AMT OLYMPUS REPAIR
AMT OLYMPUS REPAIR
After some month i finished this old engine of my friend
no electronic, no original compressor and intake cover, standard skf bearing
then new compressor, new grw bearing, new part of intake cone, balancing, projet HORNET ECU and sensor Projet
RE: AMT OLYMPUS REPAIR
First run after repair
projet hornet ecu and projet sensors
[youtube]http://www.youtube.com/watch?v=vWfwEi60b9U&feature=player_embedded[/youtube]
Chrigul hi,
Great work your doing... Did you use the Projet engine board, with optic sensors..? And need to do a calibration run on first run time..?
Cheers Jeremy.
Cheers Jeremy.
Hi..many thx..
i used for this run HORNET II V7.1 + magnetic sensor..
i tested first the voltage start of the pump and i set the ecu..then run calibration
