Reload this Page >
SKYMASTER F9F Build Thread
Old 03-13-2017, 07:54 AM
  #126
flyloose
flyloose's Avatar
Originally Posted by geh3
OK stab all done,now onto the wings...
I'm assembling the 1/5th Cougar, am I the only one running into a stab thickness issue towards the trailing edge? Trying to fit a standard size servo (MKS 1220) that is 20mm wide and the depth is barely 20mm in the stab. Now bear in mind the Cougar stab/elevators are swept compared to the Panther. I may need to go with a thin servo, but decent torque is hard to find. Any ideas guys?
Old 03-13-2017, 08:19 AM
  #127
geh3
My Feedback: (84)
geh3's Avatar
see here>>
There are no servo mounts supplied for the flap or aileron servos
Looking at the Skymaster manual online, this is how they did it.
I made a 1/4" thick "U" mount that will beattached under the wing skin
then the servo can be mounted to the sturdy tabs on this! Attached Thumbnails
Old 03-13-2017, 08:27 AM
  #128
flyloose
flyloose's Avatar
Thanks, I see what you've done there. I think that will compound my clearance problem even more...I looked at sliding the servo further forward towards the thicker part of the stab, but there's not really much room before I run into the forward spar. You'd think after 5 years of production SM would make the servo opening large enough to accommodate a standard size servo without having to dremel out most of the cover plate lip support? (Jeez) I'll have to figure something out
Old 03-26-2017, 07:55 PM
  #129
AV8ATOR
AV8ATOR's Avatar
The folks using 160 engines are you happy the way it pushes it around with and w/out armaments.
Old 03-26-2017, 09:44 PM
  #130
In the Haze
In the Haze's Avatar
+1 Yep it's crazy, .
Old 03-27-2017, 12:38 PM
  #131
AV8ATOR
AV8ATOR's Avatar
I got lucky and was able to purchase this incredible new build. Nothing but the best was used. I will have more scale detail done on her. And to my surprise the gear was sent to down and locked for electric gear.
ID:	2207329   Click image for larger version
ID:	2207330   Click image for larger version
ID:	2207331   Click image for larger version
ID:	2207332   Click image for larger version
Old 03-28-2017, 04:30 AM
  #132
flyloose
flyloose's Avatar
Fantastic looking Cougar AV8TOR, nice scoop....
I can't comment on your thrust question as I'm just started in my build. Everything I've read and see so far supports the idea that 160 is PLENTY for this jet. (Including BVM)
I'm putting a Behotec 190 in mine but that's besides the point ��
Old 03-28-2017, 07:28 AM
  #133
AV8ATOR
AV8ATOR's Avatar
Thanks flyloose, everything I have read and few people I've talk to say go with the 160. I am going with the new KT160. The Behotec 190 is good engine. You will definitely have unlimited vertical.
CP...
Old 05-23-2018, 07:30 AM
  #134
Craig B.
Hey guys, does anyone have a drawing showing the missile rails and drop tank locations for the cougar?
Old 05-23-2018, 08:36 AM
  #135
geh3
My Feedback: (84)
geh3's Avatar
see these vids:
Old 05-23-2018, 01:54 PM
  #136
Springbok Flyer
Springbok Flyer's Avatar
Craig,
I did not put the missile or drop tanks on my Cougar, but when I needed those positions for my F-86, John at Skymaster sent me a drawing. Perhaps just shoot him an email.
Cheers,
JanR
Old 06-10-2018, 10:57 PM
  #137
Craig B.
Hey guys, can anyone please confirm the aileron throws for the cougar? Instructions call for only 10-15mm at the inboard root but that looks like it would not be enough to me.
Thanks in advance!
Old 10-06-2019, 10:09 AM
  #138
flyloose
flyloose's Avatar
Has anyone added lights to this jet, and if so how difficult was it to route the wires through the wings? any pics?
Got mine flying this year and she's a great jet. Running a 160 which gives very scale power.
Old 10-06-2019, 08:49 PM
  #139
AV8ATOR
AV8ATOR's Avatar
Hey flyloose, Jeff Tolomeo did mine I will see if he can commit on this thread an offer some advised.
Old 10-16-2019, 06:35 AM
  #140
Craig B.
I did lights on mine and it was pretty simple. I think I may have had to drill a hole in the very outer part of the wing spar near the tip but access was easy.
Old 10-16-2019, 11:34 AM
  #141
flyloose
flyloose's Avatar
Thanks Craig
Old 05-06-2021, 11:44 PM
  #142
Desert Fox 1
Cheers!
Desert Fox
Old 05-13-2021, 07:50 AM
  #143
bruno borges
M
DenisFerrari (05-13-2021)
Old 05-13-2021, 08:30 AM
  #144
bruno borges
Old 11-23-2021, 05:04 PM
  #145
Desert Fox 1
Cheers!
Desert Fox 1
Last edited by Desert Fox 1; 11-23-2021 at 06:16 PM. Reason: Corrected spelling error in intro title
Old 11-24-2021, 12:58 PM
  #146
bruno borges
Originally Posted by bruno borges
3rd placed in the scale championship in Brazil!!
uncleTom (11-24-2021)
Old 11-24-2021, 03:04 PM
  #147
RC_MAN
Default Cougar in Canada
ThunderThrust in Chatham Ontario. 160N turbine plenty of power.
Old 11-24-2021, 03:07 PM
  #148
RC_MAN
Default Cougar
Landing
