Mounting angle of the turbine engine
Reply
Old 04-02-2012, 03:43 AM
alis902
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Mounting angle of the turbine engine
Hi
The mounting angle of the image you need to attach?
Described such anywhere in the manual is not.
alis902 is offline
Old 04-02-2012, 07:55 AM
Meesh
Meesh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Mounting angle of the turbine engine
No Angle. Must be on the pipe centerline.
Meesh is offline
Old 04-02-2012, 11:57 AM
scottkieper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if you are building an a10 no angle is needed just mix throttle with elevator ..
scottkieper is offline
Old 04-02-2012, 01:04 PM
rcpete347
rcpete347's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HI all, on a jet with no pipe, the angle of the turbine is changed, if their is a change in attitude at full throttle. Example is a rise in attitude at full throttle, the turbine is slanted down, just enough to maintain level flight, ( kingcat for example)
A-10 nozzle in last pic.
Hope that helps
Rcpete
ID:	1746039   Click image for larger version
ID:	1746040   Click image for larger version
rcpete347 is offline
Old 04-02-2012, 01:22 PM
grbaker
grbaker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Plus your turbine is too far back. Look in your Jetcat manual for turbine to pipe spacing.
grbaker is online now
Reply
Display Modes
