If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 24 of 24
  1. #1
    Join Date
    Mar 2008
    KUCHING, MALAYSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    futaba 8fg super for jet turbine flying?
    hi all,
    im futaba user been using futaba 10cap 2.4 for sometime with great success!
    as for now im putting an ultra flash togather seems like im running out of ch
    on my 10cap!
    i would like to setting up craw on uf so flaperon is a must,i do not want to
    missout the smoke pump so it took another ch also e brakes valve ....
    unlike my p20 habu32 it design for using Y to run two servo for elevator also Y on flaps so my 10c no issues but not for ultraflash!
    while im doing some research on futaba 8fg super,seems like the radio do able with 12ch propotion +2 switch ch which fit what i need.
    the problem is i never seen/read any pilot using 8fgs flying jet turbine....that make me think....because it giving me the feel/looks like a park flyer tx in my eye...
    im in the safe side with the 8fg super?
    ps:im not ready to spend on 18mz i know that is best solutions so pls skip that.
    YiMing
  2. #2
    Bob_B's Avatar
    Join Date
    Nov 2003
    Bluegrass State of Mind
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: futaba 8fg super for jet turbine flying?
    The 8FGA would work fine the 12FGA has some nicer features
    2017 Fall Jet Classic - Event Dates October 4-7, 2017
  3. #3
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Kent, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    YiMing
    I have an 8FG and the upgrade to 12+2 channels has only been out a short time, so not many people using all of them, I mistakenly bought the 8FG thinking I could use it as a back up to my 12FG, but they do not talk to each other so I have two 12FG's instead, if your budget can be stretched a bit further get the 12FG it has much more functionality than the 8FG and the bigger screen make programming much easier.
    Mike
    My Gast is Flabered.
    No matter what anyone say's 100% is the maximum you can get.
    If you see a deleted post, my Avatar say's it all.
  4. #4
    raptorlogo's Avatar
    Join Date
    Aug 2006
    -Burgundy, FRANCE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi YiMing,
    I am using a T8FG upgraded with the latest 4.1 firmware to 12+2 channels and a T12FG.
    They are only few minor differences between both senders.
    The T8FG will be a great system for your Flash and is much cheaper than the T12FG
    Alain
    Citius, Altius, Fortius...
    YouTube channel
  5. #5
    Join Date
    Dec 2001
    Sarasota, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    YiMing,
    I have the 14mz and my son has an 8fg. He hates using my 14mz because it is too big for him so I setup one of my 10 channel jets on his 8fg and let him fly it. It works perfectly fine. It has everything you need to do a setup on a jet but does lack some of the higher end features of my 14mz, but is very comparable to my 9z which I flew jets with prior to my 14z. I guess to answer your question will it work..yes it will. I have not had any issues with the upgrade to 12+2 on his radio.
    Patrick
    Perfect landing or total destruction crash, I still love this hobby!
  6. #6
    Join Date
    Mar 2008
    KUCHING, MALAYSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    R_Belluomini
    noted! tks!
    BaldEagel
    tks for the ideal!
    im try to cheap on the 8fgs so that i shorthen the time to get 18mz(if the 18mz turn out positive feed back from everybody)
    YiMing
  7. #7
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: raptorlogo
    Hi YiMing,
    Alain
    Alain
    The 12FG is a far more capable unit than the 8FG just have a look at the standard mix's on the 12FG plus the amount of P mix's available, on the 8FG you would use up all the P mix's just trying to get close, I think you need to use your 12FG more often. LOL
    Mike
  8. #8
    dubd's Avatar
    Join Date
    Aug 2007
    Bay Area, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The 8FG is the worse radio I have ever programmed and I've used a 9Z. It's a capable radio as long as you can get past the unintuitive menu structure.
  9. #9
    raptorlogo's Avatar
    Join Date
    Aug 2006
    -Burgundy, FRANCE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BaldEagel
    Hi YiMing,
    Alain
    Alain
    Mike
    Mike,
    For 99% of RC pilots, the T8FG has sufficient capabilities.
    I am use to programm in depth both T12FG and T8FG (F3B/F3J gliders, 3D helicopters and jets) and I can tell you that for the most common human rc pilots the T8FG is a winner.
    If we talk about Futaba the T8 is a very good compromise in terms of cost and overall perfomance.
    I respect your own opinion and you should do the same with me.
    Alain
    YouTube channel
  10. #10
    Join Date
    Apr 2002
    Bend, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    since the question was "futaba 8fg super for jet turbine flying?" not, which radios are better than the 8fg, YES a Futaba 8fg will be more than adequate to fly a jet.... peace out
  11. #11
    Join Date
    Nov 2003
    Martinsville, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you can make all your channels work, the 8F super will be fine. I had one for years and it was rock solid. Great little TX.
    Scratch it till it bleeds Convert it till it chokes
  12. #12
    yeahbaby's Avatar
    Join Date
    Dec 2001
    FT Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It will work better than a Futaba Super 7, my first jet radio. You will be in good shape amigo, the bigger radios certainly provide more options though.
    Good luck
    work work work ......livin the dream
  13. #13
    Kenrico's Avatar
    Join Date
    Sep 2004
    La Ceiba , HONDURAS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've been using mines for about 9 months now and its all i need and never a glitch. Its a great radio for the price.
