6mm tygon to 3mm feul pipe?
Guys I need some connectors, 6mm tygon to 3mm feul pipe? (Uat to P20 fuel pipe) can anybody offer any advice on what they use and a possible source?
Scott
Scott
PA
RE: 6mm tygon to 3mm feul pipe?
If it's really not available... I can turn you some on my lathe, but shipping to the UK will make them expensive.
****EDIT*****
I just looked, and a regular envelope weighing 3oz, with a ridged item is only about $3. Let me know if you want me to make them, and I'll figure out a price. (6m Festo barb to 3m festo barb)
****EDIT*****
Scott
Give Als Hobbies a call, they have probably the largest selection of Festo fittings and i am sure they will be able to help you.
Simon
Simon
Thanks to all ...
I worked out that the 4mm to 3mm festos can take a 4mm brass tube and the tygon when pushed on over 10mm is a very very good fit ... the ID of the tygon is slightly smaller than 4mm
Scott.
Scott.
Perfect - get yourself some wire lock pliers and wire and you're done! Rough up the tube also - around it but not down it's length if you see what I mean!
Jeff
Jeff
ORIGINAL: siddus74
Wire lock pliers, where does one get those from?
Scott.
Scott.
Al's Hobbies have them, I don't use a UAT with my P20, just a paper filter clunk in the main tank, the clunk is made from a paper filter obtained from "Inline filters" in the UK and a piece of lead soldered onto the bottom, be careful if you go this route as the paper filter is glued to the end caps, the outlet is a turned down brass clunk Hysoled into the other end cap, In case you don't know if you are going to use brass tube solder a barb onto the tube to wire tie behind.
Mike
ORIGINAL: siddus74
Thanks to all ...
Scott.
Thanks to all ...
Scott.
When I am going to put fuel line onto a piece of brass tube, I always put a single wrap of copper wire around the end of the brass tube and solder it in place, to act as a barb to make sure the fuel line can not come off. I do put a wire wrap on ALL barbed and tube connections.
ORIGINAL: siddus74
Scott.
Scott.
Cheers,
Dick
get some brass step down barb fittings i know that you can get them i use them all the time when needed they are festo fittings if i remember
