months?....
Voy,
Tried that :-(
Also, I believe if you hold the rudder stick (for example) in a position whilst turning on RX then that should set the neutral in AVCS mode but that doesn't work either.
Quick thought, as a dual input gyro there are 2 gain leads in 2 channels. What happens if 1 is at -100 and the other at +100? What mode does the gyro work in?!?
M
Tried that :-(
M
Mark,
The neutral is set when you turn the gyro on. Providing you don't move the model when the gyro is initialising then there should be no need to flip switches or hold rudder sticks. AVCS is selected or deselected by the gain channel and not the rudder stick position. Moving the rudder stick might change the blink pattern on the LED but it doesn't change the mode.
The instructions are pretty difficult to understand and I didn't see how individual axis modes worked at first.
There is a tiny note at the bottom of the paragragh about 'monitor LED display' showing that the LED shows red for X axis, green for Y axis and orange for simultaneous operation. Therefore it looks like, in your example above, one axis would be in AVCS mode and the other in normal.
Don't dump it, send it to me
Hi Dan,
I want to be able to switch on AVCS on the workbench simply so I can ensure I can disable it by turning the limits to 0% on the TX.
Only issue is +/-100 seems to operate in Normal mode which is no bad thing. I'm just concerned that if I can't get it into AVCS mode it may not be working correctly in general and with my ailerons and rudder plugged into it I want to know it IS working properly!!
Cheers
Mark
Cheers
Mark
HI
Hi Mark
I have used several of the 352's if im not mistaken the Futaba Gyros like to be started up in AVCS mode when you turn on. I'm not sure if this really would cause your issue or not.
I setup my 14 MZ so that when I turn on the plane my Gyro switch is just in AVCS dead zone, like 2% I get the flashes then I go flying. I never really played around with it to see if it went in to AVCS mode or not.
I have used them for seperate surfaces like yaw and pitch. I also have it in my F4D Skyray on the elevons in the mixed mode pitch and roll works great.
Sounds like a strange issue. Maybe you could try using a servo driver to see if you could get it to go into AVCS? I hope you get it solved.
