Kingcat with AMT Pegasus
Reply
Old 04-11-2012, 09:05 PM
Xantos
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Kingcat with AMT Pegasus
Hi Guys,
I'm setting up my new Kingcat and this time around decided to try the AMT Pegasus.
The Peggy as you may know is probably one of the heaviest turbines around .
Plus I'll be adding a 1~1.5 lit smoke tank + Pump etc
Many of the new gen turbines producing similar thrust are far lighter (Thrust to weight ratios)
Considering the weight penalty do you think its still worth putting a Peggy on a KC or should I just choose something like a Rhino ?
Xantos is offline
Old 04-11-2012, 09:38 PM
sskianpour
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Kingcat with AMT Pegasus
AMT Netherlands vs. a Rhino?
Hahahahaha. Peggy. [8D]
KC's are so lightly loaded it is ridiculous; Don't worry about the extra weight. I doubled up my "Brake-away Plates" and she flies like what she is: An Aerobatic Trainer.
Good luck!
Shaz
sskianpour is offline
Old 04-11-2012, 09:39 PM
Ruizmilton
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Xantos:
I had the same question, I will maiden mine with a Rhino, but would like to use the Pegasus on it, being an exposed engine installation, the clean chrome look of the Peggy goes better with the KC, while more thrust sounds better, I feel the 28-30 pounds of the (Old)Peggy should be good for the Big Cat. Let's see what others tell us.
Ruizmilton is offline
Old 04-12-2012, 12:20 AM
Springbok Flyer
Springbok Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
.......never thought there was any choice...... Netherlands AMT Pegasus HP every time.....
Cheers,
Jan
Springbok Flyer is offline
Old 04-12-2012, 01:50 AM
hofer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Agree with most here - AMT Netherlands - what else ?
see you
Hans
hofer is offline
Old 04-12-2012, 01:54 AM
Jim Cattanach
Jim Cattanach's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have two Kingcats. One has a Merlin 140, the other a Wren XL 200. Both fly very well.
Jim Cattanach is offline
Old 04-12-2012, 03:49 AM
CraigG
CraigG's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I flew my KC for years with a Peggy. Great combo.
CraigG is offline
Old 04-12-2012, 04:07 AM
Xantos
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jim I have a KC with a XL200 too ! It has over 150 flights on it now , the XL needs to go back to Wren for a check up.
KC + XL is a great combo but a little more power would be nice.
Craig- Did you end up with any extra noseweight on your KC with the Peggy ?How much downthrust did you need on the turbine ?
Xantos is offline
Old 04-12-2012, 05:54 AM
CraigG
CraigG's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Xantos
Craig- Did you end up with any extra noseweight on your KC with the Peggy ? How much downthrust did you need on the turbine ?
2 or 3 washers under the forward mounting screw as I recall. With the batteries in the nose I did not need any extra noseweight.
CraigG is offline
Old 04-12-2012, 11:08 AM
scheur
scheur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
go for the top....AMT is the best!
scheur is offline
Old 04-12-2012, 02:09 PM
rcjetsaok
rcjetsaok's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Two #4 flat washers under the front engine mount screws... As far as nose weight, I wouldn't think so... The KC's tend to be nose heavy any way best I can tell... Seems battery's don't seem to end up in the nose.
Danno
rcjetsaok is offline
Old 04-12-2012, 06:58 PM
yeahbaby
yeahbaby's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got two a123s in the nose and an 11v lipo on top of the center fuel tank, no nose weight required. Two washers under the front mounting lug and you will be good to go.
Peggy on the back of mine
yeahbaby is offline
Old 04-12-2012, 07:27 PM
Kelly Rohrbach
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kingcat + Peggy =
Great combo!!!
Kelly Rohrbach is offline
Reply
Display Modes
