Large futura prep and painting
#201
RE: Large futura prep and painting
Hey Maikel. We were going to use the drop tanks from your hawk, but they were too big. These are from a Skymaster Hawk 100.
Hi Jeremy,
That Phrase still works, although a little dated now.,, but thanks anyway. I know we are set to fly it this weekend, so hopefully there will be some in flight photos. Not sure about video, but if we get any I will be sure to update.
Regards Al
Hi Jeremy,
Regards Al
#203
Nice work Philip and Ali, you forgot the "God Bless You"
http://www.flickr.com/photos/richsnyder/6884769059/
Rob.
Rob.
#205
Thank you for all your kind words.
I will explain the process of weathering but it is sometime very hard the explain in words.
Unfortunately the next three models I am working on are all big radials, one racer and two warbirds.
Two will be weathered, one polished.
#207
Ok, here goes.
There are two types of weathering, one I call cartoon weathering, this is when you use a stencil and an airbrush, you use the stencil and air brush to create dark edges along panel joints or hatches.
The other method is using artist oil paints. The model will be painted in either cellalous or 2k paints using artist oil paints is a simple and easy way to create a dirty appearance.
This is we're you need nerves of steel to do the next bit, when the model is finished being painted and I mean finished, every colour squadron marking needs to be do otherwise you will have to weather that area again which can cause issues. Get your black oil paint and mix some with a very little amount of white spirit or turpentine, you don't need it runny just a little thinner from what you get out of the tube. Now you need to apply the paint using a cloth and cover the whole model until it is covered.
If you want a light weathering affect then you will need to start the removal process straight away, if not leave to harden for about an hour. You need to remember to wip off in the direction of the airflow, the harder you rub the less weathering you leave behind, now if you find that the oil paint is to heavy (weathering) then put a couple of drips of either thinner on a cloth and wipe off the oil paint, be very careful as the thinner really does thin the oil paint and if you use a lot of thinner the oil paint will disappear completely.
I will stop here and wait for any questions.
#208
Hi Phil,
Couple thoughts... The satin clear, is a 2k type..? and has no problems going over the oil paint weathering after its had a drying time..? Not prone to fish eye then, needing a additive..?
Do you have, some pics of the Cartoon airbrush type work..?
Cheers Jeremy.
Cheers Jeremy.
#209
Hi Jeremy, as long as you give it time to dry then you will not have any issues with clear coating it. I always recommend making a test piece to test any combination of paints, it's the carrier that is always the problem with clear coating over paint and affecting the paint, making it craze. I have found in the past that enamels are affected by some 2k carriers and can cause devastating issues.
#211
Hi Phil,
Thanks for the pic of the Rafale, very nice...
Now you say.. it's the carrier that is always the problem with clear coating over paint and affecting the paint
Sorry for my ignorance, but whats the carrier..?
cheers Jeremy.
cheers Jeremy.
#215
The good news for those of you that have enjoyed this great thread that Phil has kindly put up and updated with his know-how and skills is that I have done my own little bit into making last a whole load longer....
Today's test flight of the Futura did not go quite to plan. To say it was not a success would be an understatement and a half. I think the photos do enough to explain. [:@]
Simple fact of that matter is that with a busy schedule of testing other peoples models, mixed in with a fair amount of complacency. I experienced for the first time that I can remember a situation where I took off with my ailerons reversed! I am not too proud ( Yet very, very embarrassed) to admit it. The really annoying thing is, that I know i check them on more than one occasion. Even worse is that I remember setting the model up on Thursday, and thinking how odd it was that the values on my crow mixing had to be reversed as when i dropped the flaps, both ailerons drooped instead raised[:@]
Right now I fell like all of the **** and ******* under the sun rolled into one. It sure is an expensive lessoned learned for me, and hopefully others might see that no matter how many flights you do, a mistake or an oversight can still sneak in there to bite you in the *****!
The only saving grace is that the damage is limited to the fuselage only. Roll on the Re-prep and Re-Painting thread
Regards Al
Regards Al
#218
Al
The one thing I will say that we were all impressed with your conduct afterwards and I think I can speak for all that were present that we were all gutted for you [&o]
The Futura painted in that scheme looked truly awesome and I for one look forward to seeing it again flying.
That cetainly explains how it started to bank a little at first then it turned into a more accelerated roll rate.
Sorry to see this happen today..
Alan
Alan
#219
My Feedback: (57)
Truthful explanation says a lot about your character. You can tell "TRUE" learning has taken place... It can be argued a mistake that doesn't kill you & you learn from is not really a mistake. To bad it cost $$$.. Sorry for your mishap, she is a beautiful ship!
#220
My Feedback: (48)
UGH! Sorry to hear this Ali!
Really appreciate you turning this misfortune into something that may possibly help us all out. This will give us a graphic image to stick in our heads as a reminder.
I'll be the first to admit I dont always make it a habit to check flight controls before each flight. Ill move surfaces to check if they are working, but Im not always sure if I make a consious note of direction on the ailerons. Ill see them flapping and go!
Posting this must be tough and putting yourself out there for the critics is admirable.
Very Sorry,
Scott
Very Sorry,
Scott
#221
Sorry to see that happen Ali, what a shame, that is just a gorgeous airplane and I can't believe I'm saying that about a Futura! The only one I've ever seen that I liked! I hope you get it fixed or replaced as we'd all like to see some flight pics of that beauty!
Regards,
Mike
Regards,
Mike
#222
Absolutely gutted for you Ali and Phil. Classic Human Factors error but on the positive side you will have had a significant impact on flight safety for the rest of us and that type of incident certainly wont happen to you again.
As with full size aviation once the dust settles and calm returns its often interesting to look back and recognise the chain of events that lead to this particular flight critical system getting airborne.
Heard of some ways of extending a thread but this really takes it
Rob.
Rob.
#223
Thanks for all your kind words, It is very hard to admit that is was human error and I take my hat to Ali to admit this. I heard minutes after it had happened and I felt so sorry for Ali as I knew how happy he was with this particular model. One good thing is that no-one got hurt and we can fix it, OK a new fuse is necessary but we have the technology to rebuild her.
She will fly again
She will fly again
#225
ORIGINAL: Ali
Regards Al
Regards Al
Pablo
