New T2 Buckeye from Air C Race Germany
#51
Hello Racer, thanks for answering. One question, I haveread that this particular plane has a 6 liter tanks and it’s behind the wingtube, so in order to balance the plane following your chart instruction, I haveto fill the tank with just two liters and them check the CG, correct?
Regards
Erwin
Regards
Erwin
#52
Hello Erwin,
yes, the right CG will balanced with 2 Liters and it still is on the nose haevy side... I dontthink you fly the tank empty all the time... 6 Liter is enough..
I have 4 Liter in my T2 and after 5 Minutes still 50% left... also we are on to prepare an new tank what fits in the Back behind the seats and hold 4 Liter for the new kits.
#57
Hello Malcom, do you remember the brand for the front tire that you used on your T2. I need to replace it. Also please the mainwheels in case I need to replace them in the future.
Regards
Erwin
Regards
Erwin
#63
Hello Mikes68charger,
we use a carbon tube wich fits inside the carbontube wich is in the rudders allready and ad 2 Sqare carbon stringers 6x1mm in fron and behind that tube and glue all together.... never had problems with that in years....
