video-mythical beast breathing fire
here is the youtube address http://www.youtu.be/Bkt8VNNUDqY the new system uses liquid propane@110psi and a stun gun circuit to ignite it as it flashes to a vapor because there is a delay in oxygen mixing with the gas the flame establishes itself in front of the jaw-hate to burn the paintreally cool part is I tapped off the gas side of tank and use that pressure to actuate the brakes
PA
RE: video-mythical beast breathing fire
ORIGINAL: LGM Graphix
The dragon is a flying turbine powered model anyway, there'd be no reason to remove it from here in the first place.
ORIGINAL: j.duncker
I am going to leave this one in the Jets Forum as there is an obvious potential application.
Yep... I was going to say the same thing.