  14. #14
    DAN AVILLA's Avatar
    Join Date
    Dec 2001
    roseville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I checked out a buddies 8F. It appears to not have a servo slow function like my 14mz. If some one found how to do that would be great info.  Dan
  15. #15
    Join Date
    Nov 2008
    Ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    There are a couple of slow functions I have found on my 8FG Super.
    I have one running flaperons slowly in flaps up/down...really nice.
    There is also something on throttle that I believe I saw, but it does not apply to my gasser and glow kites so I haven't used it.
    I'm new to this radio but so far it's very nice.
  16. #16
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have the 8FG for a couple months now. I have a large EDF using all 14 channels, no problems. There are efficient ways of programming it and inefficient ways. I originally used all 5 mixes, now I am just using 3. I even am using it as a gear door sequencer on a 3 way switch.
    I am currently building two turbine powered jets and I will bre using the 8FGs. I have about 20 or so flights on it and not a hickup.
    The only complaint I have is using a 7CH rx with my HABU 32. Using a single aileron channel and Y harness, it does not auto setup flaps. You have to usea mix tothen to setup flaps. BUt that is based on what I know now, there may be a better way.
    THe mix is to have elevator mixing with the flaps, which is usually setup without a mix when using 2 aileron + 1 flap
    There needs to be an option, 1 aileron, 1 flap.
    I have not seen the slow servo function but I have found ways to not have to rely on that.
    Kingtech K180g, K140g, K100g
    Jet Legend viper
    Skymaster Mig-29
    Yellow Aircraft Single (under construction)
  17. #17
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gary1, where are the slow functions you found?
    Jet Legend viper
    Skymaster Mig-29
  18. #18
    Join Date
    Jan 2010
    Tallahassee, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Absolutely. I'm learning to fly my BVM Super Bandit withthe 8FG. The new Futaba wireless training system is fabulous, too.However, I do agree that programming a model (giant scale warbirds and jets is what I’m familiar with) for the first time can be complicated. My buddy helped me with the programming, so it was painless. I'm very pleased with the radio and 6014-receiver combination.>>
    Best>>
    Ernie
    Skymaster F-16 1:6 P-200-SX
    BVM Super Bandit P-140-RX
  19. #19
    Join Date
    Dec 2001
    Sarasota, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: skydve76
    There are efficient ways of programming it and inefficient ways.* I originally used all 5 mixes, now I am just using 3.* I even am using it as a gear door sequencer on a 3 way switch.
    I completely agree with the above statement. It seems that modelers are stepping away from properly setting up a model first by mechanical means and then by correcting any bad tendencies with mixes.
    Patrick
  20. #20
    Join Date
    Dec 2009
    Central Midwest
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Keep in mind that before the 8FGs, the 8FG was 8 channel.  8 Channels is hard to pull off on a turbine with brakes, retracts, gear doors etc..  Its doable but not the ideal situation.  Now that it is 14 channel its good to go.
    Jet Legend viper
    Skymaster Mig-29
  21. #21
    Join Date
    Mar 2008
    KUCHING, MALAYSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i will not go over to 12fg as the 8fg super fits my need i d use up all those 12p mix!
    i have some more time to conside as my new engine still with ali,also u/c from dreamworks is out of stock.
    today our lhs landed some 18mz it looking sooooo cool! i know the 8fgs will work for me but that is what i want but not something i need!
    after spending all those $$$ on ultraflash and related the 18mz at Sdg$4300 price tag i need to think twice~nmv i still hv time to dream bout it!
    im realy pleased my question has been consider and come out solutions and helpfull input.
    thanks every one here spend your time to reply! thankyou guys and thankyou rcu!
    Yi Ming
  22. #22
    Bob_B's Avatar
    Join Date
    Nov 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yi Ming the 8FG Super is a really nice radio. I want to make sure you know that you can use the 6014 rx with your radio too.
    I am looking into the servo slow feature for you and will let you know what I find out after this weekend.
    Bob
  23. #23
    Join Date
    Mar 2008
    KUCHING, MALAYSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    bob
    as for servo slow I'm using "condition" to slow servo but it only limited to sailplane mode on my 10c.
    I force to using sailplane mode to fly my high power gliders because the need of servo slow.
    as for habu32/p20 I'm using triple switch to achived full flaps/half flaps on acro mode.no servo slow on acro mode.
    it flying well still but it will be a plus if having servo slow.
    I don't mind getting 8fgs to try it out if jump ship to 18 I can easily to sell it off as the 8fgs kinda hot cake at the moment.
    no hurry the UF going to take some time..at the mean time life as usual because I'm still hv my good trusty 10c to torture
    all my planes !
    Yi Ming
  24. #24
    GrayUK's Avatar
    Join Date
    Oct 2003
    Dunstable, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The 8 FG is fine for turbines, i have flown at least 4 turbine models on it with no issues.
    If you can go for the 12FG it is better on the program side, servo slow is very good for flaps and the sequencing / logic functions are great for UC doors etc.
    Both use the FASST system so the RF is the same and rock solid.
    Never had a glitch on either system.
    Paul G
    no one told you when to run...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
