Reload this Page >
Dry Transfers
Dry Transfers
Old 01-18-2012, 10:29 AM
Eaglepilot2
Eaglepilot2's Avatar
Default Dry Transfers
Does anyone have a good way to remove dry transfers?
Thanks in advance.
Old 01-18-2012, 11:43 AM
BalsaBob
My Feedback: (24)
Default RE: Dry Transfers
If they have not been clear-coated over ..... some scotch tape should lift them right off.
Old 01-18-2012, 11:44 AM
Greg Wright
Greg Wright's Avatar
If you haven't sprayed any clear over them then some good 3M masking tape will peel them right off. If you have sprayed clear over them then start sanding thru the clear and they will come off that way.
Old 01-18-2012, 01:25 PM
Eaglepilot2
Thanks guys, I have tried the clear packaging tape and that has worked some, but mostly it just comes off in little pieces and it appears that its done all its going to do. I bought the plane second hand, but it doesn't appear that its been cleared. However, that may be why its not coming off any easier than it is. May have to start sanding.
Thanks for the replies.
Old 01-18-2012, 03:37 PM
KC36330
try a tape with a higher tack such as vinyl tape.
